Greetings, I read your question and I think Reliable-Store can help you in this. Here's the site link.
Best Manuals
SOURCE: I have a lx 255 john deere wont start
You have a defective ignation coil. When the engine gets hot, the winding in the coil opens and the engine stops. After it cools down, it will again make contact and start again. If you don't know where the coil is, follow the wire from the spark plug. The spark plug wire is attached to the coil from the factory. It's easy to replace with a 1/4 inch socket set. Set the magnet to coil gap with a standard business card.
SOURCE: where is the hood release for the 3320
Below the bottom of the hood you will find two metal tabs,push down on either one to release the hood.You will have to release the grill guard pin and roll it forward before the hood will open all the way[if it has a loader on the tractor].Under the hood and to the left of the battery is the prop rod to hold it up.Hope this is helpful.
SOURCE: My John Deere 345 dies for no apparent reason
You have dirt in the fuel tank and it sucks the dirt up on the filter that is attached to the pump. After the machine stalls, the dirt falls off and it will restart and run for a few min.
SOURCE: I need a belt diagram
Hi and welcome to FixYa, I am Kelly
By secondary belt I am assuming you need the deck belt routing. Here is a picture of the front deck belt routing: http://opebycrigby.tripod.com/decks/jd/jdf525.jpg
Thanks for choosing FixYa,
Kelly
