Question about Garden
How do I release the saftey latch? - Garden
  • 41 Answers
On the handle where the guard is push the saftey latch forward. hope that helps
Posted on Jul 11, 2009
My hood safety latch want release the hood so it can open. How can I get around this
You will need to use a long tool and some spray lube to get it to pop. Have some one hold up on the interior latch while you try 'slapping down' on the front of the hood with your hands and if that doesn't work, try the spray through the grill area. Use the long tool with a flashlight to try pushing the latch from the grill area. Good luck!
Sep 13, 2015 | 2005 Chrysler Pacifica
Open engine hood
One release is under dash by the drivers left foot but the saftey latch is under the hood on the passanger side.Peek under and you should see it ( has a yellow lever ) move it to the trucks right..
Mar 02, 2014 | 2008 Lincoln Navigator
My spare wont descend for some reason the wire will come down but the black plastic bolt will not
common problem, theres a saftey lock just incase the cable poped the tire woundnt fly out, the problem is that the lock gets rusted and sticks, you will have to go and push the lock to release, caution the tire will fall as far as the cable is down, the lock latch to the cable housing, you can also spray wd40 up there and try wiggling and tighten and loosening the spare.
Jan 25, 2010 | 2001 Chrysler Voyager
Does any one know how to open the hood on a 1987 300e if the latch doesn't release
There is a release cable that is attatched to the red releas handle on the drivers under dash panel. You can grab that cable with needle nose pliers to release the hood to the first detent if the handle or cable is broken. There is a secondary release mechanism(called a hood tongue) which routes through the grille where the rectangular slot is once the hood is popped up with the release handle.you can grab the rest of the broken hood tongue with needle nose pliers and pull it out to completly release the hood from the saftey catch. If it is completely broken you can take a long screw driver and push the saftey catch( i beleive to the right) and the hood should be able to open all the way up. Both the hood tongue and the cable(securing portion at release handle) are common failures and break over the years.if it is at the release handle you are having a problem-get a #2 phillips screw driver and remove the release handle to gain access to the loose cable. I hope I have been helpful
Oct 07, 2009 | 1990 Mercedes-Benz 300 Diesel
I have a 2000 Blazer and the back hatch won t release.How do i get inside the back hatch to release it?
right where the carpet meets the plastic on the tailgate there is small opening pretty buch right on the other side of the button if you get a flat head screw driver in there there is a saftey slider latch in there move it over and its open
Mar 22, 2009 | 2000 Chevrolet Blazer
PT Cruiser LAtch won't operate
If the latch won't operate when you use the handle, try inserting the key, turning it, and pulling up on the liftgate while the key is in the turned position (it won't stay there, so you need to hold it turned while you raise the liftgate.
Aug 06, 2008 | 2001 Chrysler PT Cruiser
Amana self cleaning oven - latch is stuck
make sure that everything is turned off then the saftey latch should release,
Jun 12, 2008 | Amana Kitchen Ranges
UNLOCK STOVE DOOR
no code for unlockin door, were you self cleaning unit prior to door locking? if so themal fuse problably tripped off for percieved saftey reasons( thought it got too hot), you might be able to jimmy door open witha wire hanger bent a 90 degree angle maybe 2 in long slide it between console and door latch should release to the left. good luck fishin!!!
Feb 21, 2008 | KitchenAid Superba Architect KSCS25INSS...
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
