Question about Philips Magnavox 51MP392H Rear Projection Television
Can you replace the picture tube on a big screen maganavox tv?
Can you replace the picture tube on a big screen magnavox tv?
  • 3,741 Answers
Yes it can be replaced.but the tubes are costly to get replaced.you can get the parts at www.partstore.com or at www.shopjimmy.com thanks.
Posted on Jul 11, 2009
Yes my philips magnavox big screen tv is real
This TV needs the coolant changed. There is a layer of coolant between the face of the picture tube and the projection lens that degrades over time causing the picture to become less than perfect. This is a complicated repair because the picture tube and lens assembly has to be removed from the set and disassembled. Best left to a professional. Thanks for using fixya. Please take a moment and rate this solution.
Dec 04, 2009 | Philips Televison & Video
Phillips magnavox big screen rear projection tv
Base from the description that you gave us this is really a symptoms of a bulb that is going bad and needs replacement already, because it will just go bad dark as time goes on so it will be better for you to have the bulb replace as of now ....
Good luck.........
Aug 17, 2008 | Televison & Video
Magnavox big screen has dull picture and colors are not clear. Cloudy picture and has a green film of color over screen. this ia a 64inch big screen. What can
This is especially common with Phillips/Magnavox - A foggy image usually suggests that the coolant in the picture tube(s) (1or all 3) has become discolored and needs to be replaced. The only way to check this is to look directly into the crt faces (disassembly required) to see the condition of the fluid (coolant).
It's a relatively big job that shops charge between $300-400 - Get an estimate. See link for Kit
http://www.tvrepairworld.com/crt_coolant
Nov 06, 2009 | Philips Magnavox 27MS343S 27" TV
I have a magnavox big screen tv the picture is pretty dull. I was wondering how i can fix that problem
First try cleaning the mirror and the tops of the picture tubes. If this doesn't help, you'll probably have to change out the CRT coolant.
good luck
Sep 02, 2009 | Televison & Video
MAGNAVOX 2GB MP3 PALYER
I have a magnavox mp3 player and it turns on and shows just the magnavox sign then shuts off what should i do
Jun 08, 2009 | Philips Magnavox
Bad color suddenly appeared on Maganavox 437S 52 " Flat Screen HD
it should have a year warranty get it in for warranty repair before the warranty runs out or someone tells you the wrong thing to go and the tv ends up as a big paperweight...
Dec 28, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Big screen problem
http://servicemanuals.vstore.ca/index.php/cName/phillipsmagnavox-tv-parts
Jul 21, 2008 | Philips Magnavox 9P6034C 60" Rear...
Black screen no sound
What is the model or chassel number it be a few thing H.O.T Resistor Caps etc..most likely horizontal output transistor.
Nov 12, 2007 | Televison & Video
Tv has a big black in yhe middle,does that mean that the picture tube is going out
no that is not the sympton of picture tube failure. please give the details of your problem so we will get you solution.
Oct 07, 2007 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 51MP392H Rear Projection Television Logo
915 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
