Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
When the control switches are in auto the display says service and the pump doesn't turn when the timers is set to turn on. I can manualy turn on the pump by turning the switch to manual.
    Champion:
  • 246 Answers
Go to the main panel and switch to auto if still not working remove the spa side switch if still not working bad board must be replace
Posted on Oct 15, 2009
My Beko MW5104 is frozen and does not respond to any settings. It is permanently on at spin/end with the green light on. I can switch it on and off. I have unplugged it from the mains and switched it off...
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 28, 2012 | Dishwashers
Jenn air. Quiet seriesii won't start. Lights on panel flashing. Tried turning off power for fifteen minutes at breaker.
I dont know how to set the timer
Question posted under Intermatic T104 series timer and pool control center.
Open following link to see how to set this timer:
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
Intermatic T12404R control center has 2 timers.
Each timer is set same way.
Timer must be reset after power outage. If time dial is not rotating correctly or is sticking at the tripper, then the WG1573 clock motor can be replaced by homeowner.
Both timers are 240Volts, and can be wired in variety of ways to control different voltages. For example 120Volt pool lights, and 240Volt pool pump and pool heater etc.
Each timer snaps out of control center using thumb spring located top inside box.
Each timer mechanism is sold separately. One timer is T104M. The other is T104M201.
The difference is that the 201 has a 'fireman's switch' that can be wired to pool heater, and the switch turns off heater 15-20 minutes before turning off pump.
Each timing mechanism can be repaired by homeowner using available clock motors and trippers.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 11, 2011 | Intermatic Timer T12404R Pool & Spa...
Pool pump cannot be turned off with timer switch. Pump runs constantly. I can turn off with breaker switch but not with switch on timer.
You posted under Intermatic EI200 series countdown timer.
Intermatic EI200 series is rated for 1/4 HP.
Check nameplate on motor for HP. Pool pump is probably 1 HP.
Open following link for countdown timer ratings:
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html
http://www.intermatic.com/products/timers/in-wall%20timers/electronic%20auto-off%20timers.aspx
Add a comment and say what kind of timer you are using and say specifically what you want timer to do, and I will locate correct timer for that specific need.
You can also add a contactor to the circuit.
Timer controls contactor, and contactor turns pump on-off.
http://waterheatertimer.org/Water-heater-contactors.html
Also take advantage of fixya expert assistance live.
Apr 04, 2011 | Intermatic EI220 Electronic Auto Shutoff...
I need to know more about "Countdown - Auto -
Open following link to identify timer
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
59377 manual
http://waterheatertimer.org/pdf/Woods-59377.pdf
Auto: timer must be set in AUTO for programming to work
The word AUTO is printed on timer face.
Small black triangle will display above the word AUTO when timer is in AUTO
Countdown is feature that lets you set timer ON for set amount of time, and when time expires, timer turns OFF.
Manual button.
I have not tested this specific timer.
Simply plug lamp into timer, and then push manual button to explore feature.
Watch what symbols display, and watch what lamp does.
Add a comment for more free help.
Mar 08, 2011 | Woods Industries 59377 Indoor Digital...
Intermatic PF 1102 digital timer with freeze control; Timer will switch from off to on to auto, but when switching to "on' the pump will not turn on. There is a "click" that indicates to...
The freeze control is wired parallel with timer, so both controls can turn Load ON-OFF.
So Load turns ON when either the freeze-control or the timer turns ON.
When both are ON, then Load will be ON.
Freeze control can be ON and timer OFF and Load is ON
Freeze control can be OFF and timer ON and Load is ON.
Only when both Freeze control and timer are OFF, will Load be OFF.
If pump is not turning ON below 32 (or the protection set point), then freeze control thermostat is suspect.
But you need to check if pump turns ON when timer turns ON.
If pump operates with timer, then freeze control is main suspect, unless there is a loose wire.
Open box and check for loose and burned connections.
If pump does not operate with either timer or freeze control, then check for loose wires and also check your circuit breaker and check that pump is operable.
To find replacement freeze control, Google search: Intermatic freeze protection thermostat
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 03, 2011 | Intermatic 24 Hour Electronic Timer
Compool TimeMaster with this control panel Picture: http://is.gd/juMkm Manually turning on or off pump/lights/spa all work, but the auto timers fail to start or stop any functions. Any ideas? ...
The first thing that I see is if you have a service panel, make sure that it is in "auto", not "service" and that all switches are set to off. That is the panel by the pool/spa, not the main panel.
Gary
Dec 26, 2010 | Pentair Pool & Spa
Timer is set properly, but, the daytime lights never switch off
The timer doesn't know what time it is until you set current time.
The yellow outlets are controlled for 12 hours, and you can determine when those hours occur when setting current time.
http://waterheatertimer.org/GE-timers-and-manuals.html#zilla
If you want timer to control one lamp with both day and night schedules, you have to adjust current time setting so lamp schedule falls within a 12 hour period. If that schedule doesn't fit, then buy a second timer.
Absolutely feel obligated to upvote the help.
Or take advantage of fixya expert assistance live.
Aug 07, 2009 | Coralife Zilla Aqualight Power Center
Kenmore Electric Range Model # 790.95664100 All display lights are off until you turn on a heating element control knob. Then the time display starts flashing "12:00" along with a short buzzing sound...
Sounds to me from the information you provided that the auto timer is set...when the auto timer gets set you are generally unable to use the oven. If the auto timer is not set then you are looking at a problem with the Electronic oven control..do any error codes show up f1 - f2 - f3 and so on?
Jun 23, 2009 | Kitchen Ranges
Turns its self off
if your tv has a auto timer turn off you have got to manualy turn it off in the menu setting
May 02, 2009 | Televison & Video
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
114 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
Craig Butler
Craig Butler
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
