Question about Freezers
My fridge freezer is making a lot of noise after opening the freezer door. It sounds like a fan
    Champion:
  • 363 Answers
You are right it is the freezer fan. In order to replace this fan the rear panel has to be removed. The fan is attached to the rear panel on the inside. The DC brushless motor over time wares out, causing the shaft to wobble, this wobbling causing the fan blade to hit the side of the housing.
Posted on Jul 26, 2009
Samsung wheezing/ Gasping sound.
It is likely just refrigerant coursing through the coils, or maybe the water valve when it opens to fill the ice maker... Is it constant, or does it come and go at intervals?
May 27, 2016 | Samsung RF4287HABP 28 cu. ft. 4-door...
Samsung refrigerator loud noise
if the fan is still running when you open the door , the I would be leaving that idea as a last resort
try this
get 2 taper door chocks and put one either side at the back of the fridge
push the cabinet sideways and slip one chock in a bit then do the other side
many noises are from the bottom plate that the compressor is mounted on from tapping on the floor and lifting it a bit stops the noise
the same as when you open the door the pressure on that plate is removed and so it stops hitting the floor
Nov 04, 2015 | Samsung RS261MDWP - 26 cu. ft. Side by...
Ariston fridge/freeser BCB31AA
Call out the warranty supplier. Where is the noise coming from? If no warranty, check the electrics to the compressor and fan. sometimes the noise is the fan. Also switch off overnight and leave doors open. When restarting, if the noise has gone it will have been the internal fan hitting on ice buildup.
Mar 25, 2014 | Freezers
Fridge noise cutting out
To be honest it sounds to me like your fridge may be ok?
To extract the heat from within the fridge interior a compressor (motorised pump) moves gas around a series of pipes around the cabinets insides. This movement of gas causes heat to be picked up and taken away externally to the outside world. When the fridge temperature reaches a predetermined level (around 5C) the compressor shuts down and all is quite. The sound of running water you hear is the coolant gas changing state from gas to liquid and running through the coolant pipes. If the fridge is doing it's job and keeping the content cool then I wouldn't worry. One of the reasons you are probably noticing this sound is because it is a table top fridge. Built in fridges make the same noises but you don't really hear them so much because of the cupboards screening the sound.
Dec 27, 2013 | Igloo Cooler IGLOO Freezer. 3.6 cu. ft....
FRIDGE COMPARTMENT NOT COLD ENOUGH.
If you have never defrosted it before, leave it off for a lot lot longer, doors open in a warm area. Is the fan working when you close the door ?(or hold the door switch in), if not, there could be a problem with the condenser fan), otherwise 90% of the time, they are frosted up internally, and because of good insulation, need time to "warm up" inside, in order to defrost
Mar 30, 2009 | Freezers
Constant and fairly loud noise
thats typically an air circulating fan thats either faulty or something is touthing the blade. open up and see.
Jan 09, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
The fridge on my fridge freezer has stopped
just about all friges work off the frezer .the evap fan moves the air fromthe frezer to the frig.so you would here fan noise.i dont know your brand but on most frezers if you turn the frezer temp to the highest setting thats acomplished by keeping the air from going to the frige.hence warmer frig temps .also make sure fan on out side back is working and condenser is clean.again turn air damper control from frezer to frige to lowest setting .somthimes this could be in frig section.God bless ,tom
Jan 01, 2009 | Freezers
Fridge making a purring sound then stopped working
Yes, I think you have a problem that can be fixed easily by a repair technician. The sound as you described it could have come from the air circulation fan in the freezer compartment striking ice. As the ice builds up it could have stopped the fan from rotating and air flow to the refrigerator compartment.
Nov 27, 2008 | Zanussi Freezers
Noisey fridge freezer
Please check the fallowing:
-Loose flooring or floor not firm.
- Cabinet not level.
- Tubing in contact with cabinet, other tubing or other metal.
- Drip tray vibrating.
- Fan hitting another part or worn fan motor bearings. Unplug the unit and rotate fan manually by your finger.
- Compressor mounting grommets worn or missing; mounting hardware loose or missing.
- Free or loose parts causing or allowing noise during operation
- Check compressor it may contact with tubing or other parts.
- Check the body of your unit is not touching the wall or other object
Jan 25, 2008 | Freezers
FREEZER SOUNDS VERY NOISY
that because the internal fan is hiting the ice or has bad bushings you can hear the noise just with the door close because when you open the door there is a switch the one turns off the internal fan so when you close the door it turn on the fan again if you wants to hear that with the door open just open the door and push the botton swich with your fingers and you'll hear the noise
Dec 29, 2007 | Freezers
Freezers Logo
105 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
