Question about Hitachi 50UX58B 50" Rear Projection Television
Convergence i no longer have the factory remote. if i hold the magic focus button for more than three seconds it will go into center mode and then static mode, can i do any thing in these modes with out the remote.
  • 934 Answers
No, and you can order any number of so-called substitute remotes for it and they'll work the Tv functions okay but they will fall short of operating everything in the higher functions like service menu operation and convergence...
There is one possibility, miracle remote. I haven't ordered or had a need yet to get one of their Hitachi remotes but I have several others and they operate EVERYTHING perfectly! Might give it a try.. http://www.miracleremote.com/
Hope this helps
Bill
Posted on Nov 15, 2007
Magic focus not working colors not aligning
If Magic focus will not correct it (it is the limited auto convergence for this set) both the convergence chips which should be stk392-110 or 150 will have to be replaced, convergence is done with the original remote with set in the Decam ( tech convergence mode).
The parts are not that expensive and TVrpairparts.com sells kits with instructions for these sets by model number.
Dec 10, 2012 | Hitachi 51S500 51" Rear Projection...
Hitachi convergence seems to be bad, but all resistors check in spec's can you check ic's the cross hach lines will move in all directions but some are bent
I know this set very well, have fixed hundreds of Hitachi sets with convergence problems--
first--did you just go into the customer menu?
There are two ways to get into the tech convergence mode on most of these sets---if the set has "MAGIC FOCUS" PRESS the button the front panel---while magic focus is running press magic focus again --if STOP is displayed on the screen press either RECALL OR STATUS BUTTON ON THE REMOTE--set will go to the tech convergence mode--take a good look there ---if red or blue is skewed most likely one or both of the 2 STK-392-110 CHIPS THIS SET USES IS BAD--NO WAY TO TEST THEM--IF RESISTORS ARE ALL GOOD--you have to replace BOTH chips to see if one is your problem.
You can also get into the tech convergence mode by removing the front speaker grill and inspection plate behind it----there is a tiny micro switch on the front of the board (little blue button) with something not metal--touch it with the set on and you will be in the convergence mode.
I presume you know how to navigate with the remote in this mode 2,4,6.8 to move--ant to select blue and 0 to select red---enter button will stop blinking cursor and you use the ARROW CURSORS to adjust---DO NOT TOUCH ANY OTHER BUTTONS---
What you are looking for is will the "bent" lines adjust.
If the answer is no--change the two chips and see what you have--The STK-392-110 chips can also be replaced with STK-392-150 chips---they are a longer life version of the original chip.
If you need help doing the repair ask me before you begin.
SD TECH
Oct 19, 2009 | Hitachi 53FDX20B 53" Rear Projection...
Alignment Issue with model 53SDXBA Magic Focus doesn't correct.
A little hard to explain:there is a small micro switch on the front of the main circuit board(very small and usually button on it is blue) this will take the set into the CONVERGENCE MODE---DEPENDING on the number on the remote(CLU5722tsi etc) different buttons on the remote are then used to navigate and to adjust convergence; some buttons will allow you to change from red to blue; others will change the grid that will appear when you engage the micro-switch from fine to coarse---this set should have a remote with clu-615mp marked on the outside of it. If you need full information I can provide a detailed copy of instructions via email for this set and this remote-----after all convergence is aligned you have to use the remote to SAVE the adjustments---if you think this is beyond you---get a tech to do it---these sets are easy to align for convergence(presume you do not have a convergence problem) and it is easy to do after you know how. etower.766@netzero.net
Jul 18, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Is there a Magic Focus function on 53XDF01B?
The correct model is 53fdx01b. There is a mogic focus button on the front of the set. Procedure for Chassis DP05F, DP05, HP11, HP12:
1. Press and hold the DIGITAL ARRAY or CONVERGENCE ADJUST button on front panel.
2. While the button is held down, then press the INPUT or ANT button on remote control.
3. The unit will now be in the DCAM.
NOTE:
1. Proceed with digital convergence adjustment.
2. Remember to save the correction data.
3. Units with MAGIC FOCUS only - Failure to initialize MAGIC FOCUS sensors after saving
convergence correction data will result in a STATIC (+) display when MAGIC FOCUS attempts
to run. The technician will then be required to access the service only switch behind the front
cover to get back into the DCAM to initialize the sensors, since the procedure to access DCAM
without removing the front panel, requires MAGIC FOCUS to be running.
4. To exit, press the POWER button on the front panel.
Apr 23, 2009 | Hitachi 53UDX10B 53" Rear Projection...
I have 46ux13k hitachi tv and i need to know if there is atrick to adjusting the convergence.
Manual Convergence for the Hitachi. YOU WILL NEED ORIGINAL HITACHI REMOTE. NONE ELSE WILL DO
1. Receive an NTSC signal.
2. Press Magic Focus to begin magic focus
3. Press magic focus again during the magic focus process to get the “stop” screen.
4. While stop screen is up, press STATUS or INFO on the remote control (R/C) to bring you to DCAM mode and the service grid (64 point grid).
5. When you first get in here? I believe red is the selected color by default (it is flashing).
6. To choose other colors to converge, use the following buttons on the R/C:
· “STATUS” - Green
· “0” - Red
· “ANT” – Blue
ONE COLOR WILL NOT MOVE. YOU WILL NEED TO MOVE OTHER COLORS TO ALIGN TO IT.
7. Start from the center of the screen and work your way out on one color at a time. I adjusted red across the whole screen to match green. Then I switched to blue, and adjusted that to green as well. After you adjust blue, you
may want to go back and adjust some red again? etc. until the convergence looks good.
· Use 4, 6, 2, and 5 on the R/C to move the cursor position (dotted lines).
· Use thumb stick to move the convergence point color.
Then going along the lines and adjusting, you may run into the problem of getting an ‘S’ curve on the line. You’ll know if you get there. Basically, no matter what you do to adjust the line to be converged, the middle of the line between the points will not straighten out (it bends between the points). To fix this, the manual recommends going to the (7x5) mode which gives you less points to adjust. I had this problem, and the solution worked. There is also another mode (3x3) which gives you even less points. Basically, if the set looks good, you only fine tune it in (13x9) mode (64 point). If you have serious problems, the grids work as:
3x3 – ‘coarse’
7x5 – ‘medium’
13x9 – ‘fine’
10) To get to each of these patterns use the following on the R/C: (only if you need to)
1. (3x3) Press “STATUS” 5 times (only works when DCU is in uncorrected state)
2. (7x5) Press “0” 5 times
3. (13x9) Press “ANT” 5 times
11) If you adjust the 3x3, then you should go to the 7x5, and then the 13x9. You get the point… depending on where you start, work your way up, and always finish on the 13x9
12) When finishing up the 13x9 mode, to get additional ‘grids’ on the edges of the screen, press the PIP CH button on the remote control while in the digital convergence adjustment mode (DCAM). Fine tune the edge convergence as necessary. To exit, press PIP CH again.
13) When convergence is acceptable, press PIP MODE to write data to ROM memory. ROM WRITE? is displayed to alarm system that ROM will be overwritten with new data. Press the PIP MODE button again to write displayed data to ROM.
14) DATA WRITE TO ROM will take approximately 4 seconds and no picture will be displayed.
15) Green dots will be displayed when operation is completed.
16) Press MUTE to return to convergence pattern, then confirm again convergence is acceptable.
17) Turn power OFF.
18) Wait a few seconds. Turn the TV on, and you should have your normal signal. Press Magic Focus button just to make sure the magic focus still works (and that you did the last few steps properly)
Mar 21, 2009 | Hitachi 43FDX01B TV
DOUBLE IMAGE HITACHI ULTRAVISION TV
Ok, I would suggest before you buy anything from anybody is to try to do a manual convergence.
1) Receive an NTSC signal.
2) Press Magic Focus to begin magic focus
3) Press magic focus again during the magic focus process to get the ?stop? screen
4) While stop screen is up, press STATUS or INFO on the remote control (R/C) to bring you to DCAM mode and
5) When you first get in here? I believe red is the selected color by default (it is flashing).
6) To choose other colors to converge, use the following buttons on the R/C:
a) ?STATUS? - Green
b) ?0? - Red
c) ?ANT? - Blue
7) Start from the center of the screen and work your way out on one color at a time. I adjusted red across the
(a) Use 4, 6, 2, and 5 on the R/C to move the cursor position(dotted lines).
(b) Use thumb stick to move the convergence point color.
** There have been other posts in here to tape together the color filters found in the Avia DVD to help converge
lines more easily. I have used this method, and it works well for adjusting to a greater detail. Basically, you put the
red filter next to the green and adjust your red to the green line both horizontally, and then vertically. Then you do
the same with the blue next to the green. Some people recommended you should be at normal viewing distance. I
did mine from just a few feet back from the set. Maybe my eyes aren?t as good? maybe I just felt like it worked
better this way. There are some other posts also recommending using binoculars. I think it?s great that people
suggest things to make the process easier? but my girlfriend would think I was insane if she saw me with
binoculars on the couch adjusting the convergence. I don?t know? whatever works best I guess.
8) I did not adjust the green at all. I use the green as the guide and did not adjust the location of any green point.
This is highly suggested unless you have geometry problems.
9) When going along the lines and adjusting, you may run into the problem of getting an ?S? curve on the line.
You?ll know if you get there. Basically, no matter what you do to adjust the line to be converged, the middle of the
3x3 - ?coarse?
7x5 - ?medium?
13x9 - ?fine?
1. (3x3) Press ?STATUS? 5 times (only works when DCU is in uncorrected state)
2. (7x5) Press ?0? 5 times
3. (13x9) Press ?ANT? 5 times
11) If you adjust the 3x3, then you should go to the 7x5, and then the 13x9. You get the point? depending on where
12) When finishing up the 13x9 mode, to get additional ?grids? on the edges of the screen, press the PIP CH button
WARNING: YOU MUST DO THE FOLLOWING STEPS TO COMPLETE MAGIC FOCUS
INITIALIZATION!!! THERE HAVE BEEN MANY POSTS THAT PEOPLE HAVE HAD PROBLEMS
WITHOUT DOING THIS STEP BECAUSE THEY LOOSE MAGIC FOCUS!
17) Press PIP MODE and then PIP CH to initialize Magic Focus. The initialize operation starts and several
windows appear during this operation. It takes about 30 seconds or less.
18) When green dots appear, initialize operation is finished.
19) Turn power OFF.
21) Wait a few seconds. Turn the TV on, and you should have your normal signal. Press Magic Focus button just
Oct 27, 2008 | Televison & Video
Convergence hitacho 61swx10b
To enter digital convergence adjustment
mode without removing the front speaker
grill, please do the following:
1) Press “Magic Focus” button on the front
panel.
2) While “Magic Focus” is running, press
Magic Focus button again to “Stop”.
3) Press “RECALL” or “STATUS” button after
“STOP” OSD appears on the screen to
enter digital convergence mode.
4) Proceed with convergence adjustment
and save the data.
5) Do MAGICS FOCUS sensor initialization.
6) To exit, press POWER button on the front
panel.
7) Normal and through 1080i modes are
stored separately. Each one has it’s own
memory setting.
Aug 11, 2008 | Philips 60P8342 60" Rear Projection...
1993 Hitachi Projection Screen TV
Hi Dennis!
Your HItachi has an automatic color convergence (color beam alignment) feature called "Magic Focus" which can be accessed from the set-up menu. When selected, you will be prompted to push the front panel "Magic Focus" button... do so only one time and do not hold the button in more than three seconds to enter this mode. The process takes about 90 seconds to complete, but a second push of the button will stop the process with no change.
If the convergence is still bad after the auto-correction process, then the guns are misaligned beyond its corrective capabilities, and would require manual convergence.
A service manual detailing how to do this is available for a nominal charge at http://www.how2files.com/bykey.php/hitachi.
If you don't have one, a free download of the user's manual is available at https://merchant.satisfusion.com/sf/WarrantyCenter/registration/secure/Hitachi/Manuals/ModelNumberManualLinks.jsp?masterModelOID=SF-990486114-595&random=1213688278588.
Hope this is helpful, let us know if you have any other questions, and good luck!
Thanks!
-WildBill
Jun 17, 2008 | Hitachi 53SBX01B 53" Rear Projection...
Hitachi 53uwx10b Convergence
You must have the original remote to do complete convergence adjustments. Remote method: Press MAGIC FOCUS button on front panel to start the magic focus. When magic focus is running, press MAGIC FOCUS again. STOP should appear onscreen. Immediately press RECALL or STATUS on the remote (must be pressed before STOP vanishes). The set is now in DCAM (Digital Convergence Adjustment Mode). Manual method: Remove the front grill and access panel or reach around from the back and press the little pushbutton located in the front left corner of the PC board, next to the Digital Convergence Module.
Once in DCAM, the remote buttons STATUS selects green, 0 selects red and ANT selects blue. 2,4,5 and 6 move the cursor and the thumbstick makes the corrections.Make all necessary corrections and then press PIP MODE. The words ROM WRITE? appear onscreen. Press PIP MODE again to store settings. When green dots appear, press MUTE to return to convergence pattern. Press PIP MODE (ROM WRITE? appears again) and then press PIP CH. This will Initialize the internal sensor data positions. When INIT finishes, press POWER on the TV and convergence is complete.
Mar 26, 2008 | Televison & Video
Hitachi 43FDXO1B Convergence?
Manual Convergence for the Hitachi. YOU WILL NEED ORIGINAL HITACH REMOTE CONTROL. NONE ELSE WILL DO.
· “STATUS” - Green
· “0” - Red
· “ANT” – Blue
3x3 – ‘coarse’
7x5 – ‘medium’
13x9 – ‘fine’
17) Turn power OFF.
Jan 13, 2008 | Hitachi 43FDX01B TV
Televison & Video Logo
47 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
