Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
The water wont go up the hose to my ice maker
  • 672 Answers
If this is a new install, there is a valve, either in the basement or crawl space below the refrigerator. This valve may be shut off, or the tray full arm is in the(up) off position.
Posted on Jul 11, 2009
peyton32034
  • 410 Answers
SOURCE: Maytag ice maker wont fill upwith water
is the icemaker cycling at all? pull the front cover offf of the icemaker and verify that the gear isnt broken. if so replace the motor module. if thats ok the next 2 things could be either a frozen fill tube or bad fill valve..
Posted on Dec 12, 2007
SOURCE: ice maker wont make ice
It is quite possible that the water line which feeds the ice maker is frozen. Whirlpool manufactures a "REPLACEMENT" water line that solves this problem. Fortunatly our problem occured while the refrigerator was still under warranty. I would suggest that anyone owning a Whirlpool product purchase the longest extended warranty available! They USED to manufacture a quality product. But I guess they just don't care about the consumer any longer. It is all about money!!
Posted on Dec 20, 2007
  • 90 Answers
SOURCE: ICE MAKER
sounds like icemaker not turned on
Posted on Jan 06, 2008
  • 3 Answers
SOURCE: Ice maker issues
Replace the Motor Module on the ice maker. I had the exact same issue.
Posted on Aug 05, 2008
SOURCE: roper ice maker
My ice maker was making ice just two days ago after being off for a while. I am a new tenant. I made one basket full of ice, which I dumped to make sure the system and water was flushed thoroughly. Now the ice is just stuck there, you can see the cubes but they aren't going anyway. I try to gently force them out, but no way, they aren't budging! So, how do I eliminate this problem?
Posted on Oct 06, 2008
Water wont go to ice maker but is making water
check to see if hose behind top of frige is kinked ice maker wont work if frezer is higher then 0
Jan 23, 2014 | GE Refrigerators
Ice maker dont work
There are several things that can prevent and icemaker from working.
1- Temp in freezer. If the temp in the freezer is higher than 6 degrees the ice makers thermistat will not call for water.
2- Water inlet valve. If the inlet valve is malfunctioning the silinoid may not be opening. Even if you are getting water through the door.
3- Faulty ice maker. If the internal components of the ice maker are no longer functioning it wont make ice.
To test the inlet valve. In the back of the fridge is and access panel near the bottom remove this panel and look at the inlet valve. now you should see 3 hoses. One is usually copper and runs directly from the house water supply. There will be two other hoses from the inlet. One leads into the fridge for the water in door feature. The other is for the icemaker. Switch the two hoses from the ice maker ( water in door and icemaker) than push the water in door feature and see if the water goes into icemaker. If it does not than replace inlet. If does and temp in freezer is below 6 degrees replace icemaker.
If you need further assistance please comment me back.
Jul 30, 2011 | Kenmore 53642 / 53644 Side by Side...
Ice-maker does not work. water valve seems to be working.
There are 3 things that can prevent an ice maker from not working.
1- Temperature of freezzer- Temp must be below 6 degrees on most ice makers.
2- Water inlet valve- Depending on how your ice maker cycles it calls for water for 7.2 seconds. If you have ice and water though the door you have a dual valve and the ice maker selinoid ine the inlet may be bad. Also make sure water is getting to valve. Just because water is coming through the door does not mean water is entering fridge. There is a reservoir in fringe that holds around 3 gallons of water that can still make water come out the door without water entering fridge.
3- Faulty Ice maker- over time the winding and other components can get worn out and fail.
First check the temperature in the freezer.
Next check the inlet valve. To do this you need to remove the hose going from the inlet valve to ice maker and switch with the hose leading to door. Push the actuator in the door to call for water and see if water enters the ice maker. If it does inlet is good. Replace Icemaker. If not replace inlet valve. There may be a problem with the icemaker still but wont know until inlet is fixed.
If you have anymore problems or you need further assistance please feel free to contact
Jul 19, 2011 | Kenmore Refrigerators
I have a model GSS22UFMDWW and the ice maker motor is freezing up and wont turn the screw to dispence the ice. I have removed the assembly and let the motor thaw and dry, replaced it and in about a week it...
Check the water inlet line to the icemaker. could have ice built up in it making it spray all over. Also it can be in the wrong position(water inlet hose). Make sure there is no air in the line from say it being a new fridge or a new water filter can interduce lots of air.
The air makes the water come out all over.
Get the ice maker to cycle and watch it and see how the water comes out. If its putting out too much water then water valve is issue. If the ice maker doesn't drop the ice out then its the ice maker.
Jan 31, 2011 | GE Refrigerators
My water dispenser and water to ice maker isn't working. any suggestions?
my monogram ice maker wont make ice. it is on, the water fills the pan but thats as far as it gets. the area is cold. the hoses appear open. i have cleaned the dust of the compresser. what else can i do before i call the repair man?
Jun 15, 2010 | GE Monogram ZISx420DR 42-inch Side by Side...
My refrigerator (frigidaire plhs269zdb9) wont make ice.
A common cause for a clog is frozen water in the line.There is also a possibility that the water filter for the ice maker is clogged.Locate and replace the water filter. Filters for ice makers are typically located inside the refrigerator (to keep them from freezing).
Dec 28, 2017 | Refrigerators
maybe bad ice maker or water valve. start whit the cheapest. water valve.
Apr 02, 2010 | Refrigerators
Water in door but no ice?
there is no pump, just water psi from your house.
check inlet valve to ice maker/water float
Sep 07, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Ice maker isnt making ice
Be patient.
See if you still have this problem tomorrow.
Mar 31, 2009 | Kenmore Refrigerators
Hose comes off back of the refrigerator going into ice maker
you have a clog.you need to remove ice between hose going in to freezer and where water comes thru to ice maker
Mar 05, 2009 | Refrigerators
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
139 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
