Kitchen Appliances - Others Logo
j
jeannette salmen Posted on Jul 08, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I make pop corn in model 207226? What measurements?
WHat are the measurments for the corn and do I add oil? If so how much?
johnny rebel
Level 3:
Top Expert:
  • Master 10,875 Answers
  • Posted on Jul 08, 2015
 johnny rebel
Master
Level 3:
Top Expert:
Answers
10875
Questions
0
Helped
2942068
Points
47944
Don't have a manual need to know how to operate Do I add oil or butter in bottom with the corn if so how much?
the ratio for popping corn with oil is three parts corn to one part oil . So a 6 oz kettle you would use 6 oz of corn seed to 2 oz of oil. Don't use butter to pop, it will burn.
I lost the instructios for the amount of kernals to put in and if put oil in the well
If you have no idea what brand or model number you have and the kettle is heating properly you can figure it out pretty close just by timing the popping cycle. The ratio is 3 parts corn 1 part oil. so a 12 oz kettle would be 12oz of corn (1-1/2 cups ) to 4 oz of oil. A good popping cycle takes about 3 1/2 min from the time you add the corn and oil to dump time. you can make ajustments for the results you get.
I have a Fun time 2408 machine we ended up using different pre made popcorn bags and oil 4 6 and 12 and were just now realizing that weve been using the wrong oz,s and when we do it make crappy pop co
You can clip the corner of the popcorn section and shake the salt into a small bowl, then cut just the corn section into another bowl, and hand measure the ingredients.
The Funpop 8 works best with 2oz (1/4 cup) oil, 8oz (1 cup) popcorn, and 1 teaspoon of salt.
1helpful
I have 2003 model whiz bang popcorn machine that takes forever to pop the corn
Old popcorn is the first thing to check, and that you are measuring correctly. 12oz of popcorn is the correct amount in a 3 min popping cycle. always time the 2nd batch.
That model popper has 2 heat elements, and 2 thermo stats that control them. If the first 2 things to check are good, then you dropped a thermo stat or heater and it is operating on 1 heater instead of 2.
The popcorn is not popping. the kernals are just burning. help! please!
You may not be using enough oil. You should have 3 measures of popcorn, to one measure of oil. So if you are using 12 ounces of corn, you should use 4 ounces of oil.
How to pop corn in a westbean corn poper
put about 2 tablesppons oil into the popper. Put 2 or 3 kernals into the oil. Turn the popper ON. When the kernals pop,.the oil is hot enough. Add 1/2 to 3/4 cup corn and enjoy when its done.
2helpful
3answers
Need model number for Gold Medal popper
http://www.concessionpalace.com/concession-tutorials/P-60_60_Special_Uncle_Walts-1866_2085_2086_2656-popcorn-machines.pdf
7helpful
NEED AN INSTRUCTION MANUAL FOR ''OLD FASHIONED MOVIE TIME POPCORN
The usual way to use a pop corn popper is to:
1st - add oil
2nd - add popcorn
3rd - add any seasoning (if using the pre-packaged "theater" popcorn mix).
DO NOT add butter into the popper, as it will burn quickly and make for some foul tasting pop corn.
You can always add butter and salt to taste AFTER the pop corn is done popping.
Hope you find this Very Helpful. Best regards!
2answers
Brown oily leak
The oil is leaking around the stirring-arm-motor shaft -- it needs a new seal. It's not the oil you're using.
Popcorn maker
When Popper Has Popped Corn Just Before.
1. Pour the properly measure amount of Oil into the kettle.
2. Wait about 45 seconds - or until the Oil in the kettle starts to smoke slightly.
3. Pour the contents of the properly measured corn cup (kernels plus popcorn salt or Flavacol) into the kettle.
4. Wait about 2 1/2 minutes. If you are using a pan on the stove without an agitator, you must constantly shake gently. When the crackling noise of the popping corn is no longer heard, dump the kettle and empty it completely.
5. Repeat if needed for more popcorn.
6. When you are finished popping, turn off the kettle agitator switch (if you have one) and turn off the Pilot light/ heat switch.
7. After the machine has cooled enough so as not to be dangerously hot, wipe the outside of the kettle with a soft damp cloth. This helps prevent a heavy build-up of the Oil.
TIPS
- Bagged floss keeps a day or two, depending on the humidity
- Use bags to make and display cotton candy in advance - use cones for immediate sales
- Unless you're experienced, it's best to turn off the motor to refill the spinner head
- If machine will be used more than 20ft. from power source, be sure to have an adequate extension cord
Top Helman Group Kitchen Appliances - Others Experts
john h
Are you a Helman Group Kitchen Appliances - Other Expert? Answer questions, earn points and help others
