Question about Karcher 2500 PSI Pressure Washer
Stalls after running for a while
I have a John deer 3000psi pressure washer with a Honda Engine. It starts up fine and has good pressure for a little while, then the engine will start revving up and down and the pressure drops then it will stall.
SOURCE: Katcher pressure washer w/ 5hp Honda Engine
pour a bottle of carburettor or fuel injector cleaner in the fuel tank, replace the spark plug and set the spark pluglug gap at 0.7mm. Replace the air filter element. Also change engine oil if necessary (mobil 10w30 synthetic.
Posted on Feb 03, 2009
SOURCE: engine keeps shutting down
Most Honda engines have an oil pressure switch that prevents engine damage due to low/no oil pressure. Make sure there is sufficient oil in the engine and that the wire is connected to the pressure switch.
Posted on Jun 01, 2009
MNfisherman
  • 11896 Answers
SOURCE: I have a problem with my karcher 2500 pressure
Carb is mostly likely gummed up and should be cleaned. Best option is to dismantle the carb and soak in solvent or equivelant for a couple hours and replace it. Our use Gum Out. Do make sure you have a good spark plug and a strong spark. If you have a fuel filter, then replace it. Check intake filter as well
Posted on Aug 05, 2009
  • 174 Answers
SOURCE: Karcher G 3000 BH Engine Pumping Problem
This may not be a motor problem. It sounds like your pump is not working properly and the motor is just following the pump. First thing to do is check for leaks in the pump, wand hose, gun etc. It may also be a blown water seal inside the pump.
Posted on Aug 18, 2009
SOURCE: EXCELL VR2500 power washer runs and then stops
I had the very same problem and nobody could help me until I was talking with a co-worker. Its a very easy fix. I couldn't believe it. I did this yesterday and it ran like a charm. You can either replace the head gasket or just by a good sealer to use on your existing gasket or replace it. I use Indian head gasket sealer on mine. The bolts on the bottom were lose causing a loss of compression. If you need more info you can email me (for free) and I will tell you exactly how to do it. Agr8flson@aol.com
Posted on May 31, 2010
John deere pressure washer will start up and run fine on half choke. After a short time i open up the choke full open. The dump valve works fine but when i squeeze handle on wand to work the motor shuts...
Mine run like that right from the factory so I just left mine on half choke. The store told me it has something to do with the settings at the factory. It was set to run in a certain country with the air pressure. They told me to run it on half choke. all the time.
Jun 17, 2018 | John Deere Garden
John Deere 310E backhoe stalls soon after startup.
indicates air in the pump
very slow leak to allow pump pressure to drop to a point where it starts but then the supply is below requirement until the continued cranking removes the air and then the engine starts and runs
Jun 01, 2018 | Cars & Trucks
84 john deere 410b stalls out
could be something floating around but did you fuel it one day and not the other try and run it with the gas cap off there is a vent on the cap that gets plugged
May 13, 2012 | John Deere Garden
Karcher 2400 psi with honda motor started up big puff of white smoke from exaust it shut off noiw wont start whats going on
I have a john deere 3000psi pressure washer with similar problem. Running fine then a puff of smoke and it shut down. I checked the oil and found it full of water. Not only that but since I still had the water turned on, the water was flowing out of the dip stick tube. I'm trying to find a solution online and will pass any information on.
Nov 13, 2010 | Karcher 2500 PSI Pressure Washer
John Deere 3000psi pressure washer stalling
Mine is having the same issue...I googled and found this with no answers. I'll update if I can find a cure on my own...
Have you checked your oil level?? Small engines have a cut-off switch if your oil is low...mine is topped off so this is not the solution for me..but it could possibly for you.
May 01, 2010 | Garden
John Deere 3300 PSi pressure washer shutting off while in use.Everything appears fine Oil level,Gal level,Air cleaner ok etc.. May run 2 minutes or 12 minutes then spudders a bit then Bang "Off" as if i...
John Deere will replace the cap for free; they acknowledge the vendor who supplied Briggs & Stratton gas caps provided faulty caps. Call 1-888-228-3068 then 1 (English), 2, 1 and a technician will ask you for model number and Serial Number (which they need to replace the cap). Don't drill a hole in your cap: debris will find a way into the gas tank and end up possibly fouling the engine. Bob from NJ
Nov 03, 2009 | Dewalt 3800 PSI Pressure Washer
John Deere tractor stalls when I let up on the clutch.
when you let the clutch out and it stop engine it could be a safty switch. but a safty switch would not make it stop after it was runnig unless you have a short in the wire.
Jul 06, 2009 | Garden
Water comes through nozzle, but no pressure. it is a john deere, with a honda engine.
The engine doesnt matter. Most pumps are DeVille Bliss. Get the model off the pump and go to their website for trouble shooting information.
Apr 22, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
199 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Tim Venetis
Are you a Karcher Garden Expert? Answer questions, earn points and help others
