SOURCE: GE GSL22JFPH BS refrigerator, coils icing up
I'm in the process of fixing the same problem on a GSS22JEPDWW right now. There are several parts in the defrost circuit that I can tell:
1) Defrost Heater
2) DefrostThermostat
3) Temp Sensor (Thermistor)
4) Main Control Board
I've replaced the Defrost Heater (remove back panel of freezer section - it's a stainless steel bracket that has a glass bulb in it) and it still doesn't work. The main control card provides power to the heater 4 times every 24 hrs for 25 minutes or so to defrost the evaporator coils. If all items are working, you'll see water in the drip catch at the bottom inside of the freezer compartment. Better yet, pull the refer away from the wall for 24 hrs and check if water is gathering below the plastic drain on the right rear of the refer in the pan. The water drips into a pan and the fan for the condensor coil evaporates it. Go to the www.ge.com website and look in the service section to find the parts diagram for your refer. You can then get a part number to buy the parts you need from a local parts store or the Internet.
I just bought the thermostat a few minutes ago and will try that next. Heater was $37, thermostat was $15. Sensor is about $20 and the control card is $140 (you can find on line for $95). I'm going down that path. If none of this works, it'll be in the dump in a week.
I've learned on-line GE refers are bad news. The control cards can fail repeartedly, althoough mine has worked for over 4 years. But, I won't ever buy another one since refers should last at least 15 years in my book. After $200, it doesn't pay to throw more good money after bad. I'll keep you posted on my results.
TM
SOURCE: defrost thermostat connector
Where is the defrost heater? If it is below the problem area, I don't think it is a defrost problem. This sounds like low freon. The symptoms of this are heavy frost on only part of the coils. Try deforsting with a hair dryer and putting it back together. Wait about 3 hours and look again. If there is frost only on part of the coils that is bad. The most this unit could defrost is every 4 hours, most are on 8 or 12 hour cycles. On most units the defrost timer shuts off the compressor and gives current to the defrost heater/s through the defrost thermostat. This thermostat is closed below 15 degrees and opens at a much higher temp after sensing the heat. This shuts off the heat usually before the timer and lets the water drip down where it should go. Then the timer turns the compressor back on and removes current from the defrost system. A common defrost problem is if the doors are left open for a LONG time or not shut all the way. Sometimes it causes so much ice that it can't melt with just one defrost cycle. This problem builds as if air flow is restricted it causes even more frost and gets worse. If this ever happens , just find the defrost timer and turn it very slowly click by click just until the compressor stops. Let it defrost , then do it again in about 2 hours. If it is a low freon problem there may still be a partial warrenty left sometimes the sealed system is guarenteed ror 5 - 10 years. Sometimes if it is not covered it is not worth fixing.
SOURCE: evaporator coil iceing
if you can put the frig. in defrost this will tell the sensor to turn on and you will see the heater melting the ice,if you can't put it in defrost and the sensor still has ice on it,simply put it in your hand,as your hand warms up you should feel the sensor pop,this pop tells the heater to turn off,if no pop the sensor is bad,if no ice on the sensor put it in a glass of ice,chill it down and do the same hand test,you can also use an omhs meter to check it,all the sensor does is open and close,let me know what you find-mike
SOURCE: Samsung side-by-side RS2545SH with several problems, possibly related
never buy a samsung appliance because you can not repair them. the company would like for you to buy a new one . my fridge the rs265labp freezes up in the fridge section and i have to take it apart once a month to defrost it. but i did find that if you keep a couple of boxes of baking soda in it and replace them often it helps to make the time between defrosting longer. hope this helps someone. i hope that samsung either goes out of business or straightens up
SOURCE: evaporator coil freezing, replaced main control
It is possible you have a defective fan motor in the condenser area or evaporator area. Sometimes when they become defective they will run for a while and just warm up and stop while the compressor continues to run. I learned that one on four costly returns to the home. The cost was to me not the customer. Thanks, Sea Breeze
