Question about LaCie Computers & Internet
The computer will not read the hard drive
I connected the hard drive and was ready to format. as soon as i selected to start the formating it stopped and will not show that it is connected now. How can i fix this?
  • gmandible Jul 11, 2009
    i just bought this brand new. and that doesnt seem to work.
  • 3,741 Answers
The connection are not getting detected.its getting loose in between.check out if its connected tightly,and there is no dust in between the connections.remove all the external removable connections and reconnect every thing again and retry.
Posted on Jul 11, 2009
Reformatting HCS725032VLA380
Is it your primary hard drive ?
Reformat hard drive to NTFS Windows XP allows you to easily format the hard drives with its inbuilt utility. Formatting the hard drive would forever delete all the files stored on it. There are two ways in which you can format the hard disk partition - from My Computer and from DOS. You cannot have a NTFS partition with allocation unit s above 4096.
Click on "Start," and then click on "My Computer." Right-click on the disk partition to format and then click on "Format." Click on the "File System" drop down box and select "NTFS." Click on the "Allocation unit " drop down box and select an allocation . It is recommended that you select the "Default allocation " option. Click on the "Start" button. b> Format the Partition from DOS b> Click on "Start," and then click on "Run." Type "cmd" in the 'Run' dialog box and then press "Enter." Type "format drive_letter: /FS:NTFS" at the command prompt and then press "Enter." Replace the 'drive_letter' here with the letter of the drive that you want to format (for example, format e: /FS:NTFS). For help on advanced formatting options, type "format/?'more" at the command prompt and then press "Enter." Keep pressing "Enter" as you read on. Hope it helps
Jan 24, 2013 | Hitachi CinemaStar 7K500 HCS725032VLA380...
How fix it:''windows was unable to complete the format''
You have to be the computers administrator to change any values on any hard drive on your computer
click start control panel user accounts on the users tab click the name of the computer administrator you must have full control
click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
click start click on my computer you should see your usb drive
right click then select format
another way is to control panel administrative tools computer management disk management right click on your drive select format
hope this helps
Nov 08, 2012 | Computers & Internet
How do you set up an external hard drive?
Turn your computer on and plug the external hard drive into the computer.
Open "Computer Management" by clicking "Start," "Control Panel," "System and Security," "Administrative Tools" and "Computer Management."
Click "Disk Management" in the left pane under "Storage."
Locate your external drive from the list of hard drives connected or installed on your computer.
Right-click the drive and select "Format."
Select a file format from the drop-down menu. Choose "NTFS" if you will be using the external hard drive with a computer that uses Windows 7, Windows Vista or Windows XP.
If you will be using the hard drive with an older version of Windows, select "FAT32."
This is a much less common format.
Click "OK" twice and your external drive is formatted. Once the drive is formatted, it is properly set up to be used with your computer.
hope this helps
Sep 10, 2012 | Computers & Internet
How to format and use new USB storage device
if its not your primary drive
click start click on my computer you should see your drive
hope this helps
May 14, 2012 | Computers & Internet
My computer is not letting me format my removable disc
click start click to open on my computer you should see your Hard drive C: right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure all 3 boxes are ticked full control change and read in windows 7
Right click the icon of your Hard Drive (It should be C:/ or something)
Click permissions
click start click on my computer to open you should see your drive
another way
click start control panel administration tools computer management disk management right click on your usb drive select format
hope this helps you
Jan 17, 2012 | Microsoft Office Computers & Internet
It claims to be full. How do I empty it and start over?
It depends on your operating system but is similar for most windows versions.
For windows 7/vista
Click Start Click computer right click the flash drive and click format check quick format and then click start
Note: this will erase everything on the drive.
Mar 05, 2011 | Dane-Elec DaneElec 2GB USB Drive Red Hard...
Phillips software upgrade is UPG file format?? How do you work around?
Update starts as soon as you connect usb drive (automatic start). For this version number has to be different than the firmware on the tv. If it is a downgrade it will ask if you are sure that you want to do it.
Philips refer that you should format the drive as FAT (DOS) or FAT (not FAT32)however other persons refer that FAT32 can be used. You can format USB drive by right clicl on it in "My computer" and selecting "forma"t then "format as". Please note that by doing this (format) everything on that drive would be permanently erased.
Feb 21, 2011 | Philips 37PF7320A 37 in. HD-Ready LCD...
Format
If you are wanting to re-install your system press either F9, F10 , F11 Or F12 As soon as your laptop says ACER on it. You should hopefully have the OS pre installed ready to re-install any time you want. However, if you are wanting to delete all the files on your laptop and formatt the hard drive. go to < MY COMPUTER. < Right Click The Hard-Drive you want to format and select format.
May 27, 2010 | Acer Aspire 5735 Notebook
How do i free 8mb in Sandisk Sansa M250 i formated but the same result happens plz help me!!!!
SanDisk tech support recommends formatting the m200 series in both MSC and MTP modes to completely clear out all work areas,"fragments" and residual data. The m200 has a very basic Operating System that doesn't have a defrag option. According to tech support, the m200 needs formmating occasionally to keep it working smoothly. I learned that formatting will also clear up intermittent hang-ups. I format mine each time I reload it.
Format in MSC Mode
With the m200 not connected to the PC, power it on, press the menu key. Select "Settings", then USB, then MSC.
Connect the m200 to the PC via the USB cable
Right click on the "Start" button.
Left click on "Explore"
Find the m200. It will show as a hard drive, for example: "SANSA M250"
Right click on the m200 device and select "Format"
After formatting is complete, click on the "Safely Remove Hardware" icon on the System Tray and stop the device
Disconnect the m200 from the PC.
Format in MTP Mode
With the m200 not connected to the PC, power it on, press the menu key. Select "Settings", then USB, then Auto Detect.
Connect the m200 to the PC via the USB cable.
Find the m200. This time it will not show as a hard drive but as a music device, for example: "SanDisk Sansa m250"Note there is no drive letter in MTP mode.
After formatting is complete, disconnect the m200 from the PC. There is no icon to stop the device.
Your m200 device is now formatted and ready to reload.
By the way, MSC mode is mostly for use with other than Windows XP computers. If you are using WinXP and Windows Media Player 10, you might consider using MTP mode and WMP to manage the m200's.
Source: http://forums.sandisk.com
If i was helpful, kindly do Rate!
Regards.
Jul 28, 2009 | SanDisk Sansa m240 MP3 Player
Format Hard Drive Error
If the unit detects any form of Hard Drive Error it asks you to format the drive. Connect the unit to your PC and run ScanDisk or DOS Chkdsk on the drive. Will help to rectify any issues with the FAT. Windows XP & 2000 Running Check Disk Utility (ChkDsk) ? HARD DRIVE mode only If you still have problems with the file system on your AV 500 you can try to fix it using the DOS utility, check disk (chkdsk). Do the following; ? Make sure external AC adapter is powering the AV 500. ? Quit all running applications. ? Properly connect the AV 500 to your computer ? Wait patiently (up to 5 minutes) for Windows XP to show the local drive as mounted. ? Open a DOS window. Programs > Accessories > Command Prompt. ? At the prompt, type chkdsk e: /f . Use e: or f: or whatever drive letter is representing your AV 500. The /f argument tells the program to automatically fix errors. ? Be patient, this may take a while. ? When finished, exit the DOS Window and properly disconnect the AV 500 from your computer. Now try using the device. DO NOT try to defrag the drive. Let us know how you get on.
Jul 26, 2007 | Archos AV 500 Digital Media Player
Computers & Internet Logo
88 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
