Hello Anonymous!
Error code Er rF is an :Abnormality of BLDC FAN Motor for Freezer.
Good Luck,
JP
Testimonial: "You have been a lot of help so far. See additional information below."
JP I have noticed ice on the back left side of the refrigerator behind the long glide n serve drawer. Can this information help pin point the problem. The temp in the main part of the refrigerator is warmer and in that drawer everything was frozen.
Good Morning Jimpat Holmes, thank you for your inquiry!
I understand that you are having an error code "ER" displayed on the panel of your Frigidaire dishwasher. Normally, "ER" stands for error code and that can be a miscommunication within the board. I would perform a reset on your dishwasher and you can do that by disconnecting power from your dishwasher for ten minutes. If you continue to receive an error code you could be experiencing an issue within the control panel or faulty wiring harness. I hope this information is helpful. -Matt
Hi friend, thank you for your inquiry!
I understand that you are receiving an "ER" error code on your Frigidaire range and you want to clear the code. "ER" stands for error, I would recommend performing a reset which can be done by flipping the household circuit breaker for roughly ten minutes. That should clear any false error codes. If you continue to receive an "ER" or any different codes please provide that feedback. I hope this helps. -Matt
