Question about Boating
1989 200hp evirude wont idle in water idels fine out of the water
1989 200hp evinrude wont idle in water idels fine out of water. Puts out about 12-1/2 volts acts like it is floding out. could it be the regulator just put a new stator on it. we cleaned carbs new fuel lines and bulb. runs great after you get took off out of an idel. thanks'
  • thomas foster
    thomas foster May 11, 2010
    have u changed the plugs? if not always change two stroke plugs first
  • 86 Answers
I would readjust your idle mixture screw with engine in gear and on the water at an idle. That is a common problem after rebuilding carbs. It will run diferently under a load in the water. Just tie up to the dock and adjust them there.
Posted on Aug 06, 2009
Engine wont rev when in neutral
take it to a service shop
I suspect that you put the new motor onto old fuel lines and the rubber on the insides of the primer and hoses has not broken down and is blocking the high speed jets or affecting the fuel pump valves
if it is fuel injected , the shop will be able to read the fault codes to find the faulty sensor
Aug 09, 2018 | Clymer Evinrude/Johnson 5-70 Hp...
Evinrude 60 hp tracker dies below 1100 rpm, will not idel. cleaned carbs. didnt help. runs great under throtle. compression on all 3 cylinders 121 to 125. why cant I get it to idel.
the idle circuit in the carby still has a blockage that is preventing it from allowing the fuel through
compression is good
possible that the ignition timing is not correct
at this point I would suggest that the carby be overhauled by a Evinrude service shop as rubber from hoses , fuel pump breaks down and fine particles get into jets and passages and block up the holes
Nov 21, 2017 | HP Boating
How to find year model on Aust evirude
1970 4 Hp with that info.
Mar 03, 2014 | Boating
My 2003 chryler seabring water pump went out i changed it got the car back together when i first start it in the morning it idels fine then when it warms up at stops the idle go's to 800 rpm or st
OK. Nothing to do with water pump.
Recommend checking your IAC (Idle Air Control) circuit. This allows air to bypass the throttle body while idling, at stop sign, etc.
Here are a couple of links that should help you
Chrysler Sebring Idle Air Control Valve
How To Install Replace Idle Air Control Valve 2 7L 2001 06 Chrysler...
Jan 28, 2018 | 2003 Chrysler Sebring
My mercury 35 hp outboard motor idle's fine but won't run
While at the river try to adjust the fuel air mixture. When you are on the water it puts the engine under a load and if that dont work then dont be afraid to bump up the idle stop screw slightly.
Aug 02, 2009 | Light Outboard Motor Boat Bass Fishing...
Evinrude outboard hard to start
If it is flooding then you need to remove the carbs and check your float level and see if your needle and seat are worn out. If you hold your carb upside down with the bowl off then your float should be level straight accross. If it is not straight accross then you can bend the tang by the needle until it is level.
Jul 28, 2009 | Boating
Boating Logo
282 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Bill Boyd
Are you a Boating Expert? Answer questions, earn points and help others
