SOURCE: warning light
As long as you have the correct tyre pressure , dont worry. The warning light depends on various factors
SOURCE: BMW i system
this needs to be reset with a scan tool capable of doing european cars, call around and see if some one has this tool, get back to me if you need more help.pleaserate my fix as i strive to be te best Thanks Ray
SOURCE: punctured tyre warning indicator
use the I drive system to reset flat tire monitor, go to vehicle settings, then flat tire monitor, then select reset, then you have to drive the car system resets as you drive
SOURCE: warning light that is orange
I just checked the owner's manual. I think you may be looking at a brake warning lamp. See if this helps.
SOURCE: reset bmw 530 puncture warning light
The TPMS signal is not idetified by your vehicle,when a predetermine amount of air is not present the sensor turns off. When this sensor turns off .Your vehicle TPMS monitor notice it and turns the light on.Some vehicle needs the TPMS monitor to be reset.Others need to be turned on. Still others just needs a set amount of air pressure to turn on and driven in your case the TPMS monitor should detect the sensor and the light will turn off
