Retail Supplies Logo
s
san juanita navarro Posted on Jul 11, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i get the numeric keypad to work
I cant get the numeric keypad to work and add up sales . only the programmed numbers work
Electroboy
Level 3:
  • Retail Supplies Master 1,888 Answers
  • Posted on Jul 11, 2015
Electroboy
Level 3:
Answers
1888
Questions
Helped
675259
Points
3733
Brand and model? Are you using PLUs or departments?
How do I type accents on a laptop without a secondary numeric keypad?
In order to type accented characters, you'll need to know the ASCII code of that character. You can check that out in the character map. This can be accessed in the following way:
  • Click the Start button
  • Click All Programs
  • Clicking Accessories,
  • Click System Tools
  • Click Character Map.
Once you have the character map open, you can just highlight the character that you want, and the ASCII code will be displayed on the 'Character map' window.
In order to insert the character, go to the textbox where you need to insert it, hold down the 'Alt' key on the keyboard and type the number on the numeric keypad.
In case of a laptop, you'll need use the numbers on the numeric keypad. But there's no separate numeric keypad on a laptop, instead, the numbers are arranged on the same keys as the letters. They're separate from the numbers on the top line.
I replaced Refrigerator Electronic Control hv board and I can't program it successfully? DOthe doors need to be open to program?
1. Open the Fresh Food door and press and hold the Door Alarm keypad DoorAlarm .
2. Press and hold Refrigerator Temperature UP keypad .
3. Release the Door Alarm Keypad DoorAlarm and wait 3 seconds.
4. Press the Refrigerator UP Keypad again.
5. Display will show 001 in left display and numeric or dashes in right display.
6. Press Freezer Up keypad and Freezer Down keypad to toggle through Service Test numbers
The numeric keypad on the Satellite C655 is not working. Cant type in numbers on word or excel. Can you help
it may just happen that your numeric keypad is turned off. See if the Num Lock is On (should be above the 7-key)
1helpful
My function key is on and i cant figure out how to turn it off
To use the embedded keypad
After pressing Fn+F8 to activate the numeric keypad, you must press the Lock key
(in the top row of the keyboard) to turn number lock on or off.
When number lock is on:
• Keys change to the numeric or arithmetic designations printed on the right side of the
keys in the numeric keypad area.
• The Num Lock status indicator is lit.
• To turn off the embedded keypad, press Fn+F8 again.
For further reference of usage of Function keys, check the HP manual:
http://h10032.www1.hp.com/ctg/Manual/lpi05379.pdf
Page number: 30/141
Regards,
Nags
Cant get the at button to work even by pressing shift or not,every other key function works.
You may have a bad key, or a key with something under it.
Try this:
Turn the netbook upside down so that the keysj face the floor.
Bang on the back side that way you would to burp a baby.
Then, take a vacuum cleaner and **** out the spaces between the keys.
If this doesn't work, you may have to make an @ symbol manually by using the ALT key. (ALT plus 64). This should work in most Word Processing programs.
  1. Make certain that the Num Lock key has been pressed to activate the numeric key section of the keyboard.
  2. Depress the Alt key.
  3. While the Alt key is depressed, type the proper sequence of numbers (on the numeric keypad) of the ALT code from the table above.
  4. Release the Alt key, and the character will appear.
  5. On a laptop computer, there usually is no numeric keypad. So, instead, depress the Fn (function) key, then the Alt key, then the numerical code sequence. The numbers are on the fronts of certain keyboard keys: M=0, J=1, K=2, L=3, U=4, I=5, O=6, 7=7, 8=8, and 9=9.
http://www.tedmontgomery.com/tutorial/altchrc.html
1helpful
2answers
British Pound symbol
If you have Windows XP, click on Start, Programs, Accessories, System Tools, and choose "Character Map" - you should see and be able to copy the symbol to the clipboard you need from there.
Good Luck!
18helpful
5answers
Keyboard letters 'm,j,k,l,u,i,o' permanantly locked for numerals. i have no idea how i switched this function on.
NumLock is on. Look for the Fn key in the lower left corner, and lookint in the top right, the NumLock key.
Group code
I believe what you want is at the bottom of this list.
If you frequently send faxes to the same group of telephone numbers, you can assign these numbers to a group.
Only Speed Dial and One Touch numbers can be assigned to a group. A maximum of 25 Group Numbers (WorkCentre Pro555) / 50 Group Numbers (WorkCentre Pro575) can be assigned (in the range 1-1999). Preset group numbers can also be used for polling.
The following information is included below:
  • Create a new group
  • Add numbers to an existing group
  • Delete numbers from an existing group
  • Delete an existing group
To print the Group Phonebook, see the Related Items below for additional information.
Create a new Group:
  1. From the Standby Mode, press the [Menu] (up arrow) button on the Control Panel, then press [3], [3].
  2. Use the numeric keypad to enter the Group Dial number (1-1999) you want to assign to this group.
  3. Press the [Enter] button. The screen will display a name.
  4. Use the numeric keypad to enter the Group Name (20 characters maximum), then press [Enter].
  5. Press the One Touch button you want to include in this Group, or enter the Speed Dial number, then press [Enter].
    NOTE: The One Touch and Speed Dial numbers must already be programmed. See the Related Items below.
  6. Repeat step 5 to enter additional numbers.
  7. When you have entered each number you want to include in this group, press [Enter].
    NOTE: Group Transmissions are easier if a group is linked to a One Touch button.
  8. To assign this group to a One Touch button, press the One Touch button. To skip this step, press [Enter].
  9. Press the [Exit] or [Stop] button to return to the Standby Mode.
To add numbers to an existing Group:
  4. Press [2] to modify this group.
  5. Use the numeric keypad to enter a new group name, then press [Enter], or press [Enter] to retain the old name.
  6. Press the One Touch button you want to include in this Group, or enter the Speed Dial number, and then press [Enter].
  7. Repeat step 6 to enter additional numbers.
  8. When you have entered each number you want to include in this group, press [Enter].
  9. Press the [Enter] button.
  10. Press the [Exit] or [Stop] button to return to the Standby Mode.
To delete numbers from an existing Group:
  6. Press the One Touch button you want to delete from this Group, or enter the Speed Dial number, and then press [Enter].
  7. Press [1] to delete this number.
  8. Press [Enter] to delete the number, or press the [Exit] or [Stop] button to exit without deleting number.
  9. Repeat steps 5 through 7 to delete additional numbers.
  10. When you have deleted each number from this group, press [Enter].
  11. Press [Enter].
  12. Press the [Exit] or [Stop] button to return to the Standby Mode.
To delete an existing Group:
  2. Use the numeric keypad to enter the number of the Group you want to delete, then press the [Enter] button.
  3. Press [1] to delete the group number.
  4. Press the [Exit] or [Stop] button to return to the Standby Mode.
elem_1_spacer.gif Related Items:> See AlsoHow To Print and Read the Group Phonebook Report
> See AlsoHow To Modify the Default Resolution and Contrast Settings
> See AlsoHow To Assign / Modify Speed Dials in the Phonebook
Top Retail Supplies Experts
ADMIN Andrew
ADMIN Andrew
Ngoro
Are you a Retail Supply Expert? Answer questions, earn points and help others
