Question about Panasonic PT-51HX42 51" Rear Projection Television
Green ark on bottom of screen sometimes looks like a hourglass on its side
    President:
  • 788 Answers
Your symptoms sounds like intermittent convergence IC.
There are two very large IC’s that control the convergence in this set. They are secured to a very large aluminum heat sink. They are on the left hand side of the set as you face the back on the signal board. The convergence IC’s will have a white number stamped on them that will be like STK392-110 or some kind of number like that.
What happens in the Panasonic set is that the convergence IC’s will short and cause the power supply to shut down from the overload of current. You will want to repair the set before this happens.
If you have a low wattage soldering iron, and you want to fix this yourself, let me know and I can help you with any questions that you may have. You may be able to rework the solder connections on the convergence IC’s and that will take care of the problem.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Posted on Jul 11, 2009
Picture has hourglass look and has split screen picture hourglass comes and goes but split screen is continual
If hour glass on conventional set it is either pincussion circuit or power supply---by split screen if you mean folded over top to bottom in the middle that is in the same areas.
Apr 06, 2012 | ESA EF427E TV
How do i close window messenger so as i can install adobe flash player 10.2
find the picture icon for the messenger on the bottom right side of your screen near the clock area. Sometimes you will see a down pointing arrow instead. Click on this arrow to open the area and locate the picture of the windows messenger. right click with your mouse on the messenger and choose "exit" and this will close the program.
Mar 21, 2011 | Computers & Internet
R56wh78 has what looks like waves on the bottom of the screen and the rest looks like a hourglass or in 3d What could be the problem?
Sounds like one to three little fuses around the flyback transformer has gone bad. These three fuses are side by side. Usually for and experinced tv tech, about a 30 minute job and he is gone. Flyback transformer can hold a great punch, so I tell people not to do this unless they understand about electrical risk!!!
Aug 09, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Have you ever had this problem?
Sorry Ginko, but a convergence problem would have the curves down from the top and up from the bottom. The hourglass shape is a pincushion problem. This can be as simple as a bad capacitor in the pincushion circuit.
Could you please confirm the model number so I can look up the probable part?
Thanks,
Dan
Jan 08, 2009 | RCA F32632SB 32" TV
Model 43FDX01B double vision with red ark across bottom . and no user manual.
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 10, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Mitsubishi prjection screen WS-65908
You have a convergence problem,all this sets show this problem sooner or later,you have 2 or 3 amps for the red,green blue colors and this amps go bad and need to be replaced then you have to do a convergence aligment from the service mode and not form the customer controls,a qualified tech should be able to correct the problem since is a common one.
Sep 09, 2008 | Mitsubishi WS-65908 TV
Tv is making sparking noises and keeps turning itself off. It then turns itself back on and off and on again. The screen sometimes goes green during this process
hello. it sounds like you have a couple of thing wrong.!!! one there is a bad fly back transformer.!!! that's arking on to part of the mother board.!!! that's the sparking sound you hear.!!! two is that you have a BAD GREEN CTR GUN.!!! THAT MIGHT BE WHERE THE FLY BACK IS ARKING ON.!!! THAT'S WHAT MAKE'S THE SCREEN GREEN.!!! IT'S SHORTING THE GREEN CTR GUN OUT .!!! & WHAT EVER YOU DO .!!!! DO NOT TRY TO SEE WHERE IT SHORTING FROM !!!.THE HIGH VOLTAGE FROM THE FLY BACK TRANSFORMER .!!! IS NO JOKE.!!! IT CAN KILL.!!! OR PUT IN THE HOSPITAL.!!! THIS IS NO JOKE.!!! SO LEAVE IT TO A SERVICE REPAIR MAN.!!! PLEASE .!!!THANK YOU.!!! "GOOD LUCK"
Jul 30, 2008 | Televison & Video
Panasonic PT-51HX42 51" Rear Projection Television Logo
54 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
