Hi ! for an informantion. please visit the website below. If you need more information about a specific electrical issue you can reach me at [email protected].
Motor Part Store Motor Parts Wholesale
SOURCE: Installing new handlebars, where are wire
One the earlier models, the handlebar connectors were down under the tank. But, Harley changes electrics every year so you never know. All I can tell you is "follow the wire".
SOURCE: how to change oil in 2003 HD FXD Dyna Super Glide
remove the drain plug from the oil pan, you will need either a 3/4" box wrench or a 5/8" box wrench and the drain plug will be facing forward on the the oil pan. It is easiest to remove this drain plug from under the right side of the bike. put drain plug back in after about 10 m,inutes of drain time and tighten to 18 ft. lbs. Dont forget to change the oil filter as well.
SOURCE: Harley wheels
Don't think so. Sportster and Dyna wheels interchange, depending on the year. Check with dealer for the Sporty/Dyna wheels that will fit.
Testimonial: "good answer"
SOURCE: 2003 harley davison superglide fxd questions concerning oil
The engine takes three quarts of oil with a filter change. Now, always check the oil after filling. The dipstick has two marks on it. The upper mark is "FULL HOT" and the lower mark is "FULL COLD". Do not overfill.
The transmission holds 20-24 ounces of transmission lube. It too has a dipstick on it.
The primary holds 36-42 ounces of oil. Do not overfill this either because too much oil will make your clutch seem like it's dragging. You will not be able to find neutral with the engine running.
Good luck
steve
SOURCE: i have 2001 dyna superglide
On most Dynas, there is an electrical box on the left side of the bike behind the coil. A chrome cover to the rear of the coil cover.
But, the fuses may be under the seat. Harley has been moving them around since 2000 and I haven't seen all the bike's fuse locations.
Good luck
Steve
