Question about Canon PowerShot A75 Digital Camera
Why do I get something purple and black instead of a picture?
I turn my camera on and I set it up and I try to take a picture but it has this purple and black on no picture to be taken.
SOURCE:
t00nz
  • 4738 Answers
SOURCE: My camera will only take pictures of a purple screen
Sounds like a defective CCD imager. You may be in luck. Canon should fix this for you for free, including free shipping both ways. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
Posted on Nov 15, 2007
HeavyDLB
  • 46 Answers
SOURCE: Camera will take picture, but the picture is coming out black!!!! Help Please!!!
Dear vera11:
The symptoms you're describing sound like a classic case of having a faiiled CCD image sensor.
First try pressing the display (DISP) button on the back of your camera several times to see if your image returns at any time. One of the three display modes is "off" to preserve battery life. Your problem may be as simple as inadvertently pressing this button into the off mode.
If that doesn't work, try doing a reset and then removing your batteries from the camera for a few minutes, reinstalling them and turning the camera on to test the LCD screen.
If your screen is still black, but you can clearly see pictures taken previous to the problem, and you can clearly see the menu system when you press the MENU button, then you likely have a CCD sensor problem. Contact Canon Tech Support at 1-800-828-4040 to have the camera repaired.
Hope this helps.
Sincerely,
HeavyDLB
Posted on Jun 01, 2008
FlashyBits
  • 11 Answers
SOURCE: The LCD went black, all the icons are showed, but no pictures. Any taken pictures are also black! Already reset the camera in factory settings, didn't help... anyone???
To ivowitteman
Bad news & Good News
The BAD news is that it sounds as if your CCD has gone wrong which is the part of the camera that captures the image. The CCD is made by Sony & there is alot of dodgey ones out there that Sony have said sorry about. (type "bad CCD" on a search engine & you should be able to get more info)
You say that the icons appear so the rear LCD must be working. If the playback of pictures from a card also works then it is almost certainly the CCD at fault.
The GOOD News is that your model is one of the ones that is listed as eligible for a free replacement of the CCD. You will need to contact Canon & they will advice of what to do. I have sent several cameras of different makes back to the agents for repair & all have been repaired for free. The fault you have first occurred a few years back now so there will probably be a point where the agents will say enough is enough & stop the free repairs.
Hopefully you will be eligible for the free replacement.
Hope this helps
FlashyBits
Posted on Sep 26, 2008
gurymoto
  • 26 Answers
SOURCE: Canon Powershot SD 1100ES - display problems
My mother has this model camera. I believe there is a setting in the main menu that will allow an energy saving mode that sets the display time or no display. If not it's under warranty and your retailer should replace it if it is within 30 days of purcase date.
I hope this helps, goood luck!
Posted on Nov 20, 2008
t00nz
  • 4738 Answers
SOURCE: Black with purple lines instead of image in viewing screen
This sounds like it might be a defective CCD imager, and is a known defect for your particular model camera.. If so, Canon should fix this for you for free if you live in the US, Canada, and a select few other countries. If you live outside the US, contact Canon support for your country to see if they'll still honor the advisory (some still will, especially if you stress you knowledge that this is a known defect of the camera). They may also include free shipping both ways (free shipping varies with countries). This is regardless of your camera's warranty status. Please see this link for more info.
Affected cameras with this problem include: A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S230, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
Posted on Jun 20, 2010
When I turn on my camera I get a black screen
The camera is either set to a power save mode or the screen has failed.
Check your user guide for power save settings, if you don't have one, you should be able to download one from here:-
http://www.canon.co.uk/For_Home/Product_Finder/Cameras/Digital_Camera/PowerShot/PowerShot_A2200/
Mar 03, 2012 | Canon A2200 Digital Camera
Worked good, then has gone black. What happened?
you probbly set it as negitive on settings my does that all u need 2 do is go on settings and turn it back 2 normal
Jan 11, 2012 | Olympus FE-280 Digital Camera
I have the same problem this guy had: I have a Sony Cybershot 8.1 megapixels. Every once in a while the screen will turn black when I turn the camera on. The display will come up (shaky hand, flash, etc.)...
The camera either has a stuck aperture inside the lens or a bad CCD sensor.
The aperture is the opening that allows light to enter the lens. If it's stuck closed no light goes in, so no display on the LCD and solid black pictures. The way to fix it is to replace the lens. You can try tapping or banging the camera on it's side on your hand or even gently on a table. This might unstick the aperture for a short time, but it will just stick again later.
If the CCD is bad the sensor won't show anything other than solid black, or sometimes purple/pink smeared lines. Again the solution is to replace the lens assembly, or look for a used CCD online and just switch that out instead.
Hope this helps!
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
Jul 12, 2011 | Sony Cyber-shot DSC-W100 Digital Camera
Jun 20, 2010 | Canon PowerShot A95 Digital Camera
Everything is purple can see nothing
its problay a setting error try bring down the color or light in the settings
Aug 23, 2009 | Kodak Easyshare M753 Digital Camera
Black screen on Kodak M753
You have a bad CCD imaging sensor. Not worth repairing. Very common problem with most point and shoot cameras. Suggest you buy a new camera.
Jul 02, 2009 | Kodak Easyshare M753 Digital Camera
Sony DSC-T700 PURPLE FLICKER
Let's try Initializing the Camera.
If you're able to access the Home Menu select the SETTINGS in the Home menu.
Then, select the MAIN SETTINGS under the SETTINGS.
Then, select the Initialize option under the MAIN SETTINGS to initialize the Camera.
If the issue still persists try Power Resetting the Camera.
To Power Reset the Camera, First, please turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the POWER button on the Camera for 30 seconds.
Then, reinsert the battery pack and check whether the issue is resolved.
If the issue still persists service of the Camera is required.
Jun 14, 2009 | Sony Cyber-shot DSC-T700 Digital Camera
Purple tinged camera screen
all you have to do is, (Now, I know this may sound crazy but it will help) Take apart your camera. Disconnect the black cord wrapped around the blue cord. Pull out the yellow cord out and throw it away. That yellow cord is a virus which is causing your screen to go purple. Now reconnect the black cord and unwrap it from around the blue cord. This will cause your screen to not only turn back to normal but to hold 2x the space of pictures you would usually hold. If this doesn't work, then stop being lazy and buy yourself a new camera. Yes, I'm talking to you granny!!
Good day my fellow American citizens. I really do hope this works. Thank you for your time. ;)
May 21, 2009 | Kodak EasyShare C713 Digital Camera
Purple lcd display
Hello tonyj111, If your old pictures look fine on the display, then the problem is related to the ccd sensor itself. The purple color is displayed because of a problem in the signal transmision from the ccd sensor to the camera's main processor. This is done using 3 channels one for each primary color (RGB red green blue). If the connector to the sensor is broken, or got out of place (loose) because some mechanic shock or symilar, the data processing woun't come out right. It is purple because your camera's processor mess up blue and red signals therefore resulting same purple instead of blue or red colours. In order to fix this you will need to either send the camera to a service center to have those connections checked (if your camera is still in warranty you will want to do this) or ask me for further instructions if you wish to try to dissasemble the camera yourself. In either way the problem is fixable and in most probabilities a cheap fix will work. Good luck
Jun 01, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Purple Tint Sky
auto white balance should work OK. I was thinking maybe you had accidentally switched it to the Fixed setting. Hmm. You said you were using Normal and Landscape modes. Just to see how it works, I would suggest switching from Program mode to Full Auto. See if that fixes your purple skies. I don't know why it would, but it is something to try
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Canon PowerShot A75 Digital Camera Logo
82 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
