Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Find a Solution
Most Common Problems for:
My assassins creed wont load????
pst1 on Nov 15, 2007
i recently bought assassins creed and i went to put the game in and when i did,the disk icon came on on the across menu when you turn on you ps3,well iy read the game but it wouldnt load? the screen just went black and stayed that way? can anyone help me out about that? (i even took the game back and exchaned it for anotherone and it does the same)
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Same Problem
Jul 14, 2008
-   When I put the game in it shows up on the playstation menu. However when i start the game it shows Playstation 3 like normal and then the screen goes black and stays black. -   Harshaw
Jun 09, 2008
-   The PC version has problems too - seems like a good game that got rushed through to sale.-   Guest
Jun 04, 2008
-   bought assissins creed and it wont load so i exchanged it for another one and i get the same problem-   Guest
May 15, 2008
-   i bought assassins creed and when i click on it on the ps3 menu the screen goes black!!!! please help!!-   kevinmurren7
Jan 27, 2008
-   Same problem. Assasins Creed had 2 new discs and wont play. Took the console back and its just the same. the title comes up but the screen goes black and thats it. I`ve tried it on other TV`s analogue and HDMI its all the same.-   Guest
Solution #1
posted on Nov 18, 2007
Somewhat Helpful)
KiKi5
Rank: Wiz
Rating: 81%, 105 votes
if no games load or play back up your save data and try a system restore if that doesn't work u need to call sony if under warranty and they ill probably send u another ps3 within 7 days if not under warranty check out this link
http://www.eurogamer.net/forum_thread_posts.php?forum_id=1&thread_id=73887&start=60
Was this helpful?
Yes
No
Solution #2
posted on Dec 27, 2007
Somewhat Helpful)
tervy
Rank: Apprentice
Rating: 78%, 2 votes
Hey guys just got the same problem, here is what i did
-download/update the firmware for your ps3 (wirelessly or wired)
-do all the bs it tells you to do
- download the update for assasin's creeed
-load game
-ENJOY (finally, lol)
Was this helpful?
Yes
No
Solution #3
posted on Nov 30, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Assassins creed wont work if ur tv doesnt support at least 720p resolution.Thats why u see black screen..
Solution #4
posted on Dec 09, 2007
Not Helpful)
strey23
Rank: Apprentice
Rating: 57%, 3 votes
i may know why some games won't work as some people said before, u may need to have a high definition tv which can support the power of your ps3 and game e.g. if you have a ordinary tv with no high definition system it may not have enough power to support such a powerful console and games. some games require a lot more definition then some other games which may result in the black screen appearing. imo u need full HD TV to fully unlock the playstation 3's potential.
Was this helpful?
Yes
No
Solution #5
posted on Nov 29, 2007
Not Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
keep trying sometimes it works
Solution #6
posted on May 12, 2008
Not Rated)
badseedjr
Rank: Apprentice
Rating: 0%, 0 votes
If you all are still having this problem, this is what I had to do. There are 2 places where you have to go in to and delete the assassins creed game data. One is the normal save data, but there is also a place with the game data that is corrupted. If you go in and delete both the save data AND the game data, it should reload all of that the next time you put the disk in and allow you to play.
Was this helpful?
Yes
No
Solution #7
posted on Dec 26, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
All you need to do is update the PS3 to 2.00 or higher.
Solution #8
posted on Dec 25, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
how do you update to firmware v2.01 with a black screen ?
Solution #9
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
hey guys, my brother just got a ps3 today for xmas. He also ruined it with the assasain's creed. I updated his firmware via internet and it worked fine. Make sure you update. Cheers
Solution #10
Not Rated)
gpaulo
Rank: Apprentice
Rating: 0%, 0 votes
Hi there. Hope this helps:
+Check your firmware. Must be 2.00.
+Check if your PS3 is PAL or NTSC.
I got Assassin's Creed to work on the NTSC. On the PAL it leaves me with a black screen on startup. I'm not sure though, could be the firmware too. Cheers.
Was this helpful?
Yes
No
Solution #11
posted on Dec 22, 2007
Not Rated)
speedpunks85
Rank: Apprentice
Rating: 0%, 0 votes
helP1!!!!1
Was this helpful?
Yes
No
Solution #12
posted on Dec 06, 2007
Not Rated)
Victor Ward
Rank: Apprentice
Rating: 0%, 0 votes
Got it to work by updrading to firmware v2.01. Works a treat now.
Was this helpful?
Yes
No
Solution #13
Not Rated)
guicane
Rank: Apprentice
Rating: 0%, 0 votes
I have tried so many things but finally I have got it working.
The playstation was set up to work in 720p, I tried changing to 1080i and it works perfectly! I´m very happy! Weird thing is that it happened only after the 2.0fw, before all games used to work in 720p!
Was this helpful?
Yes
No
Related Problems
wont play anything piece of ****!! help!!!!
had it hooked up to hdtv at a friends now i"m at home and i...
my problem, it can't read my soul calibur 4 game but my...
Can you Help with these Video Game Console problems?
help
Solve
when my ps3 come on all you can see is the background and nothin else
i get sound but no picture, have...
Solve
i get sound but no picture, have already tried resetting console, and different jacks,for ps3 .
ps3 controllers will not work...
Solve
controllers will work when plugged in to PS3 usb. I don't know if this is related but my wireless... (More)
PS3 won't play anything
Solve
I was watching a blueray movie, out of the blue it froze, and i had to manually power it off. from... (More)
22 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Dec 30, 2007
game loads on preview screen but when I try to load it the screen just goes black.
Comment by Guest, posted on Dec 25, 2007
I have exactually the same problem........does anybody know why this is?
Comment by wigz411, posted on Dec 25, 2007
Merry xmas. Iv had the same assassins creed Christmas blues but managed to solve it first go to the ps3 homepage and download the new ps3 update patch you can do this straight to your ps3 if it is hooked up to the net. Mine isn't so I downloaded it to my mp3 player and the through the usb port of the console updated the ps3. There are very easy to follow instructions on the site and now after a short while Im playing Assassins creed. I hope this helps all.
Comment by slickrick777, posted on Dec 25, 2007
I have a standard t.v. and assassin's creed won't load. the screen just goes blank after it says playstation 3.
Comment by furiousmum, posted on Dec 25, 2007
Jut got a new PS3 and assassins creed game. Have spent hours trying to get it working. PS3 wont read disc. Just get a screen with PS3 home options and no disc being read. Christmas very frustrating in our house.
Comment by YuNg GuN, posted on Dec 25, 2007
put disc in then sez playstation 3 then screen stays black
Comment by joey85, posted on Dec 24, 2007
my game doesn't load but when i put the disc in the backgroung changes but the game screen goes black when i try and play.
Comment by tolrak123, posted on Dec 24, 2007
I HAVE THE SAME PROBLEM!!! Except, it affects both "Uncharted:Drakes Fortune" and "Assassins Creed". Okay here is what happened. I went to the store and purchased both Uncharted and Assassins, i was really excited to play and I got home and put Uncharted in the system first. It worked fine, but overtime I began notice it was freezing a bit and the audio would overlap or be a little delayed. OVer the course of 2 days it escalated and became really bad, audio would almost stop playing then be mashed into one big audio clip a minute later. NOW ASSASSINS CREED: is waaayayayayya worse! I cant even play that game on my PS3! The minute I put it in it worked but it had awful load times, at first I just thought, oh ok, it will work eventually, then once i started playing! The same audio thing I experienced in Drakes Fortune (Uncharted) occurred in Assassins but it was 100X worse!!! It was so bad the game would basically "stop" until the audio was retained (which rarely hapened). To make this simple, I basically cannot play assassins since I can;t even get past that "Animous" part you know that machine thing at the first part with the doctors looking at you! Furthermore, Now my PS3 is acting incredibly slow and messed up, I cant play unchrated or Assasins creed but I can play all my other games such as Heavenly Sword, Motorstorm, Call of Duty 4, etc!!! HELP HELP HELP!!!! - Oh yeah I also returned Uncharted and Assassins Creed back to gamestop and got brand new ones AGAIN = STILL NOT WORKING!!
Comment by koketso, posted on Dec 15, 2007
i have turned off the system, cleaned the disk, taken it back to the shop and got a replacement no difference. tried unplugging controllers.... nothing.
Comment by Tony151, posted on Dec 14, 2007
I got the game for my birthday, and I put it in, game goes to black screen, and im sitting there looking at it to load for like five minutes, I dont understand why it doesnt work, some people say that you need a better tv, but I dont think that sony would make a game that you would have to buy a hdtv to play it, Im goin to get another system and see if its jus my ps3
Comment by Guest, posted on Nov 30, 2007
i brought my boyfrend a ps3 4 christmas and u get da game assasin creed wid it and the installation disk dem 2 disks wont load and we have anova game that does work why doesn it work??? xbox 360 is so much betta
Comment by Victor Ward, posted on Nov 30, 2007
I have the same problem. Anyone manage to get it fixed yet?
I have had two disks so far with the same problem. Screen goes black after clicking on the game icon in the ps3 menu. I have even had my ps3 replaced - and the same problem still occurs. PS3 works with CoD4, and assassins creed works at the store where i bought it.... but through a unique situation does not want to work on my PS3.
Is it a resolution issue? Or a firmware problem? I havent updated my FW yet and am not connected to internet or PSN.
Comment by guicane, posted on Nov 28, 2007
Hi everybody! I am in the Uk using a Japanese console. Everything was fine, I played 5 games on the console and it was ok. After the 2.0fw the console still works, all dvds and blurays but when I insert the game disc I get a blank screen, no sound at all. The ps3 is connect via hdmi and always worked. Tried 2.01 fw and still the same! I have no idea what to do! The BR drive is fine as it detects there is a game, it loads the game wallpaper in the XMB and plays all discs. Anyone got any ideas? I rang Sony but they wouldn´t help me as my console is not European! Please help me people!!
Comment by M555, posted on Nov 26, 2007
I have the same problem. I had to unplug the PS3 to get it working again - I would get the black screen when putting the Assassins disk and then my other games wouldn't play anymore. The controller quit working, too. After unplugging, everthing recovered. The exact same thing reoccurs each time I put the Assassin's Creed disc back in. It appears to be a defective game design. Has anyone had any luck with a new, second disc? All other games work fine, this one disables your entire machine!
Comment by Bowds 13, posted on Nov 25, 2007
Wont load game
Comment by Guest, posted on Nov 17, 2007
my game loaded asked me to update, did so. played the game switched console off, next day try to put it back on nothing only black screen
Comment by Rdy2dodat, posted on Nov 15, 2007
I'm having the same problem, I purchased Assassin's Creed and tried to play it also and it goes to the main screen and won't load up or read the disc, so I returned it back to the store, I thought it was the game because I have never had a problem with my PS3, now none of my games will load or play on my PS3.
Sponsored Links
Describe your Consoles problem:
Top Video Game Console Experts
Rank: Guru Guru
Solutions: 2826
Experience: I have yrs of experience dealing with many situations.
Ask Me
Find more Video Game Console Experts
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
