Question about Kenmore 42800 Stainless SteelCooktop
Kenmore Elite 36' induction cooktop. After experiencing erratic performance such as the unit turning itself off and finally crapping-out permanently, had Sears come in. Repair tech couldn't solve the problem, but did find a fused "communicator cable" that was apparently installed over one of the heating pads. It was also noted that the cooling fans may not have been operating. Other than to recommend replacing a $1200 circuit board -- with no guarantee that it would fix the problem -- I had no option since the unit was just out of warranty and the cost of the repair would have been over 50% of the original purchase price. I realize that the unit (less than a year old) was produced by Electrolux, but have been unable to get any contact info to report my dissatisfaction with the manufacturer.
SOURCE: error codes 10 12 16 on kenmore induction cooktop
We purchased a 36" elite model on ebay for our house we are building. I finally installed a year later only to have error codes 39 & 40. I completely dissasembled it and put it back together. No luck. However after much searching I found the service manual for the 36" Icon by Electrolux (same manufacturer as the Elite). The guts look mostly the same. Manual states your codes 10 16 12 are for defective key sensors. I found out that on my cooktop if I held a key for maybe 20 sec or more it would beep once - indicating the key was not defective.
Link for manual on web site appliancejunk. com is below
http://appliancejunk.com/forums/index.php?action=downloads;sa=view;id=270
Posted on Dec 05, 2009
e-Guru
  • 3917 Answers
SOURCE: reassembling a Kenmore 30 in. induction cooktop
The best way to understand how its installed would be to check out its user manual. Since you have not provided the exact model number I was unable too narraw it down to help you with correct manual. But please click on the link bellow to download the appropriate manual:
http://www.hammerwall.com/Manuals/Kenmore/9-36/Lookup/Home%20Appliances/65/
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Posted on Apr 06, 2010
  • 157 Answers
SOURCE: Electrolux induction cooktop shuts off and won't turn back on
There is an internal thermal circuit breaker. The breaker has gone bad. On-line of Electrolux find a service manual of your model to locate the breakers location. Contact a local appliance parts store for a replacement also ask for heat sink gel(very small amount). Trip the circuit breaker, remove bad one, clean the space, apply gel and replace it.
Posted on May 14, 2010
SOURCE: Kenmore Elite Induction Cooktop Error Code 41
I realize this is over a year old. I have the same unit with the same error code. Last night, mine made a popping noise followed by smoke and then displayed the 41 and all E's. I pulled the breaker immediately. I'm sure that at least one controller board is toast.
I called Sears and it is under warranty but for parts only, so I guess I will give them a call and schedule the repairman. This should be fun.
Anyone else experienced this failure??
Posted on Jul 16, 2010
SOURCE: kenmore elite 36'' glass top cook top beeps and displays eo 11
so does mine
Posted on Oct 02, 2010
Prestige induction cooktop showing error E4
Good Afternoon friend, I appreciate your inquiry!
Typically on an Electrolux induction cooktop the "E4" error code stands for key sensor for timer. Which means you could be experiencing an issue with the right board, center board, or left board. I would perform a reset on your cooktop and you can do that by flipping the household circuit breaker off for ten minutes.
If that does not assist with clearing any false error codes or the error "E4" continues to display I would suggest seeking assistance from a professional for proper diagnosis and repair. Hopefully this helps. -Matt
Oct 18, 2014 | Electrolux 36" Electric Hybrid Induction...
Wiring for Kenmore Elite Induction Cooktop
The white one may just form an earth loop,, I recently had a ceramic plate needing cleaned so we did the whole lot, I think most hobs have 4 wires and they are numbered rather than colour coded..hope this helps
Nov 10, 2013 | Kenmore 30" Induction Cooktop Stainless...
Induction error e6
Hello it07002 - You may try and reset the induction cook top by disconnecting the power to the unit for up to 30 seconds by flipping the circuit breaker off and back on. This often clears most false error codes. If the error code does not clear, then the unit more than likely may be experiencing an issue with the EOC (Electronic Oven Control) and/or user interface board. This is not a typical do it yourself job; please consult a professional or your manufacturer.
May 07, 2013 | Electrolux 36" Electric Hybrid Induction...
My electrolux iduction cook top sends error across the whole bord when I put anythng on the inductoin burner
You may try and reset the induction cook top by disconnecting the power to the unit for up to 30 seconds. This will clear most false error codes. You can disconnect power by flipping the circuit breaker off and back on. If the error code does not clear, then the unit more than likely can be experiencing an issue with the EOC and user interface board. This is not a typical do it yourself job; please consult a professional or your manufacturer.
Sep 11, 2012 | Electrolux 36" Electric Hybrid Induction...
Replace fan switch on ge cooktop profile
I agree completely with imaginus2000. GE Profile is junk. Came with the house we bought so had no choice there. As soon as it craps out it will be sent where it belongs. The scrap yard!
May 26, 2012 | GE Profile 36" Electric Induction Cooktop...
Reassembling a Kenmore 30 in. induction cooktop
Apr 06, 2010 | Kenmore 30 in. 32384 / 32385 / 32389 Gas...
Feb 01, 2009 | Kenmore 42800 Stainless SteelCooktop
Error codes 10 12 16 on kenmore induction cooktop
Oct 10, 2008 | Kenmore 42800 Stainless SteelCooktop
Kenmore 42800 Stainless SteelCooktop Logo
479 people viewed this question
Top Kenmore Cooktops Experts
Kolbrun...
k24674
ka4iup
ka4iup
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
