Question about Maytag CWE4800A Electric Single Oven
I have a Maytag double wall oven purchased in 2001. I need a bake element but part of the serial and model numbers cannot be read...i can make out serial 18_75575Zq and model CW_800AC_. Can you help me fill in the missing digits so I can order the part? I guessed at the part and ordered by measuring and like appearance but after receiving it im not sure i ordered the correct part.
  • erroberson1 Jul 11, 2009
    I am in Houston, TX...the part looks exactly like the old one except the leg ends where the wires are attached have a different color..the old ones are blue, the new red. Also, i was told to simply remove the screws that connect the wires to the old element to remove it but i find no screws so im not sure how to remove it.
    I got it! Thank you, Mike!
    President:
  • 744 Answers
Hello, I have checked out every source of mine and unable to come up with the correct model number...In the past when I dont have a model number I have taken the heater to a local appliance store to have them match it...If you want to comment back with your town and state I can get you a list of local suppliers, also its worth remembering you reallly only need find one that matches yours beacuse all heaters are 220v and really any heater that fit's would work. comment back and I will give you a list of local suppliers. Mike
Posted on Jul 11, 2009
  • Mike Price
    Mike Price Jul 11, 2009
    oh ok well you have the right heater just the wrong terminals..that heater WILL work..just need to change the ends, all you are going to need to do is cut the terminal Ends off the wires..next if im reading this correctly you have spade connectors on the end of the heater...go to an electrical supplier and buy a pack of crimp on connectors like in this picture i'm going to insert...
    The one you prob going to need is similar to yellow one 2 up far right...anyway go to an electrical store home depot will have them..buy a crimping tool and crimps..no more then $10. Attach new connectors to heater..reassemble your oven and your good to go.
    If you have any other questions feel free..
    Mike
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
NEED BAKE ELEMENT FOR THIS MODEL
Hey friend, thanks for your post!
I understand that you are in need of a bake element for your Frigidaire wall oven, RGB94K. I would recommend performing an online search for antique appliances to see if any additional parts are available for purchase. I hope this information has been helpful. -Matt
Sep 27, 2014 | Frigidaire 24" Single Gas Wall Oven with...
Maytag model number mew6527dds when you turn to bake the broiler comes on
The oven control board is defective--most likely the electronic control chips have been damaged and are causing a crossing of the functions.
Sep 08, 2014 | Maytag 30" Built-In Single Electric Wall...
Thermostat broken
Good Morning a_t_pearson, this is Z. Thank you for your post! I understand that the thermostat is broken on your top Frigidaire oven; therefore I'm assuming that you have a double-wall oven. If so, please help me understand what you are referring to by thermostat? Is your oven not preheating or reaching desire temperature? Are you speaking about the bake and/or broil elements not heating? May I please have your model number? The serial tag, which lists your model number, is typically located on the front of the oven, on the left side, as you open the door. With this information I can better address the issue at hand. Thank you!
Apr 01, 2014 | Electrolux Ovens
Whirlpool built in electric oven bake (bottom)heating element does not heat up only tot heats when in bake mode
CHECK FOR CRACKS IN THE BAKE ELEMENT. IF THE UNIT IS NOT HEATING THE BOTTOM, BUT THE TOP IS STILL HEATING, YOU MORE THAN LIKELY HAVE TO REPLACE THE ELEMENT. THIS IS A 220 VOLT OVEN WITH 110 VOLTS ALWAYS GOING TO THIS ELEMENT, SO TURNING OF THE BREAKER IS VITAL FOR SAFETY PURPOSES. WITH AN OHM METER, UNINSTALL THE ELEMENT AND CHECK BOTH WIRE CONNECTIONS FOR OHMS. YOU SHOULD GET SOME KIND OF READING BETWEEN 10 OHMS AND 500 OHMS. IF YOU'RE NOT AT LEAST GETTING A SOLID READING, REPLACE THIS ELEMENT.
Jan 24, 2013 | Whirlpool 24" Double Electric Built-In...
I have a frigidaire 30" wall oven GLEB30T8CBA.
The control on the upper bake element has failed.and needs to be replaced
Nov 28, 2010 | Frigidaire 30" Built-In Double Electric...
I have an electrolux double oven eou 6330 the bottom oven element has broken.Can I buy and fit it myself as single female with very little spare cash?
Yes. You can do it. Part should be $40 or less.
Turn off the power to the oven. Remove the oven racks.Unscrew the element screws from the back wall of the oven. Carefully pull the element out. The wires may be short. Remove the wires from the element. Do not let the wires pull back into the oven cavity. Take the element to the appliance parts store and have them match it to the existing element. Attach the wires to the new element,insert the terminals into the opening,replace the mounting screws. Turn on the oven and bake away.
P.S. Your model number is not correct.
Nov 05, 2009 | Electrolux EOU6330 Electric Double Oven
Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
Jan 30, 2009 | Thermador Ovens
Maytag "Magic Chef" electric double wall oven
check the high limit swtich. You need to remove the back of unit to find it. replaced it part# is:w10175596
Jan 02, 2008 | Maytag CWE5800A Electric Double Oven
Maytag CWE4800A Electric Single Oven Logo
Top Maytag Ovens Experts
Carmen Mikulic
Marvin
Marvin
Sal De
Are you a Maytag Oven Expert? Answer questions, earn points and help others
