Question about Philips Magnavox 32PS55S 32" TV
Philips 32PS55 S321
Any time I am watching the TV it could be cold or warm, any bright or white screen, it shuts the TV off. well, it is still running, but in order to get the picture back, I need to shut it off and turn it back off. Any ideas on what this could be?
  • ron_d Dec 16, 2007
    I have the exact same problem. If you change the channel the picture will come back on as well. Please let me know if you find a solution!
  • neraht May 26, 2008
    i have a similiar problem. mine also shuts off when it gets to bright. i have noticed that if i turn down the brightness it helps but also makes normal things very hard to see. i also notice a strobing affect dureing the bright scenes, as in the screen shrinks and swells back up again rapidly. coupled with the left and right sides are cut off, as though it is playing in wide screen. i have checked all the settings i know how to and need LOTS of assistance. :)
  • 54 Answers
Unless you are a technical electrition its impossible to tell you how to fix it, botom line you will need to take it to a repair store to be fixed , sorry i cant be more helpful
Posted on Nov 16, 2007
Check C2455 47mfd @25v on main boardand R3345 on crt board
Posted on Jan 11, 2008
Older 52 inch tv magnavox where screen is too bright or how to repair it
There two possible things based on your description.
Go to a channel that is in black and white and examine the picture--is it black and white or yellow?
These sets do have screen controls that can be adjusted but they rarely need it.
If the picture is yellow looking it could be interpreted as too bright.
If good black and white picture---stand back ten feet when you examine it---I can tell you how to adjust the sceen controls, not real easy but can be done with someone to watch screen.
I am here to help you and I have over 30 years experience with all kinds of TV sets.
Is black and white picture somewhat YELLOW LOOKING?
iF THIS INFORMATION TOLD YOU SOMETHING YOU DID NOT know rate this solution as very helpful as I do this here for free.
If you have more information or need help comment here to this solution.
Aug 13, 2010 | Philips Magnavox 51MP392H Rear Projection...
Tv picture shrinks
This is a common problem on certain models of Philips Magnavox TV sets. The most common symptom is the screen will shrink and expand over and over. After the TV heats up for a while the video will work like normal. After a few weeks or months your TV will eventually stop working and not have video. You can get complete parts and instructions from
Nov 17, 2009 | Philips 9P6031C 60" Rear Projection...
TV turns off
Your Ballast Board could be problem Now, pull back off watch as Lamp trys to turn on if there is a Spark coming from Ballast Board Lamp is Defective, If No Spark problem is in Ballast Board.
Sep 21, 2009 | Samsung HCM5525W 55" Rear Projection...
Rca 32 inch tv
this is a frame fault
the fact that you can still see the line when the tv is off is because you have been watching with the line and it has burnt into the crt.
time to buy a new tv
Sep 04, 2009 | Sanyo DS24205 24" TV
Philips 27ps55 s321 tv remote problem
bought a new universal remote control of phillips
Jul 05, 2009 | Philips 27PS55S 27" TV
Turns itself off
screen control. pict to bright. normal to shut down. when this happens. ****** screen control.
Nov 19, 2008 | Zenith B25A10Z 25" TV
No Picture Has a bright horizontal line with off white & gray vertical bars
The Problem Philips 27TS54 c101 27B800-7562 White horizontal line in the center of the screen. Color is present in the first half inch of the leftist corner of the horizontal line.
Audio is present and controllable. The green power led from a cold non plugged in state remains solid until CRT goes to ignite. A click is heard then the green power LED blinks.
I found service manual diagram of repair part or parts and install instructions
I request any info or tips you might have pertaining to this problem
P.S. 25”-27” CRT board APT187
Possible Answer Posted by PEE_WEE 4/28/2005
On the CRT circuit board(picture tube), you will find R3340, which is a 10 ohm 1/3w resistor. The location of the resistor is printed on the bottom of the ckt board. It is burned open, replace with a 10 ohm 1/2w resistor. This will solve your problem. The original resistor was sized too small, should have been a 1/2 watt. This resistor is mounted standing up on ends. Mount the replacement resistor the same way. Be careful and don't get the circuit trace too hot and damage the circuit trace. (it's very small) The resistor is located on the crt(cathode ray tube), pcb(printed circuit board) socket. The resistor supplies apx +200v to the collectors of the r, g, b, video driver transistors. If this voltage is low, it causes excess brightness(excess beam current), causing the set to "shut-down". If the shut-down is too quick, you will NOT see the excess brightness, because the picture tube has not warmed-up enough to display anything on the picture tube. To see if the set displays "excess brightness", you will need to turn the set "on" about 5 to 10 times. This will heat the picture tube enough to display "excess brightness", IF that is the PROBLEM. Of course, there are OTHER defects that will cause a tv to shut down. There are built in safety circuits, that will "activate" if excess voltage/current or heat is detected anywhere in the set.
My resistors are not numbered the same on my crt board APT187. GSM 02/20/2008
Dec 31, 2007 | Samsung TXK2754 27" TV
21PT3324/71 Philips TV wont stay on
Try this: On the flyback transformer, raise the SCREEN voltage. There are 2 controld on the flyback - the top one is FOCUS and the bottom one is SCREEN. As the tube ages its emission decreases, and the computer monitors the tube's emission. When the emission gets to be too low, the computer shuts the set down. This is exactly like IK blanking in Sony sets, except Sony blanks the video and Philips shuts the set off. To set the screen voltage properly, turn the brightness and contrast to 0, raise the screen voltage until you see the white retrace lines in the picture, and then back down on the screen voltage until just past the point where the retrace lines are gone. Reset your brightness and contrast and the set should play fine.
Aug 13, 2007 | Philips 20PT6441 20" TV
Philips Magnavox 32PS55S 32" TV Logo
305 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
