This is a common problem. If you are handy with a soldering iron you can fix it yourself. There is a thermo detection capacitor (round) on the main circuit board that has to be replaced. Use a low wattage soldering iron (25Watt)and electronics solder. If you aren't familiar with electronics soldering; then it's best to replace the set... repairers will charge you more than the set is worth to replace the $5 part and you can buy better ones these days. It is best to NOT wall mount these types of sets as they often overheat and fail.
SOURCE: RCA TV
Could you supply me with the chasis number from the back of the tv E>G ctc203 at113. With this information , I can tell you probably what the problem is and approximately how much it will cost to repair. Each Rca has its own set of problems. Recently RCA/GE were purchased by a large Chinese Corporation. Some of the newer sets are totally CHINESE.Here are some of the common problems that would give you this symptom. Bad connections on the IHVY(flyback). Open horizontal windings in the Yoke. The original problem is problably due to an inaccaure setting in either the red cutoff or red background. These adjustments can only be made from the servicemans menu and are not accessable to the consumer. The problems described are of a serious nature(except you original one). You may consider shopping for a new set , replacing it with an LCD. The LCD gives off no radiation and cost much less to operate (electricty) Scrivitron
SOURCE: How to acess set-up menu without factory remote
The manual can be found near the bottom of the Product page for this TV.
From the manual, pg 11 -
If you misplaced your Remote Control you can still access most settings
via the MAIN MENU screen when you press both CH UP (8) and
DOWN (9) on the TV set.
• Some features of your TV Set will not be accessible without the Remote
Control. If you lost your Remote Control, contact a Sharp Authorized
Servicer by calling 1-800-BE-SHARP for a replacement.
Let us know if this fixes it for you.
SOURCE: Broken ant/cable connection on Sharp TV, model 25R-M100
yes u can buy them at a local radioshack or similar business
SOURCE: SHARP TV Model 13E-M100, remote broken, trying to
I would need to know your remote model to be able to give a specific answer. However I can give you the link wherein on looking up wiyh your model no. you can get the proper code.
http://www.xdiv.com/remotes/
better solution is however available at
http://en.kioskea.net/faq/281-universal-remote-codes
