Question about Emerson MW8985W Microwave Oven
I think the fuse blew on my emerson microwave. Can I check myself by removing the rear panel?
  • 672 Answers
Unplug the power. Remove the screws, on the back that secure the outer case and slide it off to the rear. Check near the control panel for a clear glass fuse. If it is bad, make sure to replace it with one that has the same ratings.
Posted on Jul 11, 2009
My Emerson Microwave MW9117W has lost power and was wondering if there was a fuse or something that needed replacing
There are fuses inside. The big thing is to figure out why the fuse went bad. either something shorted and blew the fuse, or it got hot and went bad due to bad connections at fuse holder. or maybe a bad door switch blew the fuse. I have also had fuses just get old and tired., and just needed to be replaced.
Aug 19, 2017 | Emerson Microwave Ovens
Emerson Microwave model #MW8111SS fuse blown
You also may want to take a close look at the control panel. I found a grouping of 3 resistors at approximately center of the board that were cut on one end. Probably a design change poorly done. Somehow, just out of the blue, those loose ends touched and blew that fuse. Removed resistors........problem solved.
Jan 17, 2014 | Emerson MW8168B Microwave Oven
Emerson mw9113ss wont turn on
If the is no power to the microware and the display does not showing any signs of power then you internal fuse has been damaged. First I would suggest you move the mocroware to a different outlet to eliminate the outlet as the problem. Once you have eliminate the outlet, then disconnect the power and then remove the covers and find and replace the fuse. Let me know the results
Nov 27, 2011 | Emerson Microwave Ovens
The ceramic fuse has expired in my microwave (Emerson MW8991SB). Will you tell me where the fuse is located?
On my own microwave I have noticed there is a panel on the interior wall with removable screws...I'd suggest UNPLUGGING it first (of course!) then checking out the interior of that.
May 18, 2011 | Emerson Microwave Ovens
My problen is the mico is just a tad over one year old and the timer is working and the light is on inside, but tray is not turning and it is not heating up, could it be a fuse?
I would think it possible.
Remove the outer cover when the machine is unplugged and follow the mains lead in through the rear panel. There should be a couple of fuses nearby.
Always use the correct value fuse of identical type and size!
Hope that helps.
Feb 18, 2011 | Emerson MW8102SS 1100 Watts Microwave Oven
Emerson Microwave Model MW8119SB found blown fuse. Replaced fuse power came back punched in 10 sec started microwave and fuse blew again.
Chances are that either the diode or capacitor are shorted. Be very careful, the capacitor can store a charge and should be discharged first for safety. Hope that helps...
Geno
Dec 06, 2009 | Emerson Microwave Ovens
Microwave doesn't work after house fuse blew
Check the fuse inside the microwave. Unplug the power, remove the case screws on the back of the main case and slide the case toward the back. Remove the outer case and look for a fuse that looks simular to an old automotive fuse, usually near or just above the control panel. Check the fuse to see if it is good, if not replace with the same and reassemble reversing method used to access the fuse. Note: automotive fuses will not work. A replacement will be available at The Shack or a local appliance parts store.
Nov 09, 2009 | Microwave Ovens
Emerson MW8106W Blew internal 20A fuse.
You almost certainly have a shorted high-voltage capacitor.
Here is a link you or someone you know can use for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating a servicer or parts at 1-800-695-0098.
Emerson parts are distributed by Fox International and their number is 800-321-6993. Or you might try e-mailing researchdept@fox-international.com
Many Emerson microwave owner's manuals are available for free download here.
Oct 19, 2008 | Emerson MW8106W Microwave Oven
pls check fuse replace with since there were no noises seems pretty straight forward
Jul 30, 2007 | Emerson MW8168B Microwave Oven
Emerson MW8985W Microwave Oven Logo
714 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
