Question about HTC G1
How to insert G1 battery - HTC G1
  • amstercam Jul 13, 2009
    What helped was to re-check that the simcard was properly inserted! the diagonal slant enables the battery to fall into place. Problem solved. Thanks "sepreece" for your fine answer too!
The G1's back comes off. At the top end of the phone (away from the charger port), with the keyboard open, there's a tab where the back latches to the body. You have to open the keyboard to get to it. With the keyboard open, you can push that little tab outward to release the catch. On mine, the back makes a distinct click at that point and separates from the body along about half its length. To get it off the rest of the way, pry gently and it will come free.
Once the back is off, you can see the battery compartment. The SIM card slot is at the bottom of the battery area; you don't need to take it out to replace the battery. If the battery is in the phone, you can lift the top end of it out of the phone by lifting at the little recess at the top end. To put the battery in, slide it into the battery well with the contacts (three little brass strips) meeting the corresponding contacts at the bottom of the battery well.
Then, you can replace the back by hooking it on at the charger-port end and snapping the upper part of the back onto the body.
Posted on Jul 12, 2009
My g1 wont turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 11, 2012 | HTC G1
How do i get free unlock code for g1 google phone
Dear,
  • 1. Side out the Keyboard / Open Left Hand side Notch to unlock Battery Panel.
  • 2. Insert TMobile SIM Card and Battery.
  • 3. Press MENU Button Constantly and Switch the Phone using Red Talk End / Power Button but do not Release the Menu Key.
  • 4. This will put on the Phone in Safe Mode.
  • 5. Press to Emergency Dial Button, Windows dial *#06# and this will show IMEI Number: note it down and also Recheck IMEI with Box.
  • 6. Give IMEI to Unlock Code Provider www.unlock-tmobileg1.com and get the Unlock Code.
  • 7. Now Return to main Screen and Press MENU Button this Will popup APN Button, Just Press it.
  • 8. Go to APN Setting. There will be so many APN already Preset. Again Press MENU Button this will show NEW APN Popup Button again Press.
  • 9. Remember to put Right MCC (Mobile Country Code), and MNC Mobile Network Code, G1 Matches SIM card Data of MCC / MNC with these Setting and then try to use that. Settings.
    All World MCC / MNC codes is available here:
    http://en.wikipedia.org/wiki/Mobile_network_code
  • 10. Now Switch off the Phone and Wait for Unlock codes.
  • 11. Insert the Non T-Mobile SIM Card which you intend to use it with G1 and switch G1 on. (Your SIM must have
    Data plan / GPRS Activated so G1 will able to contact google.com for Activation)
  • 12. HTC G1 will ask for Unlock Codes. Type unlock code carefully, typing wrong code thrice may make Phone Hardware Locked.
  • 13. Once Unlocked your GPRS / EDGE / 3G Data Service will be active as per APN Setting we did before.
  • 14. Type Google User name / Password in Signing Window and this will Activate the Unlock G1 Device on your SIM Card.
  • 15. Make other remaining Data Setting like MMS / Home Page / Port to Active other Data Service
Thanks
Sep 14, 2010 | HTC Google G1/Dream Cell Phone Black...
My g1 incoming calls are all foward and the call and home buttons isn't working
Turn off-remove the battery-leave for 5 to 10 mins-re insert the battery and restart.If it doesnt help you,try to firmware upgrade.If tht too doesnt help,u'll need to take it to a service centre
Sep 02, 2010 | HTC G1
Where to insert sim card for g1
remove the back cover and the battery and look for the little picture that looks like a SIM card and insert the sim card with the gold part facing down and the cut corner of the card towards the camera lens.
May 20, 2010 | HTC G1
Received G1 replacement phone i put my existing SIM card into the replacement and in the notifications bar it says SD card removed, insert new one. the SIM card works fine in my current G1
Sounds like you are replacing the SD card, not the SIM card. The SIM is underneath the battery. It's a small white rectangle missing a corner.
Feb 20, 2010 | HTC G1
I want to unlock my g1 android. but i cant get the code for it
Hello
You can get the unlock code for free by calling the network provider.
Or you can buy the unlock code from third parties.
Dec 26, 2009 | HTC G1 Smartphone
BLACK SCREEN · I TRIED TO RESTART MY PHONE AND NOW THE SCREEN IS ON BUT STAYS BLACK
I feel your pain. My g1 droped, the screen cracked, now 3 weeks later my screen turns black. Not even turning it off or removing the battery for hours changes this. However, i found if you wiggle the screen just right sometimes you can get your screen back... for a little bit.
Oct 17, 2009 | HTC G1
Sd card is not working
Try cleaning the pins of SC Card with contact cleaner or alcohol if you prefer make sure its dry enough before inserting. If nothing happens try detecting it on PC Desktop with proper Card reader, backup files if you still can then reformat thE SD Card. Reinsert in your HTC G1 if successful reformat it again using your HTC G1 to acquire compatabilty on the device.. hope this help...
Jul 23, 2009 | HTC G1
I can't seem to download music to my G1 t-mobile phone?
Did you Mount the G1 to your Comp? When yo plug in the USB the USB symbol should appear along the top of the screen drag down the menu and select mount USB
Jun 03, 2009 | HTC G1
Need unlocking code and steps for g1 phone
The only way to get the unlock code is to have T-mobile service for at least 90 days(unless you're lucky). Call the service help line and tell them that you are going over seas and would like the unlock code for your G1. They will need your account info as well as the IMEI number of your phone(this can be found under the battery on the phone). In roughly 24hrs. you will receive an e-mail from HTC with your phone's SPECIFIC code(codes don't work for other G1s).
HOW TO:
1. Turn off the phone and remove battery/SIM
2. Insert other carrier's SIM and replace battery/cover
3. Power up phone and enter unlock code in menu that comes up.
4. Enjoy your unlocked G1
Mar 16, 2009 | HTC G1 Smartphone
HTC G1 Logo
507 people viewed this question
Top HTC Computers & Internet Experts
Tom Chichester
Mishan Kasiparsad
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
