Question about Jenn-Air JFC2089HE French Door Refrigerator
Frig. NOT working
I moved into my home about 2 1/2 yrs ago and in the house was left an Admiral Refrigerator. At the beginning of the week I noticed the frig. section smelling a little so I got a new box of baking soda on Wednesday and waited to see if my problem went away. Well today my husband noticed nothing in the frig was cold anymore. The freezer is working just fine. The compressor is still running. There is access on the back to the fan the blows from the freezer to the frig. Should I try defrosting it. Checking the evaporation coils, and if so where could they be and what would they look like or maybe could it be a faulty thermostat. Help! Thanks in advance! Pam
  • p_rizz Nov 15, 2007
    I'm sorry there is NOT access to the fan on the back.
First listen to here if the fan is working , if the fan is working remove items in the freezer and check back wall of freezer compartment for frost if there is frost, the problem may be in the defrost system witch can be checked easily.with a small amount of tools and 1 multimeter remove contents from freezer if there ia an icemaker unplug icemalker from freezer wall(rear)and then there is 2 to3 1/4 in screws that hold thr icemaker in place. Remove Then remove rear panel . remove the two screws at top panel should lift out ok it's fit tight in there. once removed, check all the connections .look for lose connections if there is to much frost the coil may have to be defrosted with a blow dryer .the defrost thermostat ( located at right side top)unplug wires and carfuly remoe from coil inspect for damage. Sometimes it will swell from moisture that freezes and damages it. or it just open check across the two leads with the ohms scale if the meter does'nt move the thermostat is bad replace if it dose move then check the heating element if no movement, replace if their is then the problem may lie in the defrost timer or the defrost board (depending on model) located in the top of the refrigerator sectio behind the light panel. when ordering parts always have you model and serial numbers ready for the parts person. have a great day!
Posted on Nov 17, 2007
  • 25 Answers
Behind the freezer panel, a defrost thermostat is insert in the evaorator coil. It could been disconnected (terminals) by the growing ice or simply defective. Also there is a defrost heater in there; it can have a similar problem.First, stop your refrigerator and let it defrost.
Posted on Nov 16, 2007
Refrigerator was unplugged for a week. We moved it from one house to another and plugged it in and it's not turning on. The light is on but motor isn't starting. Any Ideas?
ck power at new house ( the plug ) do the lights come on in frig ? if so look for wires under frig that may have been puled off during move .. this should not be a tuff one . / the frig should not been damaged by beeing off . did you lay it down dueing the move ( it chould have been kept upright .. as laying down causes the oil to ru up in the cold coil .) hope this hepls mm
Oct 24, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
About 5 days ago I noticed a strong chemical smell (like open permanent markers or nail polish remover) in my kitchen. The smell permiates the whole house, but is strongest in the kitchen area when I close...
No. The coolant cannot leak as a liquid and soak into the floor. Also, the smell of the coolant (refrigerant) does not have the acetone/ketone/laquer thinner smell that you are describing, and if someway the smell originated from the frig, the smell would without a doubt be inside the frig as well. You need to look frosome container stored in a cabinet or stored on conrete floor that has rusted or opened some way and the thinner/cleaner/solvent has leaked from such a containerwithout notice. Goodluck, Macgivor
Jan 27, 2010 | KitchenAid Superba KSCS23IN Side by Side...
Freezer and fridge not cool enough
Check if the syrofoam pieces block air inlet. If so then this may be the problem.
May 08, 2017 | Admiral Refrigerators
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
Moved refrig this morning and now it is not cooling... freezer works great
Hih, Check and see if something has stopped the condenser fan motor down by the compressor from turning. Sometimes this happens in a move.
Also make sure the controls didn't get turned to wrong settings. Make sure evaporator fan motor is working in freezer and that there is no frost building up on the rear panel.
Just some ideas to help you.
lease let me know if I can assist you further.
May 30, 2009 | Admiral 26 cu. ft. Side-By-Side...
My refrigerator freezer quit working
what you hear is the comp. trying to syart(short cycling) there is a $10 fix you can try before buying a new frig.,go to your local appliance parts store and ask for a 3in1 starter for a frig.,it has the directions right on it,let me know what happens-mike
Mar 24, 2009 | Kenmore HE2 Plus Front Load Washer
Load noise coming from freezer
nothing to do with light bulb - noise is probably fan hitting ice that has built up. to check, remove back panel inside freezer and check for ice build up. melt off with a hairdryer and get back to me if i'm right
Nov 12, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Same as 6-9-08 freezer ices up, frig won't cool
Not sure if this will help but I have/had a similar problem with my admiral side by side (approx 12 yrs old not sure of the model #)and I think I fixed it this morning..
At the back of the fridge compartment I removed the cover (covers the light and controls) the Freezer setting just seems to adjust a flap that sends cold air into the fridge.. around the flap was a mass of ice.. what seemed to be happening was as this 'vent' was blocked with ice no cold air entered the fridge and the temp stayed high and hence the stat did not cut out .. compressor running flat out 24/7..... I removed the ice and it now seems to be working better (2-3 hrs will see what its like when I get home from work..!)
Jul 09, 2008 | Admiral 26 cu. ft. Side-By-Side...
Fisher/Paykel Refrigerators
The problem of a sulfur smell is not likely to be coming from the refrigeration system itself. Near the bottom front is a removable kick plate. when this plate is removed you can access the drain pan for collection and evaporation of the water from defrosts. remove and clean the drain pan and then reinstall it. On the lower back of the refrigerator there is generally a fiber panel that is removable. remove this panel and inspect the underside for something that should not be there. Such as a dead rodent. Sorry but I've seen it many times. After clearing do not forget to replace the panel . It has to be in place for proper air circulation and heat removal from the refrigeration system.
Apr 28, 2008 | Refrigerators
Freezer and refrigerator run but is not cold
Andeb, couple of things you want to check. Is the fan in the freezer section running? Take the lower back panel off and see if the condensor fan is running as well as the compressor. As long as you tilted it only slightly I would think this is a fan or overload relay problem. Check the things I mentioned and post back...Catriver.
Aug 21, 2006 | Kenmore 50522 / 50524 Side by Side...
Jenn-Air JFC2089HE French Door Refrigerator Logo
105 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
