Question about Samsung L100 Digital Camera
Digital camera I've got this digital cam SAMSUNG L100..when the memory is in the cam I can fully see the pictures but when i've tried to connect the usb to download pictures, it wont show anything..it said the memory has been protected I dont how to open it.. please try to help me
Personally i never connect the cam to pc using the usb cable, i take the memory card out and put it in an sd card usb adapter, you say the images are protected, this tells me that you have the lock switch activated on the sd card...hope this helps :)
Posted on Oct 04, 2009
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
I have a samsung l100 cam.but my cusine destry the lens.so what can i do please say..........................
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 25, 2011 | Samsung L100 Digital Camera
My camera did not come with a usb cord so how can i get the pictures off of my samsung l100? With my memory card? If so, how would i do that?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Dec 13, 2010 | Samsung L100 Digital Camera
How do u download pictures from my samsung L100 camera
Nov 28, 2010 | Samsung L100 Digital Camera
When I connect samsung camera L100 WIN XP SP 3 does not detect any external device connected? Please give any solution I tried devise management option already.
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Sep 05, 2010 | Samsung L100 Digital Camera
Card error on L100 samsung camera, help please.
copy all the pictures/files saved in your memory card to your PC then format the card, you can format the card by going to MENU > SET UP > FORMAT
make sure that you have a copy of the files in the memory card because formatting the memory card will erase all the files that are saved in it.
Mar 04, 2009 | Samsung L100 Digital Camera
Samsung L100 digital Camera
remove the memory card and slide up the lock at the side of it
Jan 28, 2009 | Samsung L100 Digital Camera
Unable to download pics on my Samsung L100
have you check if you are using the usb cable or the av cable. the camera will not show anything on the screen if you are using the av cable and connect the camera to your computer.
Jan 11, 2009 | Samsung L100 Digital Camera
My samsung l100 memory is full after 4 photo ? i have no memory card
you have your "picture size" set too large. In the pic settings you can change it to take more or less pictures, depending on the quality you want. A better photo will take more memory. If you don't want to print your photos, put your setting on smaller size, and you will be able too shoot all day.
Dec 29, 2008 | Samsung L100 Digital Camera
Samsung l100 silver can be used as web cam?
this particulat model cannot be used as a web cam, when you connect it to your computer it is detected as a removable device not an imaging device
hope this helps
Dec 25, 2008 | Samsung L100 Digital Camera
Samsung L100 Digital Camera Logo
Top Samsung Cameras Experts
Computer Links
Jerry Z
Are you a Samsung Camera Expert? Answer questions, earn points and help others
