Question about Samsung CLP-510 Laser Printer
Jamming when Print heavy paper on Samsung 510
Word Document, Printer setting on BEST and CARD STOCK (or heavy paper) both jamming.
    Champion:
  • 220 Answers
Printer only handles up to 120gsm,any thicker will jam.
Posted on Jul 15, 2009
I am trying to print a card on 110# card stock and it gives me a paper jam. Is there a way to adjust the printer for heavy paper? my printer is a brother MFC-J5910DW. Any suggestions?
Your machine should be able to handle a 110gsm card stock. In your computer printer settings you should be able to change the paper type to either card or heavy/ thicker paper. If the card stock is quite stiff your machine will not be able to bend it around the paper feed roller regardless of your print settings.
Sep 11, 2018 | Brother Office Equipment & Supplies
Printer jam
Make sure tray 1 is set for "auto-sense/full sensing".
Make sure the feed rollers are clean or just replace them
May 06, 2010 | HP Color LaserJet Enterprise CP4025dn ...
Can not get the card to feed the printer
This printer isn't designed to take heavy paper, only office standard, and slightly heavier for smarter documents / photos. Best idea would be to print one on smart bright white paper (or desired colour), and take it to a copy shop where they can print onto card. The problem is that the thin paper will easily roll round the rollers at the back, however the thicker paper can't, and therefore jams with the rollers tickling the end of it.
Good luck, and congrats on wedding :)
Mar 14, 2009 | HP PSC 1610 All-In-One InkJet Printer
I have hp photosmart 7850. I was printing envelop and there was paper jam. I pulled out the stock and jammed envelop and ever since the printer would not load paper to prinit and keeps flashing for error....
I have had this happen to several people and also to me. What I did is to take a sheet of Card Stock (Heavy Paper) and put it through the feed putting pressure on the Card Stock and pressing on the feed button. What happens is that a piece of the jammed envlope or document gets caught in the feed way and will not allow the document or envelope ( in your case) to pass. It should solve your problem if it works. Bud
Jan 05, 2009 | HP Photosmart 7850 InkJet Printer
Jamming paper
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Dec 30, 2008 | HP Photosmart C6180 All-In-One InkJet...
Trouble printing Clean Edge business cards
not tru. you need to go to printer set up and chane the setting to heavy paper so that the fuser will fuse the toner in to the card stock
Dec 03, 2008 | Brother MFC-465CN InkJet Printer
Blinking yellow light
I m not sure what the specification of the paper type you are using however if you are using card stock than you should use manual feed Tray and in the printer driver properties you should select paper type as Card-Stock to make sure there is no print quality issue.
Nov 30, 2008 | HP Color LaserJet 2550n printer + HP Color...
Wont print on card stock, legal paper- keeps jamming
Menu> scroll to Paperhandling> MP Tray type>>(plain) try changing this to cardstock  <enter>
instead of MP Tray type do the same for Cassette if you desire....
Best, danakadan
Oct 11, 2008 | Kyocera FS-1030D Laser Printer
Document jam
There is most likely a very small piece of paper in the document feeder.
What you can do is take a minella folder or some card stock, open the document feeder cover and shove the folder or card stock through the feeder to dislodge whatever is stuck in there.
The document sensor itself may be knocked out of position.
It can't be the copy paper path since you can print.
May 16, 2008 | Xerox WorkCentre PE120 All-In-One Laser...
Samsung CLP-510 Laser Printer Logo
144 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
sahoo_sanjay
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
