Cannot print I have power getting into my printer but I cannot switch it on and therefore cannot et connected to PC or print,
  • ibber Jul 24, 2008
    power light on (no other lights or display)....wont turn off if communication occuring with pc.
Just take the shell off and pull the plastic cover off the little micro-power switch. Blow it out. This is the simple soultion that worked for me, when mine would not power up at all.
Posted on Dec 27, 2007
  • 118 Answers
This might probably the printer power circuit problem try changing the power circuit or give it for repair
Posted on Nov 16, 2007
1. thing you have to check power cable.
try to change and test ones again.
2. open the front sight component using driver and check the
power cable most properly it has red color
Printer is paused wont restart
it may be that you have a corrupt file in the print queue, a quick fix is possible - switch the power socket OFF, disconnect the PC/Network connections.
power on the printer, it should have had time to clear the memory now, see if the machine is able to print a menu page or config sheet ( open menu enter the information menu- print config sheet:)
if the printeris able to do thiswith no network connections you have eliminated the printer from the problem. next switch on and log into your PC, still disconnected from printer, open print queue and delete all documents from the queue ( your not deleting the files ( just the print requests)) once this is done then reconnect the printer and send first a windows test page ( confirm working connections first ) then attempt to print the failed file - if it fails in the same manner - the file was your problem.
Mar 16, 2014 | HP OfficeJet V40xi InkJet Printer
49 service error ff04
your printer driver is corrupt or the files your printing are corrupt- most 49.xxyy errors are down to software external to the printer. not sure?.
disconnect the printer from all network points and cycle the power - when it is ready perform a path print test ( found under the diagnostics menu on the printer itself ) and you will likely find no errors ( if by some horror of horrors you do get 49.xxyy error then you will need to replace the firmware chip - Very Very unlikely) -
what to do--
remove the printer and uninstall from the workstation - reboot the PC - re install the latest driver for your operating system downloaded from HP website
re connect the printer - print away !!
Jan 28, 2014 | HP LaserJet 4600dn Color Printer
I can not get my printer to print documents from computer it acts like its not there it was printing before then something happened and now it want do anything off the computer.
The correct port has to be selected. The port is determined by how the printer is connected to the computer. Re-install your CD & follow the directions based on how the printer is connected to the PC. I have the same printer connected to several PCs using USB. Therefor I select the USB port in properties.
Nov 11, 2009 | Lexmark X2600 InkJet Printer
Hp deskjet3940 printer only prints testing page but nothing else.
uninsta|| again the driver and rem0ve the printer c0nnecti0ns t0 the pc.
put back again the c0nnecti0ns 0f the printer.|et ur pc detect it.and insta|| again the driver
Jan 15, 2009 | HP DeskJet 3940 InkJet Photo Printer
Printing error
when i send for print i et
PCL XL error
subsystem: KERNEL
Error: IllegalTag
Operator: 0x1b
Posittion: 7
Jun 15, 2008 | HP LaserJet 6p Printer
Cannot configure the wireless USB Print Server
first delte all the programs that u have installed about the print server and the printer.then connect the print server on ur laptop and run the installation .search for the wireless netwrk and connecting to it using the wpa key.After tats done connect the print server to the printer and run the printer installation ,,hope that shud resolve it,,best of luck
May 06, 2008 | Port Incorporated Wireless 11Mbps...
Nothing printing
have you install the correct drivers
Apr 24, 2008 | Zebra 105SL Thermal Label Printer
Internal error 11
Is your printer connected directly to your PC? I?ve found some literature that suggests this is or is related to a communications problem. I would suggest removing the printer and reinstalling it from scratch. If you run into problems try another cable, remove all other USB devices (if you?re using USB to connect the printer) or if using a parallel cable switch your parallel port to ECP or bi-directional printing mode. Let us know if this helps and please don?t forget to rate this post.
Feb 15, 2007 | Samsung ML 7050 Laser Printer
112 people viewed this question
