Question about Troy-Bilt Garden
I have a Wizzard model GIS 2025 A18 tiller that was manufactured by Troy-Bilt. This unit has a reverse, 2 belts that my grandson took apart to replace. However he was recalled to active duty before he finished. I now have a number of retainers and springs that I cannot figure out where they go. Does anyone have a diagram that might help me?
4 Suggested Answers
Loringh
  • 185 Answers
SOURCE: need a repair manual for troy bilt tiller
Ddavis:
Have a look on ebay. Do a search for troy bilt tiller manual. There are several folks on ebay that collect and sell on manual on all kinds of stuff. I was able to locate a manual for an old singer sewing machine.
Hope this helps Good Luck Loringh please leave me a rating Thks
Posted on Nov 11, 2008
  • 3 Answers
SOURCE: how do I change the belts on a troy bilt tiller
remove plastic belt cover
remove the guard,belt/pulley
work in the right side first:
remove the rigth-side wheel
remove the screws of the bumper
remove 2 screws on bracket/transmission assembly
pull the bracket
install the new belt
reinstall the right side screws and wheel
do the same in the left side
Ps: remove the belt guide, and reverse return spring
http://www.partstree.com/parts/?lc=troy_bilt&mn=21A-634K766+7HP+FRT+Roto-Tiller+(2005)&dn=0079200009
Posted on May 13, 2009
SOURCE: where do i find serial numbers on troy bilt horse tillers
On the old Gardenways Horse the serial number is stamped into the top of a little flange on the side of the transmission just to the right (viewed from behind) of where the handles attach. It may be covered in gunk so a douse of mineral spirits and a little scraping will reveal it.
You can download the manual and parts list from the Troybuilt site. Enter "HORSE" for the model and the serial number.
Posted on Aug 06, 2009
Need to see belt route for gilson bros. tiller
You did not state if it was a front or rear tine tiller. This is for the front tine tiller:
http://photos.cubfest.com/albums/userpics/10231/Belt_Routing.jpg
The rear belt has a 1/2 twist in it for reverse. The front belt goes on nomally.
If this does not help you I would like a model number if you can locate it so I can get your the proper routing diagram.
Kelly
Apr 14, 2011 | Troy-Bilt Garden
Need belt diagram for Troy bilt Pony. The drive belt just broke and I need to 1, buy one and 2, replace.
hi im having trouble on my troy belt riding mower it is a 42 inch im tring to change the belt we have it on but it not right please help me
May 15, 2010 | Troy-Bilt Pony Garden Tiller
Can i see the models from 1983 to 1985,i need a belt so i can use reverse again but i dont now my model or size. my husband died 3 years ago. if i could see some pictures from the 1980's mine has a potatoe...
Your question doesn't give enough detail to properly answer. Do you know if the tiller is a Horse model or a Pony model? Troy Bilt made both models back in the timeframe you noted. The Horse model had tires that required air to inflate. The Pony model likely had hard rubber tires in that era. The Horse models had a reverse disc, no belt. The Pony had a belt.
Once you know which model you have - look for your closest Troy Bilt dealer and see if they can track down the part for you. They might appreciate it if you could provide the serial number - which is located on the pipe connecting the tiller transmission front half to the back half, where the tines are located. It's stamped right into the metal tube on both models.
Jul 17, 2009 | Troy-Bilt Garden
How to install belt on Troy bilt tiller:
With engine OFF If you put belt on engine pully and driven pulley then work the clutch handle you should be able to see how belt goes so it tightens when clutch is worked.
Jun 24, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
How do I change the belts on a troy bilt tiller
pull the bracket
May 06, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
How do i adjust belt on troy bilt horse tiller
How do I tighten a belt on a troybilt Tecumseh rear tine tiller?
May 04, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
How do i put a troy-bilt tiller 3 hp.into free
The way to move without the motor running...
1.on each wheel pull pin in center of hub
2.push wheel closer to motor.
3.put pin back in to axle but not though hub
4.do the same steps to other wheel
now you can push tiller
Apr 07, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Belts slippin on troy bilt horse
Have you adjusted the locking cam for forward. This cam is held in place with one bolt. The further you move it down the tighter it will make the belt
Apr 02, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Garden Logo
83 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
