Question about Canon imageRUNNER 5570 Copier
E000004-0010 Press the (shut down) key. After the machine has shut down, turn the main power switich (on the main units right side) OFF & ON again
  • Anonymous Apr 21, 2008
    The iR 5570 photocopy machine displays E000004-0010 error code so please help me on how to reset the machine.
    thankyou
  • alexmel Sep 08, 2008
    Since it switches OFF the copy with in a minute, I could not try any thing.
Canon NP 6330
error 800
Posted on Jul 24, 2008
  • Canon Master
  • 1,113 Answers
I'm not a Canon Copier Tec but I know E04's on Canons generally means heat/fuser error - ie fuser, usally fuser lamp, thermister or thermal fuse. Have fuser replaced.
Have it looked at, due to it requiring electrical knowledge, ie test heater lamp(open), thermal fuse(open), thermister(check for toner built up on face) with the user removed from printer (fuser=hot bit that paper goes threw, just before where paper exits to go to sorter) or just replace assem.
There maybe a reset required, on some canon models after problem has been fixed.
So here is a link with explaination of the reset on a canon model simular to yours http://www.copytechnet.com/forums/canon/2673-error-code-e004-canon-np-6330-a.html
Posted on Nov 15, 2007
Please I want the code error of canon photocopy 6330
please send to my email : altaliby@yahoo.com
Posted on Jan 31, 2009
C-3725 trouble code
The fusing unit in side machine has reached a very high temp. This is the unit which fuses the toner to the paper the hot part upper right hand side of the machine. to reset follow:
Utility
1.Power off the machine using the main power switch inside front door leave sub power switch on that's the one on the op panel side.
2. Hold down the Utility/counter button.
3. Power on using main power switch and close the door.
4. wait for screen to show trouble reset touch trouble reset chk for OK
5. turn off main power switch, wait 10 seconds then power it up again. it should restart and go ready to copy. if the code comes back do not reset the machine again. It is informing you there is a problem get it looked at.
Jun 01, 2014 | Konica Minolta KONICA BR BIZHUB C451...
How do I replace a Fuser ?
Sir/Madam
The Problem Is Very Simple ,You Need To Follow Few simple Step To Fix This Issue
  • Turn off the machine's power switch. To avoid injury, wait until the machine has cooled down sufficiently before you replace the fusing unit.
  • Open the back cover (1) and the scanner unit (2) of the machine.
  • To release the fusing unit from the machine, release the lock levers that are on both sides of the fusing unit.
  • Hold the handles on both sides as you take the fusing unit out of the machine.
  • Put the new fusing unit into the machine. Be sure to insert the fusing unit completely into the machine.
  • Secure the fusing unit with the two lock levers that are on both sides of thefusing unit.
  • Move the fusing unit pressure release levers to the Set position.
  • Close the scanner unit and the back cover.
  • Turn the machine's power switch back on
  • Press the Menu/Set key.
  • Press the up or down navigation key to select Machine Info. and press Menu/Set.
  • Press the up or down navigation key to select Reset Menu and press Menu/Set.
  • Press the up or down navigation key to select Fusing Unit and press Menu/Set. The confirmation message appears on the LCD.
In case You Need More Help Then Go To Official Brother Printer Help Page Below:
http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faq/000000/000000/000021/faq000021_002.html?reg=eu&c=eu_ot&lang=en&prod=mfc9420cn_all
Or If You Still Facing Problem Then Follow Us On:
Brother Printer Support
Jan 08, 2014 | Brother HL 2270DW Laser Printer
Sc fusing error dsm615
you can try to reset the code by entering into service mode, just enter into service mode and then shut down the machine by the main switch and then turn it on after 30 seconds.
For to enter into service mode press the following keys in the next order:
press the yellow key ; then press 1-0-7 and then press the red key and hold it pressed until on the screen do not show service mode.
If after this again the machine gives fusing error, it means that you have problem some part in the fusing unit. possible is the termistors or the teromstats
Nov 23, 2013 | Ricoh Aficio 2015 Copier
My computer keeps shutting down irreglarly
Hey Henry,
Try reseting your PRAM and SMC.
Here's how to reset your PRAM:
  1. Shut down your machine. Yes, all the way down, not sleep or logging out.
  2. Press the power button and then press command-option-p-r. You have to make sure you get those keys pressed before the gray screen comes up or it won't work.
  3. Hold those keys down until your Mac reboots again and you here the startup chime.
  4. Let go of the keys and let your Mac reboot normally.
For SMC:
  1. Turn off your machine
  2. Keep the MagSafe adapter plugged in.
  3. Press at the same time shift-option-control (on the left side of the machine) and the power button
  4. Let go
  5. Turn your machine back on with the power button.
Nov 16, 2013 | Apple MacBook Pro Laptop Computer with...
You have to press 3cm to the right of the intended button on the touch screen. how do you fix it?
Turn the main power switch on the back of the machine off and leave the power switch on the left side on. Make sure no F-rom cards with firmware are in the machine. Press and hold energy saver and function keys down, turn the main power on in the back of the machine continue holding keys for about thirty seconds. The lcd blinks and shows a + on the upper left, press the + sign then one + sign on lower right edge and then one + sign in the middle. If the + sign goes away try the procedure again. Once it is calibrated reboot the machine and touch the Lcd in different spots to see how it works. Hope this helps.
Jun 30, 2011 | Panasonic DP-8045 Grayscale Copier
How do I replace the brother fuser?
    The fusing unit and the parts around it are hot! Be sure to wait until the fusing unit has cooled down sufficiently before replacing the fusing unit. If you touch the hot parts, you might get injured.
  1. Turn off the machine's power switch. To avoid injury, wait until the machine has cooled down sufficiently before you replace the fusing unit.
  2. Open the back cover (1) and the scanner unit (2) of the machine.
  4. To release the fusing unit from the machine, release the lock levers that are on both sides of the fusing unit.
  6. Hold the handles on both sides as you take the fusing unit out of the machine.
  8. Put the new fusing unit into the machine. Be sure to insert the fusing unit completely into the machine.
  10. Secure the fusing unit with the two lock levers that are on both sides of thefusing unit.
  12. Move the fusing unit pressure release levers to the Set position.
  14. Close the scanner unit and the back cover.
  15. Turn the machine's power switch back on.
  16. Press the Menu/Set key.
  17. Press the up or down navigation key to select Machine Info. and press Menu/Set.
  18. Press the up or down navigation key to select Reset Menu and press Menu/Set.
  19. Press the up or down navigation key to select Fusing Unit and press Menu/Set. The confirmation message appears on the LCD.
  20. Press 1 to reset the life counter.
  21. Caution
      Please be careful when replacing the fusing unit. Do not put pressure on the fusing unit; it should go in easily. If it does not, make sure the fusing unit connector is free to move.
      Do not apply force! It could damage both the fusing unit and the machine.
Feb 02, 2011 | Brother IntelliFAX 4750 Plain Paper Laser...
Error code sc548
Enter SP 5810 (SC code reset), select “Execute”, select “close”, exit SP mode then turn main power switch off and on.
to enter SP mode press yellow C button press 1 0 7 on numeric keypad and then hold down the orange C button from the menu select copier SP then type in 5801 and press # selest execute then power off and back on. Your machine should now be working. Hope this helps.
Jul 08, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
ما معنىE_5
When the copier displays "E-5" in the copy
counter. Hold down the "·" key, and two digits is displayed in the copy counter. so tell me what are the two other digits for i to can help you because e5 code have about 20 it can be the fusing unit or the main motor or the lift motor for the paper trays
so you should tell me the two other digits for i to can help or if is the fusing unit you can simply enter the service menu and shut down the machine and turn it on again for to enter in the service mode you should press the follow buttons one after other:
1. yellow key [cancel modes ]
2. press 107
3. press and hold the red button [stop] until all light star flashing.
4. then turn off and turn it on again the copier
Apr 23, 2009 | Ricoh FT5832 Copier
RICOH FT5832 ERROR CODE E-5 47
With the machine on, press clear modes(yellow button), 107, and then hold down clear/stop (red button). Enter 5810 then # key then 1 #. Turn off the main power then power back on. This code is a fuser lamp on condition. It should clear. If not reseat the fuser unit (gets hot), clear using above procedure and try again.
Apr 08, 2009 | Ricoh FT5832 Copier
Canon imageRUNNER C2058 color network printer board-B1 only. Upon power up the display screen indicates "Wait...".
The printer Board B1: you must shut it down by hitting the Options button and then selecting Function >Shut down > Shut down sytem>OK. Then power the machine off with the main switch. If the Customer has not been shutting off the machine properly and you get the please wait message you might try reloading system software first before replacing the hard drive.
Or = remove and reseat the printer board, if that doesn't work then you'll have to reformat the HDD unit and reload system software from a laptop. If the problem remains, the printer board may need to be replaced.
The Color Network Printer Board -B1 has a shut down function. It is for preventing corruption of the HDD. Be sure to turn off the main power switch after performing shutdown.
To properly shut down the Color Network Printer Board -B1:
1. Press the Option key on the control panel if the copier is in copier mode.
2. Make sure that the LCD reads Idle.
3. Select Functions on the LCD.
4. Select Shut Down from the Functions screen.
5. Select Shut Down System from the Shut Down screen.
6. The message 'It is now safe to power off the system' appears on the screen.
7. Power off the main power switch located on the lower right side of the copier.
* Note- After powering off the copier, wait at least five seconds before powering the copier back on.
Jan 25, 2009 | Canon imageRUNNER C2058 Led Printer
Canon imageRUNNER 5570 Copier Logo
4,689 people viewed this question
old marine
old marine
