Question about JVC Televison & Video
Fine horizontal white lines across top 4" of screen. Its NOT cable caused, per Cox... On broadcast stations and some cable channels. Not on Letterbox.
  • 1 more comment
  • debfunk100 Jul 11, 2009
    JVC 32730 (I provided this on prior FixYa questions...). Thanks.
    Thanks for your answer. I've never repaired TV before.....Prob have pro do it?....With that in mind:
    (Just so I'm somewhat knowledgable and can figure if repair co. is for real or padding, etc.)
    Are these parts easy to get/common/routine or difficult to find w/ lead time involved?
    Should I order parts myself or rely on pro (incur poss. leadtime & mark up)?
    Approx. $cost/range of parts?
    Approx. amount of time to replace/repair?
    Thanks,
    Deb
    Thanks for the education. I need to call in a repair person (big TV & stairs), but at least I'm more knowledgeable and won't be as surprised with repair co. actions.... Thanks very much.
  • 10,594 Answers
Please intimate exact model number of your JVC TV to find out reason of horizontally white lines at top 4" area.
Thanks.
Posted on Jul 11, 2009
  • Shahid Electronics
    Shahid Electronics Jul 11, 2009
    Thanks or model number info.
    Problem exist in vertical output section, please replace electrolytic capacitors in vertical out section.
    If you want to repair it by yourself then you should have repair manual of TV and repair manual can be download from Manual Zone for small fee.
    Thanks,
    Deb
    Well if pro is doing this job then let him arrange electrolytic capacitors and these are common parts that mostly available in TV repair shops.
    Cost of parts can be around $60 plus TV repair charges.
    In my opinion pro can return your TV next day after fix.
    Thanks.
White lines across the top of the screen
It sounds as though you can see Transmission lines which are sent out with any broadcast at the top of an image, The TV should normally blank these out, i suggest checking your horizontal and vertical settings
May 31, 2010 | JVC AV-27230 27" TV
White horizontal dashed lines appear and at top of tv screen
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Mar 13, 2017 | Apex Digital GB43HD09 43" Rear Projection...
Permanent horizontal line approx. 4" from top of screen
if this line is in the picture, that is possible burn in screen. if you have a black bar at the top or faint white lines that come down from top this is caused by defective filters in vertical circuit or bad vertical output. mch
Feb 20, 2009 | LG 50PC3D 50 in. Plasma Television
Thin white horizontal lines across top of TV
replace vertical out put ic and related capacitors
please refer to a qualified tv personal to check tv
Jan 17, 2009 | Televison & Video
Line accross top of the screen with flashing black and white boxes
Thin white dashes on top of screen is PERFECTLY NORMAL. It is nothing wrong with the TV, it is the broadcast. What you are seeing is the very bottom of the timecode running. It doesn't happen all of the time or all channels. It usually happens with old 4:3 commercials predating "Digital TV." This is mentioned in your Users Manual. You should be able to adjust the horizontal/vertical position in the menu settings.
Jan 02, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Lines across screen when using View On Demand channels
Could be a couple of things causing this.
1) Obvious, but I assume that you subscribe to these services, because otherwise it could be the encryption.
2) Make sure that you have the set-top box connected directly to the TV, and not through an external recorder (VCR, DVD etc)
This would be a problem if the services were copy protected in the same way DVDs are.
You could also check the settings on the set-topbox. Make sure the video output is set to RGB.
Aug 05, 2007 | Philips 42PF5521D 42 in. HD-Ready Plasma...
Faint horizontal lines in picture
This is usually caused by a problem in the Horizontal Output section, around the Horizontal Output transformer usually a capacitor or diode going or gone faulty... the line you see are the Horizontal "Retrace" lines that are useually "Hidden" when the circuit is OK..
Jul 30, 2007 | JVC AV-27320 27" TV
Horizontal white lines on top of screen
try to adjust the screen control in the flyback transformer. good luck
May 04, 2007 | Panasonic CT-27G14 27" TV
Several dozen thin horizontal white lines across the top of screen, all channels
These beasts are monsters to get into and service without the proper extenstion cables and a service manual. there are no user replaceable parts inside this set. if you know solid state serviceing, you can try and fix it. There is a bad capacitor or capacitors in the vertical sweep circuit and or the vertical output IC is bad also. If you can solder and unsolder go for it. But if you do not or know how the circuit Works Please find a trained tech to assist you with this repair. Good Luck. PS please do not forget to rate this.
Oct 14, 2006 | RCA 27F500TDV 27 in. TV/VCR/DVD Combo
Televison & Video Logo
62 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
