Question about HP PSC 1610 All-In-One InkJet Printer
Print carriage is not coming to the center when print cartrige is removed.
  • 3,741 Answers
Check out for any paper piece blockage or any object ,dust blocking the carriage to move.or also it can be possible that carriage belt is either slipped from its position or gor brocken.check out.
Posted on Jul 11, 2009
Print heads
Open the Front access door. You will be able to see the inside of the printer ( the carriage ).
You will find few options on the Printer Screen. Choose - Replace/Remove Printhead. The Carriage will come to Center and you will be able to remove it with the latch.
Regards,
Sean
Apr 22, 2013 | HP Officejet Pro L7780 All-In-One InkJet...
How do I remove the ink cartridge from my HP 2410 printer so that I can replace it with a new cartridge?
Hi milsyr, 1. switch on the printer
2. Lift the blue/gray latch on the cartridge carrier and remove the cartridges you need to
replace.
3. Remove the pink tape from the new cartridge.Hold the cartrige so the label is face
forward,and the words are facing you.
4. Slide the new cartridges into the print carriage.
- The color cartridge goes into the left side of the carriage and the black
cartridge into the right side of the carriage.
5. See that you slide the cartridge underneath the metal bar and then push it down
into place with your fingers.
6. Close the cover on top of the cartridges and make sure the latch is secure.
7. Close the printer carriage door.
8. Press ok on the front of your printer.
- An alignment print will follow.
THANK YOU AND GOOD LUCK!
Sep 04, 2011 | Office Equipment & Supplies
Error message: Service Call Error 00010005
This code is usually appearing when the carriage for the print cartrige is restricted by any foreing object or by displacement one of the print cartrige that is rubbing on top of the cover,
Open the cover and make sure the carriage is free of anything try to move it manually to see what can cause this blocage Hope this answer your question Please remember to Rate/vote for any solution that helps you out. Leave a comment if you need more help. Thanks for using Fixya
Aug 16, 2011 | Office Equipment & Supplies
I have inserted both my blacl & colour cartriges properly but still my printer is showing some problem with my black cartrige
When ink cartridges get low they can dry out if you do not print that frequently. So try a new cartridge. Make sure that the carriage is clean, wipe down the copper contacts on the carriage under the black cartridge with alcohol. Also ensure that the cartridges themselves are not all coated in ink.
Dec 03, 2009 | Office Equipment & Supplies
Magenta and yellow ink not printing on test print
Print head is probably plugged. With caution (this can ruin your printer if you get too violent) take a Q-Tip wet with rubbing alcohol and touch the printhead where the ink tranfers to the paper. To get access to the cartridge open the cover and when the carriage moves to the center unplug the printer. The alcohol may soften the dry ink enough to get it printing again. If it starts printing again do a print cartrige cleaning with the software included with the printer.
Jul 11, 2009 | Canon i860 InkJet Photo Printer
We reciently bought new ink cartriges and now when we try to print nothing is printed. There are no error messages on anything either....the paper just comes out blank. We also tried changing the ink...
Try reseating both ends of the printer cable.
Assure that there is nothing in the cartridge carriage to block the contacts and/or cause a seating issue.
Jidza
Jan 20, 2009 | Lexmark X5150 All-In-One InkJet Printer
How to change a cartridge on c4345
Installing new cartridge:
If you are putting in a new cartridge, make sure to remove the tape.
Turn on the unit, then open the print carriage access door. The print carriage moves to the center of the unit.
Fit the cartridge into the proper carriage.
The carriage with the gray latch is for the black ink cartridge (HP 56), or the optional photo cartridge (HP 58).
The carriage with the blue latch is for the tri-color cartridge (HP 57).
Slide the cartridge into the carriage at a slight angle, as shown in the illustration above. When the cartridge is fully inserted into the carriage, rock it upright.
Hold the hinged flap of the latch out while lowering the latch.
When the latch is fully lowered, release the hinged flap. It should catch under the tabs on the carriage, as shown in the illustration.
Close the cartridge access door.
The LCD display may indicate that the cartridges need to be aligned. Press Enter on the front panel. You may discard the alignment page that prints.
Remove cartridges:
Press down lightly on the top of each ink cartridge latch and pull the lower section of the latch out to release the cartridge.
Pull the cartridge out of the print carriage and relatch the empty print carriage. The print carriage may move to the right automatically, and if the latch is up, it could be damaged.
Nov 26, 2008 | HP Office Equipment & Supplies
CANON FAX JX200
remove the cartridge and see if it goes away, if does then you probably have a defective cartridge are are not inserting it correctly.
Thank You,
Mikey
Apr 04, 2008 | Canon FAX-JX200
Photosmart 335
Open the cover up where the cartrige are , the carriage will get to the center, then take the cartridge out close the cover.
Turn the printer off then on , put the cartridge back. try it
Mar 26, 2008 | HP Photosmart 335 InkJet Printer
Printer is not working
Hold set-up button and , still while holding set-up button, press the option button, should be ready to go now!
Nov 07, 2007 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 1610 All-In-One InkJet Printer Logo
35 people viewed this question
Clive
Clive
