Question about Sharp AR-M205 Copier
How do you install a Drum in a Sharp AR-405 copier? Is this really the cause of streaking?
    Scholar:
  • 175 Answers
The drum is very sensitive and can be damaged very easily by scratching it, touching it (oil from our skin) and being exposed to light. Streaking could be drum and/or blade, but it could also be fusing, optics and other things.
Posted on Jul 12, 2009
Can you print through a wireless connection on a Sharp AR-405?
You first would need to make sure the machine has the opional printer expansion board installed. Make sure you have ethernet connectors on the rear leftside of machine. If so you could possibly install a wireless bridge to the machine if your network supports it. Some networks such has Verizon blocks them. A bridge is about a $100 dollars and they walk you though the install just follow the directions.
Aug 30, 2011 | Sharp AR-M205 Copier
My Sharp Copier Model AR-M160 showing f2 error even I replace the new tonner.
Below are the F2 errors and causes for Sharp AR-M160
"F2-31" Image density sensor fault
"F2-32" Drum mark sensor fault
"F2-33" Grid voltage correction problem
"F2-35" Grid voltage correction problem
"F2-37" Drum mark sensor fault
Cause : CRUM chip defect OR Improper developing unit
Check and remedy : As you have already replaced the tonner, we can suggest Replace the CRUM chip,Replace the developing unit
Regards,
Shrey
Jun 01, 2011 | Sharp AR-M160 Laser Printer
Streaking problem on Sharp Copier SF-7321
Clean the optical mirrors on the scanning side and also remove the drum and clean a mirror beneath. Check also the drum condition and replace if necessary.
Dec 21, 2009 | Sharp AR-5320 Black and White Copier
We have a Sharp AR-M277. The screen says maintenance required.
Hello sir; Which means is you need a PM that including replace drum, drum blade, developer, corona wire etc. very complicate, if you really interest let me know, I'm happy to give you instruction.
Oct 26, 2009 | Sharp AR-M277 Digital Copier Copier
My copier is a Sharp SF Model 2215. I replaced
It is the drum.
Reasonable cost? That's up to you.
Call a few service depots and ask. Then decide if you want to invest the cash.
Jul 14, 2009 | Sharp AR-M205 Copier
Black blotches and streaks on copies
Sounds like a worn drum unit primarily the cleaning blade on the drum is failing. If you don't change it out soon the dirt escaping from the drum and dirty copies will foul-out you fixing unit, = more $$.
Jul 09, 2009 | Sharp AR-5316 Advanced Digital Imager...
On a sharp arm 257 can you a drum unit or just blade and drum
Did you mean drum frame unit ? This frame include all the spare parts of drum unit except drum and drum fixing plate. The code number is AR 310 DU ( DRUM FRAME UNIT ).
DRUM : AR 310 DR
CL. BLADE : AR 271 AK
DEVELOPER : AR 271 SD
Jun 03, 2009 | Sharp AR-M237 Copier
Sharp ar 405 u2-11 error
Content Counter check sum error (EEPROM)
Detail Checksum error in counter data area
Cause EEPROM defective
Control circuit hung up due to noise
Defective EEPROM access circuit on
PCU PWB
Check Check EEPROM for proper set-up
and To prevent the erasure of counter data
remedy and adjustment values, write down the
counter data and adjustment values by
simulation. (If there is a printer option,
execute SIM23-1 and note counter
data/adjustment values.)
Clear U2 trouble with SIM16.
Replace PCU PWB.
May 22, 2009 | Sharp AR-405 Printer
Sharp sf 2114 too much toner on copies
Sound like you need to have the developer, drum and drum blade replaced, you might want to have a tech look at this.
Hope that helps.
Lbcoaster
Nov 13, 2008 | Sharp AR-5316 Advanced Digital Imager...
Narrow streak down page
Take a look at the drum on you copier by opening up the right door. Do you see a line on the green drum? If so, your drum should be replaced.
Sep 15, 2008 | Sharp AR-153E Copier
Sharp AR-M205 Copier Logo
96 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
George Mclaughlin
polytek
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
