B
Bernard Colgan Posted on Jul 09, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can thermal papers be recycled?
Hi all, As I am using a huge amount of these products in my retail shop from Discount Till Rolls Ltd, so a little bit confusion in whether the thermal paper roll can be recycled or not. After one use it became like a waste product.
Steve Butterworth
Level 3:
  • Master 938 Answers
  • Posted on Jul 09, 2015
Steve Butterworth
Master
Level 3:
Answers
938
Questions
Helped
240582
Points
3298
I think that the answer is yes.
Changed till rolls and now no reciepts will print
Make sure the paper has a shiny side and face that side to the front as it exits the printer. If no shiny side, you have the wrong paper. It must use Thermal paper (57mm wide)
2answers
What should I consider when choosing a printer?
i only use epson printers, they work well,theres programs out there to reset them and the ink is very cheap. other printers are cheaper but you will pay more in the long run for the ink's
My fd100 wont print but thinks it is. also some times it freezes
if you could check the paper that you are using. make sure thermal. also scratch the paper, if a black mark appears this is the side that goes down in the paper holder, if you don't see a black line you don't have thermal paper. also make sure it is credit card machine and not adding machine paper. if you have another roll try that one. if persist. make sure the paper is hitting the thermal reader. there is no ink
2answers
Till roll re-placement not printing
Try turning paper around or make sure you have thermal paper if it is a thermal printer model
Hi, i have a CASIO SE C2000. The ink is not printing on the reciept. I do have the right till rolls but it just stopped printing. Any ide why?
If it is feeding the paper but it is blank, then you may have the paper around the wrong way. the shiny side must be towards the front. Otherwise, it may not be thermal paper. If it is not feeding out at all, make sure it has not been turned off (paper saving)
2answers
Can you use regular thermal paper rolls in the Dymo 400 turbo printer?
It should work. I have one of those tiny label printers, and thermal paper does indeed work.
Hi. i have a linksys wrt54g v7.0 and i have a roommate who downloads huge amount of data using bit-torrent, but he says he doesn't. how can i stop him from downloading huge data if i have to by only using...
use filter setting of your modem and block site like bit torrent also install networks and check download data and show repport tour friend about download amont link for networks http://www.softperfect.com/products/networx/manual/
2answers
My cash register is not printing.
Hi.
If it is a thermal printer, make sure you have the paper coming from the bottom of the roll, not the top. If you have the paper the wrong way around, it will come out blank.
If this is not the problem, please let me know the model number and any other information you can give.
Mark
1helpful
Paper jam
it takes a little bit of disarming because you've got to clean the rubber rolls that "pull" the paper, a pair of grey rubbers almost cilindrical with a flat side located over the top of the paper, and happens that you cant clean them properly if you dont disarm the printer. These rubbers must mantain their "stickyness" to be able to pull the paper properly and with the use they become dirty.
That is the problem, so take your screwdriver and some isopropilic alcohol and ...........good luck.
k24674
ADMIN Andrew
ADMIN Andrew
