Question about GE WSM2420T Top Load Stacked Washer / Dryer
Washer wont drain....
Good Afternoon. My washer/dryer combo is only 1.5 yrs old. Today the water would not drain from the unit. Any ideas why besides the lid switch?
Try the lid switch with a screwdriver in the slot to see if it activates. Mine did the same thing, would agitate but not empty nor spin and it was the lid switch assembly--a 35.00 part that cost 150.00 to repair with a repairman!
Posted on Sep 04, 2009
GE spacemaker Washer Dryer Combo don't drain properly?
Check the drain hose for obstructions. Is it being pinched where it goes over the top of the drain pipe behind the washer?
The pump may be going bad...
Jul 29, 2014 | GE WSM2700W Unitized Spacemaker Washer and...
GE Washer wont drain. Wont agitate, does nothing. Washer is part of a stackable unit about 4-5 yrs old. Checked circuit breakers and electrical and water supply. What should I check? Are there fuses inside...
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Here is a link to the part you need.
Jan 10, 2011 | GE WSM2700W Unitized Spacemaker Washer and...
My little boy put my bosch exxcel washer/dryer on to dry for 2hours and then switched it to drain and then turned it off, now its stuck halfway through drain and the door wont open.
i have never worked on this type of washer dryer combo, but just from experience if a washer will not unlock and it keeps trying to drain it is either there is enough water in the unit to trip the pressure switch and the pump keeps trying to drain, means there is a blockage normally in the pump, blocking the pump, or blocking the pressure switch tube. clean these out and unit should work fine. if you arnt tech savvy , call a professional and be prepared to pay.
Nov 24, 2010 | Bosch Washing Machines
Water under stackable washer dryer
The front panel comes off and you will be able to trace the water source. These combo units spin immediatly and if the drain is slow the water will spin up over the edge of the tub during drain.
Eric
Dec 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
Hotpoint Aquarius waher dryer
possible blockage ' filter or could aslo be water coming back from the sink if drain hose too low , you may need to raise this....
Nov 13, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Beeping dryer & broken hinge on the washer
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 20, 2009 | Kenmore 24032\24036 Top Load Washer
LG washer/dryer combo will not drain water
easy first unplug unit..take back remove phillips head screws...now the pump drain hose is the other side of the filter in front just take a pliers remove clamp,,replace hose..close unit plug back in
Aug 18, 2008 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Leaking
Flooding like that usually means a bad drain hose or bad hose connection either at the bottom of the basket or at the drain pump. Need to check both.
Apr 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Why wont my washer dryer empty the water...???
If the machine fills and agitates but does not drain, something is probably wrong with the drain hose or the pump. The fact that the washer fills and agitates tells you that the motor works and the belt is okay (though some units have a separate belt for the pump and direct-drive washing machines don't have belts). 1) Be sure the drain hose isn't kinked. 2) Check the tab on the lid that strikes the lid switch; if it is broken, the washer may stop during the drain cycle. Press and release the lid switch: if it doesn't click each time you do this, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service person. 3) The water pump may be broken or clogged with a small article of clothing or the controls may be broken; call an appliance repairperson. courtesy "nagev"
Oct 24, 2006 | Hotpoint Aquarius WD63 Front Load...
GE WSM2420T Top Load Stacked Washer / Dryer Logo
257 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Sal De
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
