4-cyl. 128k. 5-spd. Changed fuel filter. AC works. It does drag a little creating some loss of power but that is not an issue. Idle is ok but of course, not perfect, not always steady. Air filter changed. Cleaned EFI chamber. Cleaned cap, rotor, distributor electronics under cap. Minimal oil under distr. cap. I know that next I need to check for spark loss during rain and fuel pressure. I am avoiding purchasing any more parts because of uncertainty of problem. More diagnostics needed.
Most common problem is old/defective distributor cap and ignition wires. Use a spray bottle with water and spray distributor cap and ignition wires with vehicle running. If they are causing your problem you will see arcing from the wires and the vehicle will stumble/stall when the cap/wires get wet
1. Add extra oil when replacing filter. After refill check oil level.
2. With engine automatic transmission operating temperature, shift through all gears.
Check fluid level in NEUTRAL and add fluid as needed.
3. 1984-1992 Models with command-Track, add 5 oz of 75W-90 GL-5 to shift motor housing opening.
TORQUES
Oil Drain Plug.....25 ft-lbs
Manual Transmission T176
Fill Plug.....15 ft-lbs
Drain Plug.....15 ft-lbs
Manual Transmission SR4
Fill Plug.....20 ft-lbs
1980 JEEP CJ-7 4.2L 6-cyl Engine Code [C]
CAPACITIES
Engine, without filter..........5.0 quarts[1]
Wix Filter..... 51522
Cooling System, Initial Fill..........11.0 quarts
Automatic Transmission, A904, 30RH Initial Fill..........4.0 quarts[2]
Automatic Transmission, A999, 32RH Initial Fill..........4.0 quarts[2]
Automatic Transmission, Total Fill
3 speed A999, 32RH..........8.4 quarts
3 speed A904, 30RH..........7.0 quarts
Manual Transmission, 4-SPD, SR-4..........3.0 pints
Manual Transmission, 4-SPD, T176..........3.6 pints
Differential, Front..........2.5 pints[3]
Differential, Rear..........4.9 pints
Transfer Case,..........4.0 pints
TORQUES
Oil Drain Plug.....30 ft-lbs
1980 JEEP CJ-7 5.0L 8-cyl Engine Code [H]
CAPACITIES
Engine, without filter..........4.0 quarts[1]
Wix Filter..... 51258
Cooling System, Initial Fill..........13.0 quarts
TORQUES
Oilman
