Question about Amana Washing Machines
Forgot to remove shippping bolts before using machine.
My husband did not read the directions for installing an Amana front load washing machine. I feel damage may have been done because the shipping bolts were not taken out and the washer was used three times already. Is it ruined? Sales person told me it was and that I would need to get a new one. Help me.
    President:
  • 1,185 Answers
I would take out the shipping bolts and then run a prgram such as Spin.with no clothes in
If that sounds ok, wet a few towels and spin them dry
If that works put a full load in and go for it
Unless your machine was way out of balance you should not really have damaged anything.
The transit bolts are there to stop the drum from banging around during transit and unless they have torn free or have bent you should be ok
Posted on Jul 11, 2009
Whats so tricky about the repair?
Amana Washing Machine Parts - RepairClinic.com
www.repairclinic.com/Shop-For-Parts/.../Amana-Washing-Machine-Parts
Huge selection of Amana Washing Machine parts in stock. Same day ... A small leak in front of the washer could be caused by a defective pump. OEM Part ...
www.repairclinic.com/Shop-For-Parts/a11/Washing-Machine-Parts
Find your parts fast and repair your Washing Machine with our free repair help. ...Admiral · Amana · ARDO · Asko · Bosch · Crosley · Danby · E-Wave · Electrolux · Estate ..... A small leak in front of the washer could be caused by a defective pump..... Washing machine door lock and switch assembly for front loading washers.
How To Fix Front Load HE Washer Does Not Dispense ...
removeandreplace.com/.../front-load-he-washer-does-not-dispense-deter...
May 15, 2015 - HOW TO REMOVE WASHING MACHINE SOAP DISPENSER ...
Jan 10, 2016 | Amana Front Load Washing Machine Washer...
Amana front load washer how to clean water pump
remove the hoses and and remove the pump then use coat hanger to try to clean inside pump and try to turn propeller by hand depending on ur model some pumps cant be taken apart depending on either direct or belt driven ones
Aug 09, 2014 | Amana NFW7200TW 27-in. Washer Front...
Install belt on Amana top load washing machine
Use the correct sized belt!!
Loosen the Motor mounting Bolts. ( Do not take it off ) Now the motor assembly can be moved towards the opposite large pulley.
Replace the belt in this position and slide the motor to it's original position. You adjust it in such away so that, the belt is not too tight or loose!
Apr 05, 2010 | Amana ALW895 Top Load Washer
Brand new front Load GE washing machine stop at rinse cycle
Check that the Cold water valve faucet is open. Perhaps the earlier vibration problems have caused a wire to come off the water valve connections inside the machine.
Sep 30, 2017 | GE Energy Star WCVH6260F Front Load Washer
New front load Amana spins vilently and shuts down w/o completing spin cycle.
have you removed the transite bolts at the back of the washing machine and is it level and stable. hope this helped.
Sep 02, 2009 | Amana Washing Machines
Can't remove front panel on Amana washer
access through the back panel about 10 screws. Its likely the drain pump or one of its hoses.
Aug 23, 2009 | Amana ALW480DA Top Load Washer
While spinning; washer moves
if new did you remove shipping bolts,,,is the floor wood ,,or weak...did you set the log bolts on the legs,,,it sounds like you installed this your self..keep me posted onthejob
Feb 03, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front loader walking during spin cycle
Have you made sure that all the shipping bolts and stuff were removed? this happened with our Bosch and we found out we had kept three bolts installed that needed to be removed
Jan 12, 2009 | Bosch Axxis WFL 2060 Front Load Washer
LG front loader washer
YOU KNOW THIS MAY SOUND SILLY BUT THE INSTALLERS FORGOT TO REMOVE THE SHIPPING BOLTS. THANK YOU VERY MUCH FOR YOUR ATTENTION BUT I GOT IT SOLVED.
May 03, 2008 | LG WM-2277HW Front Load Washer
How to fix excessive vibration during spine cycle?
if your machine is new, and you self installed it, you forgot to remove the shipping bolt, for front load-check the back there are four long screw sometime three depending on the brand , for top load tilt ur unit take a look on the bottom- in the middle again depending on the brand they use a single bolt to hold the tub during transporting- remove it, slide out the spacer it will be ok. now if your unit is some years back already you have your problem with its transmission or gearcase for top loader-quite difficult to fix it sir, or suspension mechanism and bearing on front loader sir- u have to replace it or call a qualified service tech - happy washing soon sir
Apr 06, 2008 | Washing Machines
Washing Machines Logo
2,082 people viewed this question
Top Amana Washing Machines Experts
Sal De
Mike
Virgil Watts
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
