Question about GE Profile Spectra JGBP90 Gas Kitchen Range
For the GE XL44 model, where would i find the pilot light? the stove is not working
  • 396 Answers
There is not pilot light on the stove top since the burner is activated by a spark generate by high voltage to a small ceramic disk with a wire protruding from it by the burner.
You have the have AC Power to the stove and you should hear a clicking when you slightly turn on the burner. Once the burner is on fire then turn the burner control to the desired temperature. If the burner will not light after 4 seconds of clicking sounds turn the burner control off and make sure the round gas diffuser on top of the burner is correctly seated on the burner. It should lock in place and is removable for daily cleaning of the stove. Now try the burner control again in the light position for no more than four seconds to see if it lights.
Do you smell gas? Do you hear clicking when slightly turning the burner knob? If yes to both the stove is working and the top of the burner is not seated correctly. If no on either or both you may have a stove, electrical or gas problem.
Posted on Jul 15, 2009
gwshaw71
  • 83 Answers
SOURCE: ge xl44 I think pilot not lit. no more snap - snap and does not light
relace spark module if no snap snap from all burners.If one is just bad replace ignitor.
Posted on Dec 08, 2007
jumptrout51
  • 3361 Answers
SOURCE: Getting to the Pilot
The XL 44 should be electronic spark ignition.
No pilot.
Posted on Feb 22, 2009
SOURCE: GE XL44 pilot
I dont know if you recieved an answer yet but this is a fairly easy fix. Open your oven door and remove your bottom oven plate. You now should see the burner element running down the middle. at the rear of the burner element is the ignite r (small porcelin bugger with two wires) remove this and replace with a new one GE #WB2X9154 available from the repairclinc.com website for 69.80 plus shipping. i just ordered (2) they seam to go out like clockwork every 2-3 years. To be safe unplug your ovens 110 volt cord first.
Good Luck
Jim
Posted on Sep 22, 2009
  • 98 Answers
SOURCE: I have a GE XL44 gas stove the oven will not stay lite why?
That's bad. Sounds like the burner is dirty.
and the gas belive it or not is blowing the polit out it hit it so fast. The gas can't go in the burner. There should be two screws that hold it in place take it off and clean. See if that will work. Let me know.
Ken
heatman101
  • 43501 Answers
SOURCE: I have GE XL44 how do I lightthe oven pilot
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101 .
Posted on Oct 03, 2010
Oven pilot light won't light. Stove burners work fine.
if you have a pilot flame oven replace your thermocouple
if you have a newer oven you will have an ignitor
please advise me on whitch type of oven you have
Feb 05, 2013 | General Electric ge JGBS04BPW wb1k5 Oven...
The oven pilot does not light. The broiler will not work. The only thing that does is the light. GE XL44 range. The burners light and the pilots stay lit.
    If you have standing pilots, make sure the pilot for the oven/broiler is lit as well.  When you turn the thermostat up to call for heat, you should see the pilot get larger. That larger pilot flame heats a hydraulic sensor and opens the main burner valve.
    Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
    My GE XL44 Gas Range (Model JGBP34 GEP 1A) control
    If you like the stove and it in good shape otherwise, have it fixed. The parts are still available. The stove in good used condition (without leak) is probably worth $75.00. May cost that much to repair it. Will cost approximately $450.00 to replace it with equal range. If it's a standing pilot model (no electricity needed) they are unavailable and your new range will require power to use the oven. Hope this helps.
    Dec 07, 2009 | GE Spectra JGBP35 Gas Kitchen Range
    I have a GE XL True Temp gas range/oven. None of
    your stove must be plugged in for the auto-pilot to work .do you hear a ticking noise when you turn on a burner?
    Oct 07, 2009 | GE JGBP28 Gas Kitchen Range
    Where is the pilotlight on a ge xl44 gas stove I belive it is in the door under the oven well I turned the gas on and stuck a flame down there and nothen took off is there a certian place to put the flame....
    In general lets be clear. The OVEN pilot is located under the oven door at the top of the Broiler.It is a small piece of metal just before the GAS safety Valve which acts on temperature so gas won't flow unless Pilot is lit,That's the OVEN PILOT.The stove's RANGE is the top burners where you heat Pots and Pans.It has either 2 Pilot lights that connect the burners to the Flame they are under the Range Top.Newer Models use electronic ignitions no flame.Please note if you had your stove/oven disconected or Gas off when you turn it back on there will be air in the line that needs to escape before you light.This is why in NYC when Utility Co.works on steet main the MUST re-light your appliances.Be Careful with Gas.Good Luck.
    Sep 19, 2009 | Ovens
    Your model JGBP28DED2WH uses spark ignition on the stove top burners, and a glow bar ignitor, part number WB2X9154 for the oven and broiler. To get to the bake ignitor if oven will not light: Take the racks out of the oven. Remove oven floor by removing two screws at back of oven floor and lifting floor. Remove the square metal flame spreader to get to the burner / ignitor assembly. (note: The ignitor may still glow when you try it, but usually is still the problem)
    Feb 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    Stove top pilot light
    I have a GE Gas Stove XL44 the stove top buners don't light by themselves without manual lighting. When I turn on the buner knob the buner doesn't click. Also I used my self- cleaning oven for the first time and stopped it before the time was up after that is when the stove top buners wouldn't light by theirselves.
    Jan 20, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
    Ge xl44 I think pilot not lit. no more snap - snap and does not light
    Nov 21, 2007 | Hotpoint RGB745 Gas Kitchen Range
    GE XL44 Gas Stove
    Hi I have a GE X44 gas stove. The 4 top burners work just fine, but the oven no longer turns on. I don't see the blue flame inside the oven. Is it safe to relight the pilot light?????
    Nov 08, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
    GE Profile Spectra JGBP90 Gas Kitchen Range Logo
    806 people viewed this question
    Top Kitchen Ranges Experts
    Steve Allison
    Steve Allison
    Craig Butler
    Craig Butler
    Sal De
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
