Question about Microsoft Windows Vista Ultimate Edition
Error says cannot find c:windowsweb ip3.gif - Microsoft Windows Vista Ultimate Edition
Posted on Jul 11, 2009
How do I sync my iPhone 3 with Motorola TZ710?
you can't sync them, but if you hook the iP3 to your computer via usb you can open it as a hard disk and drag all the files to the Motorola
Mar 15, 2014 | Cell Phones
Tip
Following your instructions I was able to get the device, IP3 wiped clean....
I recently learned that RECOVERY MODE and DFU MODE are totally different. For that reason, I actually wanted to edit the title of this tip, but unfortunately, I can't, so I'm gonna write it here instead.2dd2296.png
This instruction will guide you in putting your iPhone / iPod touch to RECOVERY MODE, NOT DFU mode because apparently, you'll know that your device is in DFU mode, only if your computer recognized that there is a USB device connected to it but you don't see anything in the screen of your device.2dd2296.pngPLEASE, TAKE NOTE OF THE CORRECTION. For instructions on how to put your device to DFU mode, CLICK HERE. For more detailed comparison, read from BigBoss' site.2dd2296.pngProcedure:
  1. While ON, plug your iDevice to your computer, it doesn't matter whether iTunes (on your computer) recognizes your device or not, just plug it in2dd2296.png
  3. Hold the POWER button (only button on the top-right corner of your iDevice)2dd2296.png
  4. After just a second (literally, 1 second), press and hold the HOME button (only button on the face of your iDevice) and keep holding both buttons for about 10 seconds.2dd2296.png
  5. Release ONLY the POWER button and keep holding the HOME button for another 15 to 30 seconds longer, or until you see this image:2dd2296.pngb82dbe8.png
This means your device is already in RECOVERY MODE and iTunes will recognize. This also means that you can restore your iPhone and make it operational again. But be warned though that restoring will wipe out all data in your iDevice, as if it's fresh from the box.2dd2296.png
But, if your iDevice is DISABLED, you must put it to DFU mode first before you can restore it. For instructions on how to do that, CLICK HERE.
Other tips:
JAILBREAK
http://www.fixya.com/support/r8764632-jailbreak_ios_4_2_1_all_idevices_iphone
UNLOCK
http://www.fixya.com/support/r5537989-unlock_iphone_4_3gs_3g_or_older_ios
on Feb 16, 2010 | Apple iPhone Smartphone
The Ink Absorber is almost full. Press the printer RESUME button to continue printing
There is a consumable called an Ink Absorber. It will need to be replaced very soon. Contact your manufacturer or store where you bought it to get a new one. Once it is full, the printer will no longer work. Check your manual for more information.
Feb 02, 2010 | Powerleap PL-iP3/T 1300C (PLIP3T1300C)
Already have a lexmark x4270. can't recieve a fax?
Chances are you'll find your problem under 'fax settings' or a similarly titled option on the display. If you have it hooked up a computer as well you're in luck, most come with software that has an option labeled 'fax setup wizard' or something similar. Just follow the steps in that or call customer support at the following link to be walked through every step.
http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:439:0:0
Lexmark Customer Support: cb_transparent_l.gifus.gifspace.gifspace.gifarrow.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gif1-800-332-4120cb_transparent_r.gif
Jun 26, 2009 | Office Equipment & Supplies
AM NOT ABLE TO SYNC OVER PICTURES THAT IS ON COMPUTER OVER TO MY MP3
Are your images .gif or .jpg format?
To reformat your images open them in whatever program you prefer and click Save As and either type in the name followed by .jpg or .gif or under the naming bar there should be another bar indicating format. This should be a drop down selection box. select GIF or JPG.
Apr 12, 2009 | GPX ML648B MP3 Player
Can't save gifs
I had the same problem and googled a few forums with zero results.. so i found out what the problem was atleast for me... same error message when you try to save a GIF file "Unable to finish GIF Optimization process" What you need to do is this.
When you click on the Optimize tab you will get the same message again.. so click ok.. then at the very top second to the last icon is the Optimize Panel.. Click on it so the Optimize Panel comes up... then click on the Locate Palette tab.. and tic the "Preserve Local Palette" then you need to also tic the "Local Palette for all frames" once those two options are checked.. you will be able to save GIF files and the error goes away.. atleast for me this is what solved my problem..
Good Luck
Jan 30, 2009 | Ulead GIF Animator 5.0 for PC
ASUS m2n32 won't allow me to go into setup; shuts down...
Try to reset your BIOS by removing the button cell located at your motherboard and put it back. Check the SATA connector of your hard drive and make sure it fits right. Boot the machine and set-up to "boot from CR-ROM". And install new WINDOWS XP.
Jan 04, 2009 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
Error (-48)
Error(-48) is somekind of hardware communication error. The easiest way to fix it will be to flash the firmware. Here's how to do it.. It will take a while(around half an hour) but its worth it and will also improve the sound clarity of your phone.
What u need :
1) Motorola Driver
2) RSD Lite or Flash&Backup 3
3) Monster Pack(Flash update for(Lseries including SLVR)
Firstly you need to backup all your files that stored on phone memory because it will delete everything in your phone when you flashing.
Start RSD Lite and let it connect to your phone. If your phone is not detected (and you are certain you have everything installed), disconnect the data cable, then shut your phone off, and manually put it into bootloader mode. You do this by pressing and holding down the "*" and "#" keys while pressing and holding down the on button until you see text display on your screen. Now connect the phone back to the data cable. Now click the button labeled "...".
http://www.hackthel7.com/gif/flash1.gif
This will bring up the open file dialog box. Find the file you want to use (in this case select your monster pack file) and then click the button labeled "Open".
http://www.hackthel7.com/gif/flash2.gif
Click the "Start" button. Now you should see various messages displayed on the screen as the program processes each code group and does various other things.
http://www.hackthel7.com/gif/flash3.gif
This is what the phone will display during a flash:
http://www.hackthel7.com/jpg/upgrade.jpg
After it's finished and your phone has given you a confirmation tone, you can click "Close" and disconnect your phone from the cable and check out your changes.
If you should get a message like this where the program seems to hang:
http://www.hackthel7.com/gif/flashstuck.gif
OR
http://www.hackthel7.com/gif/flash4.gif
Don't panic. Just close the program, chance are your phone is just fine. Sometimes this happens. This is usually caused by a checksum error. There could be more serious cases where you phone appears dead. In this case try to reflash your file again. You could also try reflashing another file.
Sep 30, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Billing Server
Use an IP3 NetAccess instead http://www.ip3.com
Aug 28, 2007 | Nomadix AG-5000 (9621000001) Firewall
NOMADIX AG5000
Aug 10, 2007 | Nomadix AG-5000 (9621000001) Firewall
Microsoft Windows Vista Ultimate Edition Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
