Question about Sceptre X7SV-Naga (Silver) 17 in. Flat Panel LCD Monitor
Over Range i have had this monitor for about 2 years now and in the last month whenever i play a game my monitor goes blank and displays Over Range on it. I have played with the resolution on both the games and the monitor and it has not helped. i have 512 MB RAM and a Radeon 9800pro 256 MB graphics card.
    Problem Solver:
  • 8 Answers
Re: Over Range
Change the graphics card it may con't support the display
and install directx.
Posted on Nov 17, 2007
0 characters
3 Points
Whenever i try to open the game bought yesterday the screen goes blank little box comes up out of range & freezes the computer up so i have to disconnect to restart the computer
Update drivers, Video & chipset. Also update directX & check the vendors website for patches for the game, it might be a common issue, Also check if you can adjust the game's resolution before you launch as it may be set at a resolution your screen can not display. I think if you try all these things you will have some success.
Nov 04, 2009 | Computer Monitors
Blank HP w1907
If the power light does not turn color and stay's green on startup, it is not a power problem. It is most likely the inverter. If the unit is in warranty, send it out ASAP. Contact HP customer care by email and have the issue logged in.
If in warranty, they will send you a box by FedX second day and have repaired.
This is a 19" monitor and will not be worth paying for repairs if not in warranty.
Sep 03, 2009 | HP w1907 LCD Monitor
Monitor goes blank after 2-3 seconds
could be hardware failure but i would try buttons on front of monitor first. notice, usually green led on monitor is green, if it goes to amber, you are loosing sync pulse.
Aug 20, 2009 | Computer Monitors
"No signal detected" when LCD connected with DVI-D Cable
Thank you for providing your configuration details.
You have failed to specify wheather or not your LCD Display is under Warrenty.
Perhaps these simple trouble shooting procedures will get the job done.
1. use the DVI to VGA adaptor that came with your card
Plug in a regular CRT monitor to the Primary Display Output Port using the DVI to VGA adaptor
( either port can be designated as the primary by you )
I like to use the Port nearest to the motherboard as the Primary
2. plug in the your LCD monitor on Secondary Display port using your DVI cable
At this point you should be able to see your desktop on the Primary CRT Display
3. Go to the display properties and use the Nvidia Dual Display Setup Wizard
set both desktops to CLONED at a resolution of 1024x768 and set the refresh to 60Hz
which is default for most LCD displays , some have higher refresh rates , consult your user manuel
If the display resolution and refresh are set incorrectly for your CRT or LCD you will see
Signal Out of Range ( if the display has the ability to display that error message )
At this stage both displays should be showing a Windows Desktop
If you now see your desktop on both displays , you can now put the LCD on the Primary Port
No Signal Detected ( this means the display device is not receiving a signal )
If your LCD display is still displaying the error message
"No Signal Detected" after performing the trouble shooting proceedures
You may need to read the user manuel about how to enable DVI signal input.
If you are certan you have done everything correctly but still see only "No Signal Detected"
Your LCD Display may need replacement
Loch Hime :-)
Sep 14, 2008 | BenQ FP71E 17" LCD Monitor
Monitor displays breifly then goes to blank screen
The power -inverter board probably needs an overhaul.
I redo many of these.
If the screen was pinkish or flickering before it finally got to this point, it is possible that a bulb has gone bad.
Sep 07, 2008 | Proview PL926WBi 19" LCD Monitor
There is just no way you will be happy to hear it needs service or replacement under warranty.
Jul 03, 2008 | Relisys RLT1720 17" LCD Monitor
Samsung SyncMaster 17" LCD Blacks out
If you have a second monitor, you could use your computer until the monitor goes black... then plug in a replacement monitor. My guess is that one will display black too...
My gut feeling is that your VGA card is on the fritz... I'm not convinced it's your monitor. Do you have a replacement VGA card you can try? I'll bet that'll take care of the problem.
Apr 22, 2008 | Samsung SyncMaster 17" LCD Monitor
F1 = Fuse 1
You should be able to locate a surface mount fuse at your local electronics store.
Apr 12, 2008 | NEC MultiSync LCD1830 18.1" LCD Monitor
Sceptre X7SV-Naga (Silver) 17 in. Flat Panel LCD Monitor Logo
135 people viewed this question
Top Sceptre Computer Monitors Experts
Robert Veldman
Robert Veldman
Mike McWhinney
Are you a Sceptre Computer Monitor Expert? Answer questions, earn points and help others
