Question about Nikon D40x Digital Camera
'lens not attached'
Even when the lens is properly attached, it says 'lens not attached'. I've checked the contacts and attachment, and it intermittently works. How do I fix this please?
  • 5 more comments
  • jbird31 Nov 17, 2007
    I am having the same issue. The camera is not recognizing the lense?
  • Anonymous Nov 22, 2007
    I too have the same issue - worked fine for 2 days. Lens is properly attached and is set for auto. - won't work on manual either.
  • Anonymous Nov 28, 2007
    so how do you fix it? do I need to take it to a dealer to get the contacts cleaned?
  • nomadwnd Dec 04, 2007
    I have a D200 and a D40. I have 2 18-135 nikkor lens'. Both lens' intermittently show "lens not attached" on both bodies. All other lens' I have work fine on both bodies. I've have cleaned the contacts to no avail.
    I sent one lens in to the factory for another problem. I had a side note about the lack of the bodies recognizing the lens and the factory ignored it. I still have not found a solution. Whenever I turn on the camera and it happens, I just move the lens a little and most often it will work. This would normally lead me to believe that it is, indeed, a contact problem except for the fact that I have cleaned them a number of times, both lens' act the same way and all the other lens' I have work fine on both bodies.
  • trebor3 Dec 10, 2007
    Our camera started intermittently displaying the "lens not attached" message. If you twist the lens partially off and then back, it sometimes, temporarily fixes the problem. We took it back to the camera store and they said they had not had any other complaints, but if it continued it would need to be returned to Nikon for repair.
  • CarlosNK Mar 09, 2008
    D40 started showing the message "lens not attached". First time removing and replacing the lens fixed the problem. After that the camera refuses to focus (it works OK with manual focusing)
We had the same problem. After inspecting the contacts I saw that the one metal ball (contact) that was separate from the other contact grouped on the mounting collar was stuck down. By pressing the contact a couple of times with a blunt object it freed up the contact so that when re-attached the lens it worked as expected.
Posted on Feb 27, 2010
  • 3 Answers
If you switch to manual operation and the error message is no longer showing and you are able to take a shot ,it would appear a contact problem on the lens or camera body.
Those little gold plated pins must be spotless.
Posted on Nov 20, 2007
I have a nikon d 40 and i bought a opteka 650 -1300 mm lens everytime i mount it to the camera it says lens not attach tried everything still nothin can anybody help
Posted on Feb 10, 2010
  • chron Feb 23, 2011
    If you have a manual lens, the camera mode dial (SPAM) must be set to 'M' for manual.
  • 58 Answers
The contacts can be cleaned if you "VERY CAREFULLY" use a clean eraser on both the camera and the lens.  Be extremely careful that you do this with the camera facing downwards, as you don't want eraser bits to find their way into your camera.  Also clean the contacts on the lens.   When you change lenses, always point the camera in a downward position, as this keeps dust and other stray particles from entering your camera and sticking to the high pass filter.    If this doesn't work, I would take it to a Nikon approved repair facility.
Good luck.
Posted on Dec 06, 2007
Camera seemed warm. Lens does not work. MessageCannot recognize lens. Attach properly. Camera now cool. I reattached lens. Still the same. Battery is 100% charged.
Have you heard about keeping the contacts clean? - Contacts are found on both camera body and lens. if you get those dirty in anyway, communication between camera and lens will be affected.
Sep 28, 2015 | Sony A5000 DSLR Black Camera And 16 - 50mm...
I dropped my Nikon d50 and now when I turn it on it flashes fEE. Whats wrong?
The lens is not making proper contact with the camera. Try removing the lens, cleaning the contacts on both the back of the lens and in the lens mount on the body, then reattaching the lens. If that doesn't do it, try jiggling the lens gently. If that doesn't do it, try attaching a different lens if you have one available, or attaching the lens to a different body if that is possible. If nothing works then it could be that the lens and/or camera needs servicing after the drop.
Apr 25, 2010 | Nikon D50 Digital Camera
I get the letter "F" flashing on and off. What is it?
What lens do you have attached? A flashing F-- indicates the camera and lens are not communicating. This can happen for several reasons:
1. There is no lens attached. Attach a lens.
2. There is a lens attached, but it's what Nikon calls a non-CPU lens. The lens lacks the electrical contacts to communicate with the camera. Set the exposure mode to Manual (M) and adjust the aperture using the aperture ring on the lens. You won't get any metering assistance from the camera's built-in meter.
3. There is a CPU lens attached. Remove the lens, clean the contacts both on the lens and the mount, then reattach the lens. If that doesn't solve it, then either the lens or the camera (or both) need service.
Jan 23, 2010 | Nikon N55 35mm SLR Camera
My Nikon D40 can only be used in MANUAL mode. I was able to take photos using MANULA mode but for all other modes it says: "lens not attached" even if the lens is properly attached.
What lens are you using ?
For all functions to work you will need a cpu lens - ie; a hsm or afs lens,these are lenses with built in motors.
Also check the switch on the side of the lens is switched to (A)
Jan 03, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
F-- appears in window with the 18-135mm attached to D80
F-- means that the camera cannot find an apeture with the other settings that it is on put yur ISO on auto and put the camera in automatic mode and it should work but it might be a problem with the apeture in the lense, in which case it would be very hard to fix and you would probably end up desroying the lense in the process, if you did not go to a specialist.
Jul 28, 2009 | Nikon D80 Digital Camera with 18-135mm...
Err 01communications between the camera and lens is faulty. Clean the lens contacts.
Some people have reported that this error comes up when they have changed a lens on the camera, If the previous lens was IS enabled and was switched on when the old lens was attached, re attach the previous lens and switch off before attaching the new lens.
If this does not work, clean the contacts with a cotton bud dipped in methylated spirits. Hold the lens above you when doing this so nothing falls into the lens.
Jul 11, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
"Lens not attached" warning when lens is in fact attached.
Hello. Check the area around the lens mount carefully - specifically the contacts. Make sure all are clean and protruding the same. If one is lower than the rest, try 'flicking' it with a fingernail (lightly) to see if it will pop up to the height of the others. It may have dirt or a particle of dust lodged. If this doesn't help, get the lens to Nikon for a check-up.
May 10, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 Error Message
Get the kit changed. That should not happen right out of the box, but make double sure the next time around, you charge the battery completely before using it the first time. Not doing this can cause problems.
Nov 18, 2007 | Nikon D40x Digital Camera
Nikon D40x Digital Camera Logo
1,743 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
