Question about IBM ThinkPad T23 2647 Notebook
Hp pavilion dv 2000 computer boot, screen up but not visible/bright. The mouse pad screen button stay in yellow glow
When I plug in the charger into HP pavilion dv 2000 it charges but when I press on the power button then the power button light stays for some seconds and go off with the charging light too off.
TAKE OUT THE BATTERY!!
JACK POWER PACK IN TO THE WALL
WORK NOW
DOES BIOS SCREEN GLOW , ON DEMAND.
SEE THIS, F1, F9,F10 KEY WITH POWER
ON YES, THEN POWER IS GOOD
IF THE POWER WILL NOT WORK, WITH NEW POWER PACK, AND BATTERY OUT,
THERE ARE SHORTED PARTS INSIDE THE LT
MY GUESSING Would be silly,
Mar 01, 2017 | HP Computers & Internet
My mouse vertical scroll not working. my laptop model HP-Pavilion dv 5
Download and install touch pad driver from hp website probably your touch pad driver is Synaptics.
Aug 27, 2011 | HP Pavilion dv5000t Notebook
My mouse is frozen on my hp dm4 and the orange light in the left hand corner is not on, nor will it turn on when double tapped
First thought is look at the top of the touch pad, there is a button. Push this button once and see if the mouse works. HP put this button on to deactivate the mouse if needed.
If this does not work, plug in an external mouse and see if it works, if not do a hard boot on the computer and try the mouse again.
Jul 20, 2011 | HP Pavilion dv6000z Notebook
When my new hp mouse pad locks, how do i unlock it without restarting the computer?
There should be a button above the pad or work your way using the keybord to mouse properties and go to the page that has the name of your track pad and select enable.
Mar 01, 2011 | HP Pavilion dv7-1020us Notebook
Hallo. The screen of My laptop HP pavilion dv 2000 is
on the boot sector when you switch on youe computer, please press delete or f8 repeatedly. if there is nothing showing on your screen., then you should know that the is a problem with youe laptop scree.
i advise you to go and see a computer sepcialist to check if it is your hardware that has a problem.
thank you,
wonder
Sep 18, 2009 | HP Pavilion dv2000t Notebook
Plese help my hp pavillions dv 2000 aint workin write....
vga chips problem need to open then fix the board.
Jul 13, 2009 | HP Pavilion dv2000t Notebook
No image on monitor
Looks like the Video card, or Video chip has bought the farm
Try hooking up to another monitor to confirm where the problem is.
Jan 30, 2009 | ViewSonic VX922 19" Monitor Flat Panel
Left mouse button on touch pad not working
have u tried to check it on the control panel/mouse options.
if its not working though i guess the have reason about that.
Dec 30, 2008 | HP Pavilion dv4000 Notebook
My Hp Pavilion dv4000 screen stays blank
have you got a bootable cd or recovery cd , boot from it and do a fresh installation, i think your windows has got corrupt
Nov 05, 2008 | HP Pavilion dv4000 Notebook
Pavilion dv 1000
hook up a extrenal mouse and see if it still does it. If not, get into windows and check your power save options and make sure its not going into standby. Windows defaults to Three minutes on laptops and it may be going into standby.
If it blanks out with all the lights still on, try pressing the power button once and see if it comes on to where it was before. If it does, its going into power save.
These options are in the display settings which you find by right clicking on the desktop and selecting properties in the little box, it will open a box with tabs. click on the screensaver tab and at the bottom it has a button for power options, click it and change settings accordingly, also make sure the screen saver isnt set to come on after like a minute, usually you want it for 5-10 for a laptop and you only want power save options set for when its on battery power.
Also make sure that it doesnt have it set to go into standby when you close the lid.
Mar 30, 2008 | HP Pavilion dv1000 Notebook
IBM ThinkPad T23 2647 Notebook Logo
111 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
