Question about Frigidaire FTF530FS Front Load Washer
THE DRAIN WAS CLOGGED IN OUR fRIGIDAIRE washer, so my hubby took it out and emptied it. Now the drain works great, but the washer wont spin. What have we hit or what do we need to reset to get it going again?
  • 132 Answers
If the sensor of water level still sense a lot of water , the m/c will stay in this position refuse to spin so go ahead and complet to solve the problem of drain i think it still untill now,check the drain filter it maybe clogged.
thanks
Posted on Jul 11, 2009
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Washer does not completely drain to allow for spin
The most common cause for standing water in a washer is a clogged drain pump. Another possibility is a kink or clogged drain tube. Below is a youtube video with instructions on removing a drain pump on most front load washers including your Frigidaire model. Best of luck and thank you for using Fixya!
Dec 26, 2011 | Frigidaire ATF6000ES Front Load Washer
Spin cycle goes very slow or doesn't work.
Hello, After looking at the User Manual for our Washer, E20 is an error code for the drain. It said that either the house drain line is clogged or the washer drain line is clogged. After my husband took the drain line off the washer, cleaned it out, we noticed that the lines had a lot of detergent build up and figured that this is probably the cause of the error code. We put the washer back together and it is working properly. We have always used the "he" detergent for the front loader and always used the proper amount; however, from now on, we will use less than the recommended amount.
I hope this helps some of you who are having this problem.
Thanks
May 19, 2010 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Washing machine will not drain the water??!?
Check the drain pump it may be clogged or not working. This is a common problem i have working at a camp with 15 washers.
Mar 26, 2009 | Frigidaire GLTF1670A Front Load Washer
Washer won't spin and drain
Sounds like your drain poump is failing. It's spinning lighter loads but not able to take a full load. I woule definately replace the drain pump,
Feb 28, 2009 | Frigidaire Washing Machines
Washer wont drain and spin.
There are a number of considerations cited in the user manual which you can get at this website http://www.frigidaire.com/support/ResultsPage.asp?strModel=ATF6000ES&User=
Drain hose is kinked or clogged,The house drain pipe is clogged or cannot handle the flow from the washer.. Your pump or the line entering it or exiting it is clogged..
Go to this website and download the parts document ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/5995464004.pdf Page 6 of this manual shows a filter (item 40) that protects the pump from debris.. That may be the root cause of your problem.. Hope this helps..
Aug 31, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire frontloading washer won't spin at all
Have a GLTF2940. Error code E20 and E30 came up. Will not drain and spin.
What to do?
Jul 27, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Argh... Not Drain or Spin Effectivaly
There are two possible causes here.  One is that the pump is either defective or clogged.  The other is that the spin control board is defective.  If the pump has a multi-fan wheel on the front of it, see if it is spinning during the drain mode.  If it does not, it could be clogged.  Remove hose and you will most likely find something in the housing.  (rubber backing from a bath mat, bra underwire etc.)  Once you get the pump functional and the unit still does not spin, go to the spin control board.
Oct 10, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire FTF530FS Front Load Washer Logo
242 people viewed this question
Top Frigidaire Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Jason Harris
Jason Harris
Sal De
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
