Question about Clarion DXZ855MP CD Player
The head unit is saying amp gaurd and will not play anything
  • 35 Answers
It sounds like ur unit is protecting it self from the amp, i wud recheck the amp & amps wiring all the way too the unit & if i found nothing ten i wud check the wiring to the unit, or maybe ur rem or rca wires cd b the prob. check them as well..hope i was of help
Posted on Jul 15, 2009
Clarion NZ502E audio problems
The issue has to be with either the head unit or the external amp that is being fed. Reverse the feed to the amp from the Clarion. If the audio issue now shifts to the other side the problem is with the Clarion. If the issue stays the same then the problem is with the amplifier.
Jun 19, 2016 | Clarion Car Audio & Video
Cd player dosen't play with amp
hmmm...what cd player are you using?..
May 03, 2008 | Kenwood KDC-MP828 CD Player
I have my amp and and subs hooked up right but i have multiple component wires on the back of my vm 9412. i need to know what to hook my component wires to in the back of my head unit and also need to know...
If you are running your speakers/subs from an external amp, then you wouldn't use any of the wires in the back. Usually you don't have any type of menu to change to make anything work. Some units have the ability to turn the signal off to the amp. What color are the wires in the back that you have remaining?
Apr 13, 2011 | Car Audio & Video
Amp stopped playing riding down the road, power light turned off. came back on when i unplugged the rca's and cuts back off when i try to plug them back in.
Faulty RCA cables, Or worse possible solution is if your amp stopped playing when it was pumping at high volume, you may have blown the RCA connectors inside your head unit Or inside your amp. If possible try another known good working amp with the wires you already have, If same happens, try different RCA cables. If problem persists after trying these, Its your head unit RCA connecters or amp RCA connectors. To rule out your amp connectors, try your amp in a friends car if possible, to rule out your head unit, try another good known working amp in your car with the wiring you already have
Mar 03, 2011 | Kicker ZX300.1 Car Audio Amplifier
I just bought a jensen 9312hd head unit and it says on the back only 4 ohms. Well my front speakers are 2.65 ohms and the back are 4 ohms if I connected the head unit would it hurt anything or would I be...
You will be ok. The ohms on the unit are for the rca jacks for an amp. your only issue would be if you have really crappy factory speakers that peak at less than 20-30w. If you have am speakers then your fine with almost any head unit.
Aug 11, 2010 | Ohm 4" 40W SHIELDED WOOFER, 8 Car Speaker
My car stereo shuts off while driving and playing
if you have had the head unit for long, it might be over heating and going into safe mode so it doesn't get to hot. This happened to my amp and i never did anything until it stopped working all together. so my guess would be just to get another head unit or get some type of cooling system.
Sep 04, 2009 | JVC AM FM CD DET FACE CAR STEREO
On my jensen vm9311ts its shows my dvd playing but no sound. aame thing with my ipod. its says its playing, but no sound. what wrong?
I'm guessing you're not using you're head unit to power your speakers/subs you're probably using a separate amp so your problem is not likely to have anything to do with your jensen headunit. first just make sure amp is turning on, if it's not check all your power wires(pwr, grd, remote) if it is turning on check your rca cables. it's a dvd player so theres more rca's in the back of the unit, it can be confusing so it'd be easy to mix somthin up... if everything checks out ok and you still can't get any sound take it to wherever you had it installed and have them look at it till they figure out what's wrong
Aug 31, 2009 | Jensen VM9510 Car DVD Player
I hooked up a 4 ch alpine amp MRP-F600. The back speakers play nice but the front speakers play very low. What could be the Problem?
1)When you connected the amp to the head unit, did you run two pairs of RCA cables for front and rear reference or did you only run one set of RCA cables from the rear out to the amp?  2)If that's not the case and you did ran two sets, on your amp, swop the rear and front RCA cables. If the rears go quiet and the fronts are loud you now know the issue is either in the cables or how the head unit is set up. If the fronts are still quiet, check your Amp's gain, frequency and filter setter settings (if available). If those settings don't change anything you may have a faulty amp. 3)Check speaker connections, seems trivial, but you never know.
Message me back if nothing works and/or you get stuck.
Ciza
Nov 04, 2008 | Alpine Car Audio & Video
I have a 20 qt Hobart Mixer. The magnet that is needed to allow the unit to run, is missing. We have used a store bought horseshoe style magnet for the last year or so, but does not work now. Do you...
the magnet is in the front gaurd. I suspect you have it taped on the back. looked behind the gaurd and you will see a small nut with a threaded stud looking thing in the neck of the mixer this is a electricl switch the magnet works. maybe your magnet is not ligned up on it or the switch is bad and you need a new one. the head is held on with 4 bolts onder the head is the switch and another switch for the bowl lift. . Best solution is have your front gaurd on and sliding corretly get a new magnet for it and it will lign up. If I cam and fixed it only way I would is with gaurd magnet. Can you tell I am factory trained and been drilled by Hobart lawyers many times. LOL never bypass a Saftey
One thing if mixer does not run at all it could be many things On/oof switch, Timer, bowl lift shwitch. Gaurd switch, realy that runse it in gaurd models. so be to be sure you need me LOL kidding. Good liuck
Sep 11, 2008 | Hobart A200 Stand Mixer
Clarion DXZ855MP CD Player Logo
73 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
