Question about Philips Televison & Video
Phillips TS2744 C103 chassis # 27B800-7562. The green LED power light flashes an I have no picture, just audio.
techman
  • 3130 Answers
SOURCE: toshiba 27ax61 television chassis tma509b power led flashes
I dont think your problems in the degussing my friend. Sounds like the sets doing whats its supose to when theres a power supply overload??? we really need more info on this one please.
Posted on Mar 24, 2006
Shuttle83
  • 1139 Answers
SOURCE: Phillips/Magnavox 9P5544C102 white raster and shuts down
This denotes a problem called blooming the horizontal lines you see are called retrace lines this is caused by the increase in anode voltage which could be caused by an increase in HV section current which trips the overcurrent protection dircuit and turns the TV off.If you do not have electronics experience I would suggest taking the set to a TV repair shop.
Posted on Sep 24, 2007
sexy-ym
  • 55 Answers
SOURCE: toshiba cz36v61
check regulator or system ic.....
sexy-ym
Posted on Sep 07, 2008
  • 91 Answers
SOURCE: Phillips 42PF5321D/37-Green power light, but no A/V.
bad powersupply, the powersupply has 4 voltages, +12, +5, -12 & +12 the led only tells you that the +12 is working.
Posted on Dec 16, 2008
Ecollier2012
  • 3459 Answers
SOURCE: no picture, no sound, error code 7
Sounds like one of two problems
1) Convergence chips are shorted....One quick test is to desolder and remove both STK392 chips....then power the set on. If the tubes light up the chips were shorted. You can get new ones from www.TvRepairKits.com
2) Another possible problem is a bad HVG - AKA the flyback.
Try the convergence chip test first. Note: On some Philips sets you can just unplug cable "1516" instead of removing the chips.
For instructions on how to find/remove cable 1516 visit the website listed above and click on their tips page. On that page click on the "Magnavox DPTV3xxx Checks" link.
Posted on Feb 13, 2009
I have an LG Plasma TV model 50pc5d-ul That powers up with no picture. Green power-on light blinks 13 times (staying on with the 13th blink).
Green LED flashes 13 times means power supply board is the issue. If you are familiar with the electronic repair, open the back and check if any capacitors are blown.. if they are bulgy on top, replace them. Attached link may help you in investigating the problem:
https://www.avforums.com/threads/lg-lcd-tv-power-problems.840361/page-2
https://www.youtube.com/watch?v=0Z_T_cS_B7g
May 08, 2017 | LG Televison & Video
No picture on startup , continuous flashing green and orange led
Seems that way. Fact that you saw the logo on screen eliminates the inverter board.
Nov 08, 2015 | Sony XBR-52LX900 BRAVIA LX900 Series 52 3D...
I have a 42 " Phillips with no pic and no sound. I've replaced the Power Board and CT Board tht corrected the error blinking lights but still have the problem My Light stays solid green and I
Dear Mate
Please share us the Model # and Is that is the Plasma LCD or LED. And tell us Is your`s TV is stay on stand by or its green LED is stable.With No video and sound.
Dec 11, 2014 | Televison & Video
Green LED stays on steady after a minute when you turn on but no picture black screen then the led flashes fast continuesly
Please follow up with me if your able to get any sound out of the unit.
I had a similar problem. I had a 52" RCArear projection tv. It would do this when I initially turned on the television, but then after a few "on/off, on/off, on/off" cycles it would stay on. Eventually it started doing it more; until finally there was a spark and that was it. The tv was dead.The bloggers called it "the blinking green light of death" (because of green light on the panel).The power board is going out.ALSO holding down the Input and Menu buttons afterward will give you some diagnostic information via 2 sets of blinking indicator lights.
You may very well have issues with capacitors on this set being that it is or very similar to the V26 chassis. Since I have spare test lamps laying around, I would normally try that first. If the lamp still would not stay lit, I would then suspect the electrical chassis (capacitors). When I suspect the chassis, I can usually verify it by pulling it out and partially disassemble it and find blown capacitors
Jan 12, 2011 | Mitsubishi WS-55613 55" Rear Projection...
When turned on green light flashes and no picture
Check the Lamp if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 2X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Check the ballast if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 3X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Dec 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Phillips Flat TV Model 20pf4121\105 (Flashing green led)
I had exactly the same problem When the TV was switched on all I could see was a flashing green light. After cheching the TV internals and not seeing a problem including the power supply unit which looked and checked normal. Here is what I did to get M TV working again.
Disconnect it from the power supply. Hold down all the buttons simultaneously i.e. the on/off, the volume, the programme, menu buttons, all of them simultaneously and Plug it into the power supply again.
Lo and behold My TV jumped back into life after an absence of about 4 weeks.
Try it yourself exactly as above.
Best of luck.
Irishfreethinker
Jul 10, 2009 | Philips 20PF5120/01 20 in. EDTV-Ready LCD...
Blinking green light under 'Timer' flashes there is no picture
If you have a green blinking LED that runs continuosly, its the widespread problem of failures of capacitors on several circuit boards in the TV. Currently Mits is having authorized service centers remove the chassis and send it them for rebuilding. Its an expensive and time consuming repair.
Feb 17, 2009 | Mitsubishi WD-62525 62" Rear Projection...
I have a phillips magnovox big screen (March 2000) model # 9P6444 C103 - the picture is very dark and is best watched with the room lights off... what needs to be replaced or fixed?
The coolant fluid in the blue and green picture tubes is in need of changing.Unless you have done this before I do not recommend that you attempt this repair.A shop shoud be able to make this set look like new again for about $275
Jan 11, 2009 | Televison & Video
Dec 16, 2008 | Televison & Video
No picture
you have the ATC311 chassis. do this proceedure and you can track down where the problem is. let me know if you need more assistance. i can also post a link where you can get the training manual at a cheap cost emailed to you if you would like a copy.
5. Apply AC power and press power button.
6. If LED turns on and then off, disconnect J11501 (Audio CBA) and press power
button again. If power LED comes on and stays on suspect Audio CBA. If LED
still flashes or does not light go to step 7.
7. Disconnect J26903 (AV IN CBA) and press power button again. If power LED
comes on and stays on suspect AV IN CBA. If LED still flashes or does not
light go to next step.
8. Disconnect J19500 (Convergence CBA) and press power button again. If
power LED comes on and stays on troubleshoot the Convergence CBA. If
LED still flashes or does not light go to next step.
9. Disconnect J14801 (Deflection CBA) and press power button again. If power
LED comes on and stays on suspect Deflection CBA. If LED still flashes or
does not light suspect DM2 module.
Jun 08, 2008 | RCA HD61LPW42 61" Rear Projection HDTV
Televison & Video Logo
255 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
