Question about Bush DVD142RC 14 in. TV/DVD Combo
Get my dvd out
Cannot eject the DVD.
It is a CRT dvd combo. The power has gone. I just want to get my dvd out and bin the TV
  • 54 Answers
Re: Get my dvd out
Most likely you will need to pull off the left side of the case if it's a tower case, otherwise for a dektop case you will need to lift the top off, and make sure that the power cable is pluged in the back of the cd player properly , its the white plug your looking for , but if the light is flashing on the front of the cd player , that means there is no need to check that the cable is in, so in this case the eject drive is most likely jammed, so while u press the eject button try pulling it the front of the eject door ,
Posted on Nov 16, 2007
0 characters
3 Points
Technika 23" dvd combo DVD just shows no signal.
I also have this problem but the DVD will not eject.
Dec 27, 2011 | Combination Televisions
My dvd got stuck in the dvd player. ther may be another dvd in there. how do i get it out?/
Power the DVD player down and press the eject button. Try to remove the DVD carefully, without forcing it.
Mar 05, 2011 | Mintek DTV-233 23 in. TV/DVD Combo
The dvd does not come out. TV plays, dvd plays, when eject button is pushed, it soundsl like it is coming out, then does not
Some units have a little hole where you can insert a straightened paper clip to manually eject the DVD,
Make sure the power off first.
Jul 26, 2010 | Sansui LCDVD150 15 in. TV/DVD Combo
Dvd is stuck in player - won't play and won't eject
open cabinet of your dvd you will find out a lock open that pick up your disk during proseeing that is stucked
Mar 05, 2010 | Mintek DTV-263 26 in. TV/DVD Combo
DVD Stuck in TV/DVD Combo
This may not sound technical, but I stuck the end of a paper clip into the opening until I could feel the dvd.....jiggled it a bit, and out it popped while pushing the eject button!!!
Jun 19, 2008 | Toshiba 14DLV75 14 in. TV/DVD Combo
TV dont respond
Hello psp007,
I hate to be the one who tells you this, but you have one of those TV sets that are controlled by a single processor (as most combos have even LCD combos) and that processor may have gone bad. This is why you have so many problems at one time. I would suspect the the main processor board has a problem. You may want to take this to a TV repair shop, because there is so little you can do for this problem since if it is the main processor you will need equipment to troubleshoot this problem and to remove and install the component with the problem. Taking it to a shop is your best bet.
I hope this helps,
Thank you,
Mar 03, 2008 | Combination Televisions
Dvd is locked will not eject the dvd
dvd locked and will not eject on a panasonic triple play
Dec 21, 2007 | Toshiba MW20FP1 20 in. TV/VCR/DVD Combo
Panasonic PV-D4743S combo DVD/VCR player won't eject DVD
This unit has seperate power supplies for the DVD and VCR side and the DVD side supply seems prone to failure. I have not isolated the cause, but can tell you this will require a component level repair. Unless you are a tech you may as well buy a new unit.
Sep 22, 2007 | Panasonic PV-DM2794 27 in. TV/VCR/DVD...
Ok this is a sure fire way of getting that DVD out. Open up the unit, find the load and unload gear, rotate the gear and that should eject the carriage slide. That's it.
Sep 21, 2007 | Polaroid FDM-0700A 7 in. TV/DVD Combo
Dvd not ejecting
I just found my solution. I pressed the power button on the remote and the stop button on the tv at the same time, and it unlocked the dvd eject.
Sep 14, 2007 | Panasonic PV-DM2792 Triple Play 27 in....
Bush DVD142RC 14 in. TV/DVD Combo Logo
157 people viewed this question
Top Bush Combination Televisions Experts
Are you a Bush Combination Television Expert? Answer questions, earn points and help others
