Question about Olympus FE-170 Digital Camera
It doesnt turn on because i got sand in it! - Olympus FE-170 Digital Camera
How did you find out?
Posted on Jul 11, 2009
Hayward sand filter allowing dirty water to come through
1) Make sure that you have thoroughly backwashed the sand.
2) Make sure your chemical balances are correct
3) Remove filter canister top valve and insure that it was properly seated on the filters canisters center pipe.
4) Remove all sand from the filter canister
4) Clean all components thoroughly
5) Check for cracked laterals or plumbing
6) Repair or replace any bad or missing components
7) Reassemble
Tip: carefully use a rubber mallet to seat the canister valve by lightly tapping on and about the circumference of the valves seat.
Hope this helps,
https://www.oskopoolnspa.com
Jul 09, 2015 | Hayward SAND FILTER, PRO SERIES
How do you know if your hayward s 200 is not running right
sand in your pool is a sign that you may have damage inside your sand filter. it is not uncommon for laterals to break during winter months. also, as the sand wears, it becomes smaller and may pass through.
remember that the filter sand is white. if you have sand in the pool that doesnt look like filter sand, you may have a problem with a broken line back to pool. keep an eye on your water level as you will lose water with this scenario
May 07, 2014 | Hayward Pool & Spa
When does my filter sand need replacing
most manufacturers suggest replacing the sand every 5yrs. when the corners wear off, the sand rounds and doesnt catch debris. it also packs faster.
if you are having short intervals between backwashing, it is a solid indication that sand needs replacing
Dec 29, 2013 | Hayward 3/4hp Super Pump Inground Pool...
Pool pump pressure
check to see if filters are dirty if using a sand filter or DE filter put multiport on recirculate which will bypass a dirty filter if sand filter is the problem change sand
Dec 16, 2013 | Universal Kreepy Krauly In-Ground Pool...
My carrousel doesnt sping right the pully and whindup mecanism doesnt spin right what should i do
The instructions tell you to sand the gears and apply lacquer. I used a dremel tool to sand the gears and bought spray lacquer for the gears. Perhaps that will help.
May 23, 2011 | Wrebbit Enchanted Carousel Wrebbit 3-d...
Replaced sand now filter isnt working
if u used play sand, or any other type of sand thats NOT pool filter sand, that could be the problem. also if there is too much sand or too little sand that could also cause this.
Jun 08, 2009 | Hayward Pro Series 18" Above Ground Pool...
My sanyo camera turns on then just turns back off.
If there is sand or grit in the mechanism, then it will be uneconomic to repair it. Replace it, and be more careful in the future - sandwich bags are a useful invention.
Aug 06, 2017 | Sanyo VPC-S880 Digital Camera
Samsung L730 wont extend lens and dosent turn on right
Met the same problem. I disassembled camera and found a lot of sand in lens transmission. I couldn't move lens even by hand. It was strongly jammed. I had to disassemble lens block completely to remove all sand. Now camera fully functional.
Dec 15, 2008 | Samsung Digimax L730 Digital Camera
Lens error
you need to send this to a repair shop, for immediate cleaning, sand can practically stucked in betweeen mechanical parts and cause binding
Jul 25, 2008 | GE A730 Digital Camera
Olympus FE-170 Digital Camera Logo
89 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
