Question about Kenmore Dryers
Kenmore Gas Dryer won't heat!
I have a kenmore evenheat gas dryer, model # 110.73932102.
it runs but does not heat. I replaced the following parts already:
• High limit Thermostat
• Thermal Fuse
• Thermistor
• Fabric Care Temperature Switch
After all of those parts were replaced I was getting the ignitor to glow red, then the gas to turn on and would run for about 1 minute and then shut off. I noticed that as soon as I could not keep my fingers on the exhaust pipe it would shut off (it would get too hot).
I went to the sears parts store and they were baffled. They suggested I test and replace the following parts:
• Both Coils
• Flame Sensor
I replaced both and now the gas does not even come on. I first noticed this after I replaced the coils. I put the old coils back on, still nothing. Then I replaced the Flame Sensor.
I'm about to buy a new dryer at this point. Just bummed that I've sunk so much time and money into this already.
PLEASE HELP! My wife is getting very frustrated as well.. :)
ps - about 2 years ago I had to replace the Thermal fuse and it did the trick.
  • 2 more comments
  • jeremyjjw Jul 11, 2009
    i've already replaced the Thermal Fuse. Still no luck.
    I might have switched the wires when I replaced it - can't remember how it was on there. I've tried it both ways and it didn't seem to make a difference. Currently I have the red wire on the left and the red/white wire on the right.
    I've throughly cleaned all the vents and am running the dryer now with the back vent unattached.
    still no dice.
    still no dice.
  • jeremyjjw Jul 12, 2009
    still no dice.
    still no dice.
  • 3,741 Answers
On the back of the dryer near the fan blower housing is a thermal fuse, if this opens up ( no continuity ) the gas burner often quits but the motor will still run. If the thermal fuse is open/bad, always clean, change, adjust the venting system and vent hood first and clean out the dryers air ducts. Sometimes it is a good idea to replace the operating thermostat at the same time.
Thermal fuse parts help link...on blower housing cover, can not be re-set, must be replaced if is open (no continuity between pins).
Posted on Jul 11, 2009
  • charlymonty Jul 15, 2009
    at present in whiuch way you hAVE connected the wire is a proper way.red on the left and red/white on right side its perfect.may be the wires are gone short.try connecting it with new external wires and check out.
I have A kenmore elite gas dryer model # 110.75062501 it won't heat please help
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;'
Jul 18, 2011 | Kenmore Dryers
Kenmore Gas Dryer 11072212101 won't heat. we
heatman101.,/
Jun 30, 2011 | Kenmore 73102 Gas Dryer
Ovendoor will not lock on self clean mode
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 07, 2010 | Kenmore 73952 Gas Dryer
Kenmore dryer, the dry runs, but does not heat
heatman101
Jun 11, 2010 | Kenmore 63942 Dryer
Kenmore 84072 dryer runs doesn't heat
heatman101
Jun 06, 2010 | Kenmore 84072 Electric Dryer
My dryer (kenmore elite model 110.64992300) wont heat
heatman101
May 26, 2010 | Kenmore 64992 Electric Dryer
Kenmore 70 series gas dryer - does not start when pushing the start button
heatman101
May 19, 2010 | Kenmore 77632 Gas Dryer
Kenmore Dryer 65512 won't heat
heatman101
May 14, 2010 | Kenmore 64742 Electric Dryer
Kenmore Model 110.76912691 gas dryer that heats intermitently
Replace the solenoids on the gas valve. These are often intermittent befor total failure. Hope this helps!
Feb 26, 2009 | Kenmore 63942 Dryer
Dryer will not run
Is your dryer an evenheat dryer? It will say evenheat above the timer. Can you give me a model #? The problem is either an evenheat board or a heat relay. Relays cheap, boards not. Easy to fix. Let me know. thanks Dave www.washermd.com
Dec 16, 2008 | Kenmore 72972 Gas Dryer
Dryers Logo
190 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
