hi Jamiekom. Slow Running Computer Fix. Use MSCONFIG to improve computer's speed at startup. You can disable certain programs that auto-start at startup and spend less time waiting for your computer to fully boot. Simple tip to improve your computer's performance. Why is computer so slow to startup?
My Windows computer boots up slow. A slow Microsoft Windows boot up can be caused by a number of different issues. The following document contains various suggestions and tips that can help improve the overall speed of your computer's startup.
Why does it take so long to boot up my computer?3. Upgrade your hardware. A new computer is naturally going to start up faster because it has faster hardware, and a clean operating system. ... As we said above, computer startup is slow because you're moving information from a slow hard drive to faster RAM Computer running slow at startup Check out this Quick Tip My Windows computer boots up slow computer slow on start up Google Search
for whatever reason you require both office suites (may be due to compatibility for DOCUMENTS access, perhaps) , you cannopt have both versions installed on same computer and operate the PC effecctively without issue, unless you have dual boot system . Dual boot (Winodws XP and Vista on same PC, for example) may be your only option to allow these two suites to run simultaneously while running one OS at one time. does this help ? if so , please sne me 4 thumbs up.
Hi, your best bet is to start XP in safe mode, or, if that does not work, do a repair after booting from your installation disk.
To use a Safe Boot option, follow these steps:
Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
Here are some things you can do that will boost your performance back to normal. First, go into Start>All programs>system tools and run Disk Cleanup. This will get rid of all of the junk like *.tmp files that has built up. Second, in the same place after you run DiskCleanup run Defrag. This will take care of all the gaps on your hard drive so data can be found more easily. Finally you need some more RAM. 1GB these days with all the intensive programs is minimal especially if you have a 250GB HDD. Means if you load that puppy up your access time will be very slow with only 1GB. All programs load into RAM when they run, so with only 1GB your system has to constantly keep going back and forth to your hard drive to get code and that makes it very slow. Hope this helps and thanks for using FixYa. If you have any problems let me know.
you have to use a standard windows start up disk with cd rom support like win 98 works well so the computer will recognize a older version then insert it and boot the computer with the operating system that u want to install but be advised if you have a warranty on the machine you will void the waranty i found out the hard way i had xp on my toshiba laptop and i put windows me on it couple of months later i had a cd rom issue and sent it to the manufacture and found out that the waranty was voided because i put a different operating system on the machine
